Impact of Atmospheric Pressure on the Water in a Tank and a Pipe
In summary: If you blocked the top of the tube before you opened the "door" (valve) in the tank, then the pressure in the tube would be greater than atmospheric pressure and the water would not flow out.
tomtomtom1
160
TL;DR Summary
Impact of Atmospheric Pressure on Water in a Tank and Pipe
Hello all
I was hoping someone could help with understanding how fluids level out under atmospheric pressure. For example:-
Below is a picture of a tank of water with a closed door at the bottom, the door leads to an inclined pipe that is closed off at the end there is another pipe connected vertically.
I have drawn arrows in red to represent the atmospheric pressure which gets greater due to depth and I have drawn arrows in blue to represent the water pressure which also gets greater due to depth.
Now if i opened the green door and allowed the water to flow, but let's say for now the water did not rise up the tube then my diagram would look like:-
The question is why does the water rise up the tube and stop rising until the water in the tank and the water in the fluid are at the same level?
What i think is correct is that; as the water in the tank flows down into the pipe, the water level in the tank decreases which means that the force due to the pressure in the tank decreases but the atmosphere pressure in the tank increases.
But i am struggling to understand why the water would rise UP the tube when there is more atmospheric pressure pushing down?
Can anyone explain?
Thank you.
Is the water flowing out the pipe while this is going on, or is the water blocked at the lower end after the water fills the pipe?
The pipe is blocked at the lower end.
OK. So down low, right below the vertical tube, do you think that the water pressure is very high or do you think it is not very high? (For example, do you think that about 10 m below the water surface in a lake, the water pressure is much higher than near the surface, or not very high?)
I would say that it is high because the water flowing in from the tank is making it high.
That's the reason it rises into the vertical tube. The air pressure doesn't increase nearly as fast as water pressure with depth because air density is very low.
Likes tomtomtom1
The pressure at the bottom of the empty tube is greater than atmospheric pressure, by about 7 arrows. (Atmospheric pressure can be ignored because it is bearing on both the water in the tank and the water in the tube).
The additional pressure in the tube will push water up the tube and as the level in the tube goes up the pressure at the top of that water reduces due to the height and the pressures will tend to balance out. When the level in the tube is the same as the level in the tank you have equilibrium.
It is how water level sight glasses work. You could put one in your tube to measure the level of water in the tank.
https://inspectapedia.com/heat/Steam_Boiler_Sight_Glass.php
What would happen if you blocked the top of the tube before you opened the "door" (valve) in the tank?
Likes tomtomtom1
Related to Impact of Atmospheric Pressure on the Water in a Tank and a Pipe
1. How does atmospheric pressure affect the water level in a tank?
Atmospheric pressure is the force exerted by the weight of the air in the Earth's atmosphere. When the atmospheric pressure increases, it pushes down on the surface of the water in the tank, causing the water level to rise. Conversely, when the atmospheric pressure decreases, the water level in the tank will decrease as well.
2. What is the relationship between atmospheric pressure and the flow rate of water in a pipe?
The flow rate of water in a pipe is directly affected by the atmospheric pressure. As the atmospheric pressure increases, the pressure pushing the water through the pipe also increases, resulting in a higher flow rate. On the other hand, a decrease in atmospheric pressure will lead to a decrease in the flow rate of water in the pipe.
3. How does the height of a water column in a pipe change with varying atmospheric pressure?
The height of a water column in a pipe is directly proportional to the atmospheric pressure. This means that as the atmospheric pressure increases, the height of the water column in the pipe will also increase. Similarly, a decrease in atmospheric pressure will result in a decrease in the height of the water column in the pipe.
4. Can atmospheric pressure affect the pressure of water in a tank?
Yes, atmospheric pressure can have an impact on the pressure of water in a tank. As the atmospheric pressure increases, the pressure pushing down on the surface of the water in the tank also increases, resulting in an increase in the overall pressure of the water in the tank. This can be observed in a closed tank where the pressure of the air above the water will increase as the atmospheric pressure increases.
5. How does the temperature of the water in a tank or pipe affect the impact of atmospheric pressure?
The temperature of the water in a tank or pipe can also play a role in the impact of atmospheric pressure. As the temperature of the water increases, it expands and takes up more space, which can result in a decrease in the water level in a tank or a decrease in the flow rate in a pipe. This is because the increased volume of the water takes up more space and therefore decreases the height of the water column or the flow rate. However, the effect of temperature on atmospheric pressure is relatively small compared to other factors such as altitude and weather conditions.
  • General Engineering
  • Classical Physics
