Hydroelectric power plants question
In summary, the idea of using gravity to create an infinite source of energy is not possible. While it may seem like the orbiting water or rocks could continuously generate energy, the reality is that they would eventually slow down and fall back into the atmosphere, making it a finite source of energy. Additionally, discussions of perpetual motion and free energy are considered pseudoscience and are not allowed on this platform.
santiag0m
If we put a system that functions like the hydroelectric power plants do ( the gravity produces the movement of the water, producing electricity ) in vacuum and we put and object ( of a considerable mass ) that causes gravity and makes the "water" to orbit around it, wouldn't be a source of "infinite" electricity? ( i don't have clear if the gravity could be a source of infinite energy though)
No. The orbiting water will be be transferring its energy to the turbine blades, so its orbit will decay until ends up sitting still on the surface of your gravitating object.
What you're describing is somewhat similar to something that is done today: Position a turbine in such a way that the flow of the ocean tides will turn it, use that to generate electricity. The moon is orbiting the earth, its gravity is dragging the water around to create the tide, and it looks as if we getting infinite free energy from the orbiting moon. We aren't: the moon is actually losing a tiny bit of its kinetic energy in the process. Fortunately, it has plenty to spare :smile:
If I read you correctly, your question is, if we put a jet of water in orbit around a planet, could we use a paddle wheel or turbine to generate electricity forever?
And
"Can gravity be a source of infinite energy?"
Answering the second question first:
Gravity cannot be a source of infinite energy.
The largest amount of energy you can extract form a falling body would be the difference in the gravitational potential energy between the surface of the Earth, and infinitely far away above the Earth. This number can be big for massive falling objects, but it is still finite. You would need an infinite amount of falling objects to extract an infinite amount of energy.
As far as the second question goes:
If you were to use the momentum of the orbiting water to push a paddle wheel, that orbiting water would slow down (because the paddle wheel is pushing back on the water), and fall into a lower orbit. Eventually, if you keep using the paddle wheel, the water would slow down to the point where it will fall back into the atmosphere.One side point:
Liquid water can't exist in a vacuum since at those pressures, the boiling point is well below room temperature. However, one could still think about using a paddle wheel against orbiting streams of rocks, like the rings of Saturn.
While it may seem like a system that uses gravity to produce electricity in a vacuum would be a source of infinite energy, this is not the case. In order for a hydroelectric power plant to work, there needs to be a constant source of water flowing through the system. In the scenario described, the "water" is actually an object orbiting around the source of gravity. This means that the object would eventually run out of energy and stop orbiting, resulting in the system no longer producing electricity. Additionally, the amount of electricity produced would depend on the strength of the gravitational force and the mass of the object, which would not necessarily be enough to power an entire city or region. Ultimately, while gravity is a powerful force, it is not an infinite source of energy.
Related to Hydroelectric power plants question
What is a hydroelectric power plant?
A hydroelectric power plant is a facility that uses the energy of falling water to generate electricity. It typically consists of a dam, reservoir, and turbine that converts the potential energy of water into mechanical energy, which is then converted into electricity by a generator.
How do hydroelectric power plants work?
Hydroelectric power plants use the force of gravity to move water from a higher elevation to a lower elevation. This movement of water spins a turbine, which is connected to a generator that produces electricity. The water is then returned to its original source or released downstream.
What are the advantages of hydroelectric power plants?
Hydroelectric power plants have several advantages, including being a renewable source of energy, producing minimal air pollution, and providing a reliable and consistent source of electricity. They also have a long lifespan and can be used for multiple purposes, such as flood control and irrigation.
What are the disadvantages of hydroelectric power plants?
Some of the disadvantages of hydroelectric power plants include the high initial cost of construction, potential negative impacts on surrounding ecosystems, and the need for a suitable location with a reliable and consistent water source. Droughts and changes in water levels can also affect the efficiency of these plants.
What is the difference between a conventional and pumped-storage hydroelectric power plant?
A conventional hydroelectric power plant uses water from a natural source, such as a river, to generate electricity. In contrast, a pumped-storage hydroelectric power plant uses two reservoirs at different elevations to store and release water, allowing for greater control and flexibility in electricity production.
  • Electromagnetism
  • General Engineering
  • Electrical Engineering
