Has anyone ever programmed a computer system to evolve theories?
In summary, the conversation discusses the possibility of programming a computer to generate theories or mathematical structures based on experimental data and then testing them against related data to see if they accurately predict outcomes. This process would involve slight mutations and mating of successful theories to create an evolved theory. The conversation also explores the idea of starting with simple concepts and gradually building upon them to create more complex theories. It is suggested that this process could be done through brute force, but it may also require the ability to create new math and recognize patterns in patterns. The concept of quantum computing is also mentioned as a potential tool in this process. Overall, the conversation highlights the difficulty and potential of programming a computer to generate theories.
Meatbot
147
You would feed it experimental data and it would generate theories or mathematical structures which fit the data. The theories would then be run against related experimental data to see if the theory also predicted them as well. Slight mutations, mating successful ones ---> evolved theory. Impossible or just hard?
Computer science news on Phys.org
Define 'theory' to a computer.
Maybe you don't need to. It would be programmed with the current theories and the current data and then start riffing off the current theories, modifying them in millions of ways and testing against data. Adding/removing terms and relationships. Mixing structures. Could begin by throwing out millions of what-ifs and "crackpot" theories until one sticks, then evolving it. Just brute force.
1) What if the universe is 1D? Fail, doesn't fit data.
2) what if it's 2D? fits more data since you can have things in more than one place, which we see, but fails against other data.
3) what if it's a 3D? Fits even more data
4) What if 3D and stuff doesn't move? Fail, data shows movement
5) What if 3D and stuff moves? fits some data but doesn't address all of it.
Start with really simple thiings and keep getting more and more complex...
It would consist of lots of simple building blocks or observations.
1) Something exists. (things > 0)
2) There are many things (things > 1)
3) A thing can be different from another thing. (Things(a) > 1 and Things(b) > 1)
4) Some things are blue
5) blue things reflect light with wavelength x...
etc...
And then various structures would have properties:
- sphere has more than one point
- sphere has volume
- sphere is 3d
etc...
Theory: Universe consists of two spheres.
Check against data: Data shows 3 spheres, therefore Spheres>2
Result: Fail, modify and try again.
Not a computer science or physics guy but seems like it can be done even though it'd be hard.
http://www.sciencemag.org/cgi/content/abstract/324/5923/85
http://singularityhub.com/2009/12/17/eureqa-software-to-replace-scientists/
If nothing else, it's interesting to think about.
etc...
- sphere has volume
- sphere is 3d
etc...
Great start, and yes, actually, I did, back in the 80s, only it was about the extent of the above, times 10,000.
We basically sat around modeling ourselves with questions and answers for a few months.
I think we made good, but not terrific.
Meatbot said:
It would be programmed with the current theories...
Again, define 'theory' to a computer.
i.e. how does a computer program know what a 'theory' is?
Why is that necessary?
Evolution doesn't work from a definition. It's a matter of how a certain set of stimuli (inputs) are classified. I.e, Definitions are inferred from observations. Generalizations are made across the observations. Then, for examples, an exception to the generalizations is found, and a fission occurs and a new branch of classifications are developed. As more observations are made, the generalizations are optimized.
Then, for our own sake, we might define a theory as a generalization that meets a minimum threshold of .4 on the "generalness rating scale". And can be tested by testing the generalization on future observations that haven't been directly observed but are similar to past observations.
This looks like the fantasies people had a few decades back about neural networks...
Just feed in lots of data and the "system" will find out.
It turned out to be much harder than it sounded.
Well yeah, nobody said it was easy.
Isn't quantum computing essentially moving toward this? I mean, they're basing their qubits off the state vector of a fundamental physical system, not just abstractly, but the hardware itself, correct?
This could require the need to be a complete evolving program that can make up new math as well.
And based on that, recognize relations and find patterns in patterns.
But then how do you let a computer see how things relate to each other without predefining what it should look for to recognize this, as this should be its own task to evolve in in order to find the new theories.
Although I do think predefining with our current knowledge could already let it find interesting patterns.
It all reminds me of this:
http://singularityhub.com/2010/05/12/stephen-wolfram-is-computing-a-theory-of-everything-video/
Precisely. How do you quantify all that for a computer understand, let aline manipulate?
I can see finding equations to describe things (maybe it could deduce Kepler's Laws) but theories are semantic.
There has to be a way of doing this since our brains can do it. How did you figure it all out? how do you know there is more than one thing in the world. Perhaps as a baby you took in visual data and since the input described multiple areas of color your brain generalized and created a structure that somehow encodes the idea that there is more than one thing in the world. There must be certain arrangements of matter which correspond to the idea that more than one thing exists. Let it learn the semantics the same way we do.
Or figure out how we represent semantics it in our brains and then duplicate it - actually this might be faster. I don't think this is at all easy - just saying that teaching a computer semantics shouldn't be impossible. Exactly how is above my pay grade.
Check this out:
http://en.wikipedia.org/wiki/Computational_semantics
Ah, yes, I guess we have a small difference in the definition of theory. The semantic part of the theory would have to be developed by humans (well, today anyway). The program would find correlations in the data and derive generalized equations (like F = ma and F21 = -F21) that are episodic (for each data set). We could derive a program that is semantic in algorithm (it takes many "episodes" and classifies them) which is essentially what semantics is. Your numerous episodic encounters with apples has led you to the semantics of what an apple is.
BTW, never argue with a computer over semantics. Pigs like getting dirty. Or something.
Sure, 3 billion years of cumulative selection. I don't think I can afford that much compute time.
Oh. I thought you meant like "within this century", not far flung future.
That is the essence of automated pattern recognition and machine learning. This isn't new stuff, Dave. http://ti.arc.nasa.gov/tech/rse/synthesis-projects-applications/autoclass/".
Actually, doing just that has long been the goal of Cyc, along with other less notorious AI projects. It most certainly is the goal of the Semantic Web, aka Web 3.0.
D H said:
That is the essence of automated pattern recognition and machine learning. This isn't new stuff, Dave. http://ti.arc.nasa.gov/tech/rse/synthesis-projects-applications/autoclass/" discovered a new class of infrared stars back in the early 1990s. Work on automated discovery has continued since the heady AI days of the 1970s-1990s. Closer to the topic at hand, Eureqa has (re)discovered several laws of physics without human intervention.
Yes, that's what I said. Computers could discover new equations (or new classes of stars), I'm just dubious about new theories.
impossibile. Computers are just fast, not smart. Very fast, very stupid. No induction, only deduction.
The definition of smart/intelligent has evolved during the rise of computers to mean exactly that which a computer is not, and if this continues computers will never be intelligent. This does not mean that they cannot solve any particular class of problems better then humans, it just means that in a hundreds years when computer is capable not only of independently rediscovering all theories created by Einstein, but also writing several books on the philosophical implications of these theories, we will have redefined intelligent to somehow still exclude this behavior, because the thought of an intelligent machine is simply not something we are willing to accept.
This being said, of cause a computer can be programmed to prove and test theorems just like any human can. The four color theorem was proven by computer for example.
jVincent said:
...because the thought of an intelligent machine is simply not something we are willing to accept.
If it does happen it will not be because we are not willing to accept the irdea of an intellegient machine, it will be because we realize that intelligence is not actually required to do some of the things we thought it was.
Computers today *are* dumb. If they can solve things then those things do not require intellience to solve.
We have computation that is decent at curve fitting and statistical analysis. Mathematical modeling of data.
However, something like you describe I think is quite possible, just not with current computers. I think something like what you describe would be starting to get close to genuine AI, which I also think is quite possible, just not with current computers.
You are proving my point exactly, you have offered no objective definition of intelligence, but seem completely confident that what ever definition is the "correct" one, it will exclude computers because you consider them to be dumb. Therefore you are fully accepting that we revise our definition of intelligence each and every time a computer carries out a task previously considered intelligent, and you will continue to revise the definition even to the point where computers match every capability of humans, simply because you refuse to consider the possibility of an intelligent computer.
By what argument are computers dumb? Reductionism works equally well for computers as it does for humans and as it does for animals. Trying to manipulate your definitions of dumb and intelligent with the objective of forcing these subjects into the categories that you have already decided they should be in simply leads to the definitions being meaningless.
While this may be true:
jVincent said:
... seem completely confident that what ever definition is the "correct" one, it will exclude computers because you consider them to be dumb.
It does not follow that this is true:
Why don't you make the statement false rather than simply unproven by giving us a definition of intelligence for which it would be possible (in the sense of Popper falsifiability) for a computer to pass?
The onus is not on me to bolster any claims. jVincent is making an unfounded claim based on faulty logic about what I/we might decide in the future. Why would I need to address that? All I need do is knock the pins out from under the claim.
I didn't say you had to, I invited you to enlighten us.
like others have mentioned, a lot of this stuff is already being done. for small refinements on linear systems we use kalman filters. for less well-known stuff, system identification like what lennart ljung writes about. even then, you're dealing with mostly linear systems.
it's one thing to run cases based on mathematics that is well-known. but what if the thing you're studying doesn't behave according to the known models? maybe you've got to invent a new type of math to solve the problem. and even if you could do that, what are the chances that you get back something so complex that it is beyond your comprehension?
That's the interesting part to me. Many of the interesting problem may be solved using ideas we haven't even thought of. It has to be able to invent or evolve new models and new math. What if you have it throw out random groupings of axioms and structures and have it analyze the consequences of each?
Quite possible. In fact I read about a group that evolved electronic circuits to perform certain tasks. It turned out the the evolved versions worked much better than the conventional solutions but the scientists had no clue why. The evolved circuits were strange and counterintuitive but worked.
What about evolving ways for the computer to explain it that we will understand? How about a distributed computing project where the computer generates english language explanations and then people grade them as to how understandable they are. Then the system evolves the explanations themselves. Repeat until grokked. It's like a tutor...you don't get it this way? Well, look at it this way...no? how about this...etc... Start with simple things, then the system eventually gets an idea of what humans find understandable and what we don't. It can apply this knowledge to more complex explanations.
Also, it might be good to develop a taxonomy of the different types of relationships/interactions that 2 entities can possibly have. These would be used in generating theories and explanations. Things like this:
- a close to b
- a blocks b
- a accelerates b
- a similar to b
- a and b caused by c, a and b cause c
- a causes b, b causes a
- a same as b
- a prohibits b
- a enhances b
- a inhibits b
- a touches b
- a part of b
- a comes from b
- a is b
- a is not b
etc...
And you can stack them: (a enhances (b comes from (c prohibits d))) is similar to e
And that's hard to understand, so computer gives you this:
c prohibits d, thereby creating b, which is then enhanced by a. The enhanced b is simliar to e.
and then the explanation is further evolved:
c stops d and that makes b. Then a makes b stronger. Now b is like e.
ALSO...now you can plug your data into these things and get starter theories. What if data is:
1) the existence of light
2) the existence of protons
So you could have these theories:
- light comes from protons
- light blocks protons
- (light enhances (protons cause light))
- light is protons
etc.
The it would have to look at the implications of each of these. That's harder.
To create new theories computer would have to think imaginatly, which goes against pretty much everything of what a computer is. A computer follows a fixed alogrithm, and although it can modify this alogrithm, a computer could never spit out something like string theory, because that requires imaginative thinking.
  • #31
Nah...If your brain can do it, so can a computer. Just an engineering problem at this point.
  • #32
Meatbot is correct. Imagination is simply a feature of a very complex system. Have a computer complex enough and it'll be imaginative.
  • #33
You would have to create a neural network with as many neurons as a human brain, which is several billion, and each of those neurons would have thousands of connections, but I suppose that is just an engineering problem...
  • #34
i think you could model imagination (to a degree at least) by throwing in some randomization. that's (part of) how the evolved circuits that Meatbot mentioned arrived at their "imaginative" solutions.
  • #35
There's also mimicing the subtletly of the stimuli and reinforcement between neurons.
<h2>1. Has anyone successfully programmed a computer system to evolve theories?</h2><p>Yes, there have been several successful attempts at programming computer systems to evolve theories. One notable example is the Eureqa program developed by Cornell University researchers, which uses genetic algorithms to generate mathematical models to explain complex data.</p><h2>2. How does a computer system evolve theories?</h2><p>A computer system can evolve theories through a process called genetic programming, which involves creating a set of rules or equations and then using genetic algorithms to generate new variations of those rules. The computer then tests these variations against a given dataset and selects the most successful ones to continue evolving.</p><h2>3. What are the potential applications of using computer systems to evolve theories?</h2><p>The potential applications of using computer systems to evolve theories are vast. This technology can be used in fields such as artificial intelligence, data analysis, and even in scientific research to generate new hypotheses and theories.</p><h2>4. Are there any limitations to using computer systems to evolve theories?</h2><p>Yes, there are some limitations to using computer systems to evolve theories. One limitation is that the theories generated may not always be easily understandable or explainable by humans. Additionally, the quality of the theories produced is highly dependent on the quality of the initial dataset and the algorithms used.</p><h2>5. How can computer systems that evolve theories benefit scientific research?</h2><p>Computer systems that evolve theories can benefit scientific research by providing new and innovative ideas and hypotheses that may have been overlooked by human researchers. They can also help to identify patterns and relationships in large datasets that would be difficult for humans to detect on their own.</p>
Related to Has anyone ever programmed a computer system to evolve theories?
  • Art, Music, History, and Linguistics
  • Beyond the Standard Models
  • STEM Academic Advising
11K
