Finding the magnitude and direction of a boat's motion
In summary: That can be done by comparing the direction of the boat relative to the river to the direction of the river relative to the bank. Does that make sense?In summary, a boat is traveling upstream in the positive direction of an x-axis at 14 km/h with respect to the water of a river, while the water is flowing at 9.0 km/h with respect to the ground. To find the magnitude and direction of the boat's velocity with respect to the ground, the formula for magnitude is √(14^2+9^2), and the formula for direction is θ=tan^(-1)⁡〖9/14〗. The boat is going upstream relative to the river, and to
Abdullah Younas
A boat is traveling upstream in the positive direction of an x
axis at 14 km/h with respect to the water of a river. The water is
flowing at 9.0 km/h with respect to the ground.What are the (a)
magnitude and (b) direction of the boat’s velocity with respect to
the ground?
For direction : θ=tan^(-1)⁡〖Y/X〗
For Magnitude: √(A^2+B^2 )
Homework Statement: A boat is traveling upstream in the positive direction of an x
the ground?
Homework Equations: For direction : θ=tan^(-1)⁡〖Y/X〗
The formula for magnitude is √(A*A)+(B*B) but simply subtracting the magnitude of speeds and the farmula of direction is θ=tan INVERSE(Y/X).
but simply shows the direction into +ve and -ve x-axis. what is the best solution of the problem?
Please explain what you mean by that.
Why are the "relevant equations" you quote relevant to this problem? I.e. what do the A and B or X and Y in them correspond to in the question?
Am I missing something? From the information in the question the only thing that can be calculated is the speed. I'm willing to be educated but I can't see how the magnitude/mass can be calculated from the info provided and neither can direction (assuming direction is expected as degrees, minutes and seconds). I think I'm in at the deep end here.
travellinglee said:
magnitude/mass
Mass?? There is no mention of mass in the question. It asks for the magnitude of the velocity, i.e. the speed.
Do you understand what is meant by the magnitude and direction of a vector?
In general, yes you can figure out, in degrees, the direction of the velocity wrt the ground, given the velocity of the river and the velocity of the boat relative to it.
In the present case, it is almost trivial because the two given velocities are parallel to the same axis (termed here the x axis). So in this case it is simply a matter of deciding whether the boat is going upstream or downstream.
I obviously don't understand the term 'magnitude' in terms of physics terminology, in my uneducated world 'magnitude' is a general reference to the size and/or weight of an object, please explain. As far as direction in concerned I was expecting the answer to be more than just 'upstream' or 'along the X axis', something more like 0°, 0', 0'' e.g. North. Sorry for asking all these questions, it's a learning curve.
I am supposing A or B and X or Y values .
That's not what I asked.
You have a boat and a river, both moving. How do those directions of movement relate to X and Y in your equations?
You may need to read the question more carefully. It says: "A boat is traveling upstream".
For magnitude, see https://en.m.wikipedia.org/wiki/Euclidean_vector.
For direction, it doesn't have to be a compass direction. In this question we are given the direction of the boat relative to the river as upstream. What we are asked to find out is whether it is upstream or downstream relative to the bank.
Related to Finding the magnitude and direction of a boat's motion
1. What is the difference between magnitude and direction?
The magnitude of a boat's motion refers to the size or amount of the movement, while the direction refers to the path or angle of the movement.
2. How is the magnitude of a boat's motion measured?
The magnitude of a boat's motion can be measured using a variety of methods, including GPS tracking, speedometers, and accelerometers.
3. How is the direction of a boat's motion determined?
The direction of a boat's motion can be determined using a compass or by measuring the angle of the boat's movement in relation to a fixed point.
4. Can the magnitude and direction of a boat's motion change?
Yes, the magnitude and direction of a boat's motion can change due to factors such as wind, currents, and changes in the boat's speed or course.
5. What is the importance of finding the magnitude and direction of a boat's motion?
Knowing the magnitude and direction of a boat's motion is crucial for navigation and safety, as it allows the boat's position and movement to be accurately tracked and monitored.
9K
9K
