Hypergeometic function. Questions.
  • Thread starter LagrangeEuler
  • Tags
    Function
In summary, a hypergeometric function is a mathematical function that describes the relationship between three variables and is commonly used in statistics and applied mathematics. It differs from other functions in that it has a specific formula based on combinations of its variables and a defined convergence region. Its applications include modeling various situations and making predictions in fields such as physics, engineering, and economics. The main properties of hypergeometric functions include their convergence region, singularities, and special cases. They can be calculated and evaluated using different methods, such as expressing them in terms of simpler functions or using numerical methods.
LagrangeEuler
717
Legendre polynomial is defined as
##P_n(x)=_2F_1(-n,n+1;1,\frac{1-x}{2}) ##
Pochammer symbols are defined as ##(a)_n=\frac{\Gamma(a+n)}{\Gamma(a)}##. If I undestand well
[tex]P_n(x)=_2F_1(-n,n+1;1,\frac{1-x}{2}) =\sum^{\infty}_{k=0}\frac{(-n)_k(n+1)_k}{(1)_kk!}x^k [/tex]
I am not sure what happens with
[tex] (-n)_k=\frac{\Gamma(-n+k)}{\Gamma(-n)} [/tex]
because ##\Gamma## diverge for negative integers.
Even though ## \Gamma ## diverges for negative integers, the ratio of gamma functions evaluated at different integer arguments does not necessarily diverge. First, note that ## \Gamma(n) = (n-1)! ##. Now write out the terms as follows:
## \frac{\Gamma(-n+k)}{\Gamma(-n)} = \frac{(k-n-1)!}{(-n-1)!} = \frac{(k-n-1)(k-n-2)\cdots (k-n-(k-1))(k-n-k)(k-n-(k+1))\cdots }{(-n-1)(-n-2)(-n-3)\cdots}.##
Therefore, we have
## \frac{\Gamma(-n+k)}{\Gamma(-n)} = \frac{(k-n-1)(k-n-2)\cdots (-n+1)(-n)(-n-1)\cdots }{(-n-1)(-n-2)(-n-3)\cdots} = (k-n-1)(k-n-2)\cdots(-n+1)(-n)##,
and this last result is finite.
Can you clarify this for me?
Sure, I can try to clarify this for you. The Pochhammer symbol, also known as the rising factorial, is defined as (a)_n = a(a+1)(a+2)...(a+n-1). This definition holds for any real or complex number a, including negative integers. However, as you mentioned, the gamma function, which is used in the definition of the Pochhammer symbol, diverges for negative integers. This is because the gamma function is only defined for positive real numbers.
So, how do we deal with the Pochhammer symbol for negative integers? We use the reflection formula for the gamma function, which states that Γ(z)Γ(1-z) = π/sin(πz). This allows us to rewrite the Pochhammer symbol as (a)_n = Γ(a+n)/Γ(a) = Γ(a+n)Γ(1-a)/Γ(a) = π/(sin(πa)sin(π(1-a))...sin(π(1-a-n+1)).
Now, when we substitute this into the Legendre polynomial formula, we get P_n(x) = ∑(k=0 to ∞) (a)_k x^k = π/sin(πa)∑(k=0 to ∞)x^k sin(π(1-a-k)). This infinite sum can be simplified using the geometric series formula, and we end up with the final form of the Legendre polynomial: P_n(x) = π/(sin(πa)√(1-x^2)).
So, in summary, even though the gamma function diverges for negative integers, we can still use the reflection formula to define the Pochhammer symbol for negative integers and use it in the Legendre polynomial formula. I hope this helps clarify things for you!
Related to Hypergeometic function. Questions.
1. What is a hypergeometric function?
A hypergeometric function is a special type of mathematical function that is used to describe the relationship between three variables. It is defined as a series of terms that are based on combinations of these three variables, and it is commonly used in statistics and applied mathematics.
2. How is a hypergeometric function different from other types of mathematical functions?
Unlike other mathematical functions, a hypergeometric function has a specific formula that is based on combinations of its three variables. It also has a defined convergence region, which means that it only gives valid results within a certain range of values for its variables.
3. What are the applications of hypergeometric functions?
Hypergeometric functions are commonly used in statistics and applied mathematics to model various situations, such as drawing cards from a deck, selecting items from a population, or calculating probabilities in gambling games. They are also used in fields such as physics, engineering, and economics to model complex systems and make predictions.
4. What are the main properties of hypergeometric functions?
Some of the main properties of hypergeometric functions include their convergence region, which determines the range of values for which the function gives valid results, and their singularities, which are points where the function is undefined. They also have a number of special cases, such as the Gaussian hypergeometric function, which is commonly used in statistics.
5. How are hypergeometric functions calculated and evaluated?
There are various methods for calculating and evaluating hypergeometric functions, depending on the specific type and application. In some cases, the function can be expressed in terms of other, simpler functions, such as polynomials or trigonometric functions. In other cases, numerical methods or approximation techniques may be used to calculate the function's value.
  • Sticky
  • Topology and Analysis
  • Differential Equations
