International reference triple point
In summary, the triple point of water at 273.16K and atmospheric pressure is used as a reference point for measuring temperature. To make a thermometer, one should use a linear temperature scale and calibrate it by checking its measurement at 0K and the triple point of water. It is also helpful to measure other triple points to have additional reference points. As for resources on making a thermometer, a simple search engine query should provide helpful information.
Outrageous
374
I know the triple point of water is at 273.16K and atmospheric pressure
But how are we going to make it as a reference when we measure temperature of something?
Thank you
Simplified: Get a thermometer which is linear in temperature, check its measurement at (approximately) 0K and at the triple point, adjust the scale to get the correct values there.
It helps to measure other triple points, so they can be used as additional reference.
611Pa, or 0.006 times the atmospheric pressure.
So do you mean that between 0K and triple point is used to do temperature scale?
approximately to 0K mean we cool it as low as possible?
Do you have any link or reading source that explain to make thermometer?
Thank you
0K and the triple point of water are the fixed reference points for the temperature scale. They are used to fix the kelvin scale.
Search engines should find some.
for your question. The international reference triple point is a critical reference point for measuring temperature because it is a well-defined and reproducible state of matter. This means that at the triple point, water exists in a state where all three phases (solid, liquid, and gas) coexist in equilibrium, and the temperature and pressure are fixed. This allows for accurate and standardized measurements of temperature, as the triple point of water is a known and constant value. Additionally, the triple point of water is used as a reference point because it is easily reproducible and can be replicated in different laboratories, ensuring consistency in temperature measurements across different locations and experiments. Other substances, such as other gases and pure substances, also have their own triple points that can serve as reference points for temperature measurements in specific conditions. Overall, the international reference triple point is an important tool for precise and reliable temperature measurement in scientific research and industrial applications.
Related to International reference triple point
1. What is the international reference triple point?
The international reference triple point is a specific temperature and pressure at which the three phases of a substance (solid, liquid, and gas) coexist in equilibrium. It is used as a reference point for temperature measurement and is defined as 0.01 degree Celsius and 611.657 Pa (0.006036 atm).
2. Why is the international reference triple point important?
The international reference triple point is important because it provides a standard for temperature measurement that is independent of the properties of any particular substance. This allows for more accurate and consistent measurements across different laboratories and countries.
3. How is the international reference triple point determined?
The international reference triple point is determined by carefully measuring the temperature and pressure at which the three phases of a substance coexist in equilibrium. This is typically done using specialized equipment and techniques in a controlled laboratory setting.
4. What substances are commonly used for the international reference triple point?
The most commonly used substances for the international reference triple point are water, hydrogen, and nitrogen. Each of these substances has a well-defined triple point that can be reproduced reliably for temperature measurement.
5. How is the international reference triple point used in scientific research?
The international reference triple point is used in scientific research as a reference point for temperature measurement. It is also used in the calibration of thermometers and other temperature measuring devices. Additionally, the triple point of certain substances can provide important information about their physical properties and behavior under specific conditions.
  • Classical Physics
  • General Math
