manimaran1605
- 60
when a body is slided or move in a horizontal floor, the Frictional force is directly proportional to the Normal force acting on the body. Is there is any proof (emperically or Theoretically)
In the case of tires, there's a load sensitivity factor, reducing the coefficient of friction as the load increases. Wiki artcile, although this is for static friction:HallsofIvy said:In fact, like most simple physics laws, it is a "first order" approximation.
Frictional force is a force that opposes the motion or attempted motion of an object. It is caused by the interaction between two surfaces in contact and is dependent on the roughness and materials of those surfaces.
Frictional force can be calculated by multiplying the coefficient of friction (a constant that represents the roughness and materials of the surfaces) by the normal force (the force perpendicular to the surface).
Normal force is the force that a surface exerts on an object that is in contact with it. It is always perpendicular to the surface and acts in the opposite direction of the force applied by the object.
Normal force and frictional force are directly related. As the normal force increases, so does the frictional force. This is because a greater normal force means a stronger interaction between the surfaces, leading to a greater frictional force to oppose motion.
Frictional force can either help or hinder motion. It can be useful in preventing objects from slipping or sliding when a force is applied, but it can also act as a resistance force, making it harder for objects to move across a surface.
