How to find the period of small oscillations given the potential?
In summary: If ##x## is small, then the linear term dominates and you get the equation for a simple harmonic potential by dropping the term term in...That's right, so you can use the Taylor series to find the potential for small oscillations about the equilibrium point.That's right, so you can use the Taylor series to find the potential for small oscillations about the equilibrium point.
Davidllerenav
424
A particle of mass ##m## is located in a unidimensional potential field where the potential energy of the particle depends con the coordinate ##x## as ##U(x)=U_0(1-\cos ax)##; ##U_0## and ##a## are constants. Find the period of small oscilations that the particle performs about the equilibrium position.
##x''+\omega^{2}x+0##
##T=2\pi /\omega##
I first found the equilibrium points taking the derivative of the potential. ##U'(x)=U_0 a\sin(ax)##, and the equilibrum is when the derivative is 0, so ##U_0 a\sin(ax)=0## so ##x=0## or ##x=\pi/a##. Taking the second derivative ##U''(x)=U_0a^2 \cos(ax)## I find that ##x=0## is a minimum point, since the second derivative is greater than 0, and ##x=\pi/a## is a maximum point. But if I replace any of those points on the first derivtive, I get 0. I don't know what to do.
wait i am not sure what you are asking you got the points' derivate to be zero so obviously if you sub back the points into the derivate you are going to get zero or am i missing what you are asking?thanks
Davidllerenav said:
Problem Statement: A particle of mass ##m## is located in a unidimensional potential field where the potential energy of the particle depends con the coordinate ##x## as ##U(x)=U_0(1-\cos ax)##; ##U_0## and ##a## are constants. Find the period of small oscilations that the particle performs about the equilibrium position.
Relevant Equations: ##x''+\omega^{2}x+0##
##T=2\pi /\omega##
What determines the motion for "small" oscillations about a local minimum in potential?
Yes, sorry you're wright. What I'm asking is what should I do next, after I get the equilibrium points.
A small displacement?
It's the behaviour of the potential on a small interval about the minimum.
Ok, so what should I do once I have the equilibrium points?
Have you heard of the Taylor series expansion of a function?
Yes, they are like this: ##f(x)\approx f(a)+f'(a)(x-a)+\frac{f''(a)}{2!}(x-a)^2+\frac{f'''(a)}{3!}(x-a)^3+...##.
Can you see how to use that here? Using what you know about ##U##.
Should I expand the potential using the Taylor expansion centered on the equilibrium point?
You could try that. But in your OP you had a relevant equation:
Davidllerenav said:
Relevant Equations: ##x''+\omega^{2}x = 0##
How does ##x''## depend on the potential?
I don't know. We know that ##x''## is the acceleration, so maybe I can use the fact that the force is related to the potential by ##F=-grad \ U##, since ##F=ma=mx''##.
Yes, that's right. But, let's use ##\ddot{x}## for the second time derivative. So, you have:
##m \ddot{x} = -U'(x)##
Now, use the Taylor series.
With the potential, centered at a=0?
Of course. That's the point of interest for small oscillations.
Ok, of what degree?
Davidllerenav said:
Ok, of what degree?
I'll leave that to you to decide.
Ok, I did it of degree 3, and I go this: ##U'(x)\approx U_0a\sin(0)+U_0a^2\cos(0)(x)-\frac{U_0a^3\sin(0)}{2!}(x)^2-\frac{U_0a^4\cos(0)}{3!}(x)^3##, so ##U'(x)\approx U_0a^2x-\frac{U_0a^4x^3}{6}##. What should I do know?
If ##x## is small, then the linear term dominates and you get the equation for a simple harmonic potential by dropping the term term in ##x^3##.
Would you explain that a bit more please?
This is the standard approach when expanding as a Taylor series for "small" ##x##. Note that in this case the quantity ##ax## is dimensionless, so when ##ax## is small we have ##ax \gg a^2x^2 \gg a^3x^3 \dots##.
This leaves what's called a linear approximation for the function. Examples include ##\sin \theta = \theta##, which is often used for a simple pendulum for small oscillations.
PeroK said:
This is the standard approach when expanding as a Taylor series for "small" ##x##. Note that in this case the quantity ##ax## is dimensionless, so when ##ax## is small we have ##ax \ll a^2x^2 \ll a^3x^3 \dots##.
Wouldn't ##a^2x^2## be less than ##ax## when x is small? This only works for small oscillations, right?
Yes. I've corrected the typo. The analysis in this particular problem is the same in general for any potential:
Local minimum; first derivative is 0; second derivative is positive; linear approximation of ##U'## for small oscillations; SHM for small oscillations.
It's useful to remember this whole idea as it is used all over physics.
I see. So x is small because of small oscilations right? Since x is the coordinate, it would be small.
Effectively, yes.
PeroK said:
Effectively, yes.
Ok, so whenever I need to expand a potential for small oscillations, I just need the term with a linear ##x##?
After getting that ##U'(x)\approx U_0a^2x##, I replace that on the equation and get that ##F=-U_0a^2x## what do I do next? Do I need the harmonic oscillator equation?
That is the equation of SHM. ##F = -kx##, for some constant ##k##.
From that I have ##k=U_0a^2##, how do I use the constant to find the period?
You posted the relevant equation in your OP.
  • #31
##x''+\omega^{2}x=0##?
  • #32
Yes, and the other one.
  • #33
##T=2\pi/\omega##? One question, can't I just write ##F## as ##mx''## such that ##mx''=-U_0a^2x##? Thus ##x''=-\frac {U_0a^2}{m}x## and since ##x''+\omega^{2}x=0\Rightarrow x''=-\omega^2x## then ##\omega^2=\frac {U_0a^2}{m}##?
  • #34
Yes, that's the idea.
  • #35
And how do I get to that with the constant ##k##?
