Fluid pressure, energy and temperature
In summary, the conversation centers around creating a numerical simulation to solve the Navier-Stokes equations for fluid dynamics. The first question involves finding an expression for pressure within the fluid and whether the perfect gas equation of state is applicable. The second question relates to the different energy components in a fluid and how temperature is defined as a measure of average kinetic energy. The third question is about finding the temperature throughout the fluid, either through the total energy equation or the entropy equation. The individual asking the questions is seeking clear and useful information on these topics.
sidman
Hi everyone. This is my first post here...
I want to create a numerical simulation in software, to solve the Navier-Stokes equations (Newtonian fluids, compressible and viscous flow) and I have some questions regarding fluids and their dynamics.
(1) The Navier-Stokes equation for the conservation of momentum, contains a term which represents the spatial difference in pressure within the fluid. (the pressure gradient [tex]\nabla[/tex]p) I know how to calculate gradients in general, but the problem is I can't find an expression for the pressure field, to begin with! I only found expressions for hydrostatic pressure w.r.t. depth in static fluids. I also found an equation of state, relating pressure to density, temperature and molecular mass but it's called "*perfect gas* equation of state". Would it hold for arbitrary, non-static fluids? Furthermore, shouldn't velocity affect pressure? it makes sense, I think.
(In most numerical simulations, the flow is considered incompressible and the calculation of this gradient is worked-around. In fact, it's used as a constraint to impose incompressibility.)
(2) What are the energy components in a fluid, that its "total energy" comprises? how are they defined? I suppose there should be a kinetic energy contribution, a thermal one, and perhaps a "potential" one? (e.g. one that would change into kinetic, as a stationary particle would flow towards areas of lower pressure due to the pressure gradient?) Is this correct?
Also, temperature is usually cited as "a measure of average kinetic energy". What does that mean? That it's simply proportional to kinetic energy? Does this hold "locally"? like for an infinitesimal fluid parcel of known velocity and density?
(3) My question here may be clear already from any answers to (2), but... here goes. I want to find the temperature throughout the fluid, and I understand that this is usually done with a 3rd equation (apart from the mass and momentum conservation in N-S) which comes from the conservation of energy. I found several forms of it, however two seem the most useful: the first one expresses the time-rate change of total energy E, and the other contains a product of temperature T and the time-rate change of entropy S. (they are related through the maxwell relation Τ = [tex]\partial[/tex]E/[tex]\partial[/tex]S)
Is it possible to find the temperature from the total energy, or any of its components mentioned in (2)? Or perhaps, is there a way of finding the entropy and substituting in the 2nd equation to solve for T? Any other useful formulas, relating energy/temperature/entropy? Perhaps, a simple equation of state would do, without even using the energy equation? (velocity and density are considered known)
I guess that's about it... I'm sorry if this is somewhat... lengthy, but I've been looking for days and can't find clear, useful information. So, I thought I'd ask here...
Naturally, I'm not expecting answers to everything from a single user, so feel free to answer/comment on anything you like. All contributions are highly appreciated.
Thanks in advance, for your time and any answers. :smile:
Science news on Phys.org
The answers to all these questions are in Transport Phenomena by Bird, Stewart, and Lightfoot.
Related to Fluid pressure, energy and temperature
1. What is fluid pressure and how is it measured?
Fluid pressure is the force exerted by a fluid per unit area. It can be measured using a device called a manometer, which consists of a U-shaped tube filled with a liquid, typically mercury or water. The height difference between the two sides of the tube indicates the pressure of the fluid being measured.
2. How does the energy of a fluid affect its pressure?
The energy of a fluid, specifically its kinetic energy, is directly related to its pressure. As the kinetic energy of a fluid increases, its particles move faster and collide with each other and the walls of the container more frequently, resulting in a higher pressure.
3. What is the relationship between fluid pressure and depth?
According to Pascal's principle, fluid pressure is exerted equally in all directions. Therefore, as depth increases, so does the pressure exerted by the fluid. This is because the weight of the fluid above increases with depth, resulting in a higher pressure at lower depths.
4. How does temperature affect fluid pressure?
Temperature has a direct effect on the volume of a fluid, which in turn affects its pressure. As the temperature increases, the volume of a fluid expands, causing an increase in pressure. This is known as thermal expansion and is important to consider in systems that involve fluids and changing temperatures.
5. Can fluid pressure be converted into other forms of energy?
Yes, fluid pressure can be converted into other forms of energy, such as mechanical energy. This is commonly seen in hydraulic systems, where the pressure of a fluid is used to move pistons and generate mechanical work. It can also be converted into electrical energy through the use of turbines in hydroelectric power plants.
  • Thermodynamics
  • Thermodynamics
  • Biology and Medical
