Investment casting of complex shapes
In summary: The wax is melted and the parts are poured into the mold.The parts are then cooled and the wax is removed.The part with the most detail is the one with the most wax.In summary, Nidum explained that a complex wax pattern needs to be made from separate components that are then melt welded together. The advantage of this design is that a radial symmetry is taken advantage of which allows for the creation of identical parts that only need one or a small number of moulds. 3D printing can be used to create patterns that are complex and have a high quality finish, although post-processing is required.
GBA13
73
Hi guys,
I am learning about investment casting at the moment and have a question I would love someone to answer.
In investment casting a wax pattern needs to be created. How would that be made for a complex shape like an impeller? I've heard that lots of impellers are created using investment casting but can't work out how an impeller pattern could be economically (both time and money) in wax.
Could anyone shed some light on it?
Thanks!
Complex wax patterns were traditionally made from separate components melt welded together .
Individual components would be made in moulds . Usually metal moulds for precision engineering work and rubber moulds for lower precision and ornamental work .
In case of an impellor advantage would be taken of the radial symmetry of the design and the separate components would be made identical so only one or a small number of moulds would be needed .
In modern times complex patterns are often 3D printed in one piece .
Hi Nidum,
Thanks for your reply! That's very helpful. For the 3D printing of patterns, would that not give a fairly poor surface finish which would need to be smoothed before casting? Also what sort of materials are used in printing? Do people print patterns in wax?
Thanks very much
There is a huge range of quality in 3D printing - and they do make wax filament for exactly this purpose. Still - for high quality finish the critical dimensions are probably machined. Impellers and also be sintered metal or forged - depending on the application.
Funny story - I had a client when I was in robotics that had a foundry. The owner could not use email, but his foundry was using robots - old ones that needed cool, clean air for the robot controllers. He had this foundry air conditioned to keep the robots runnng- cracked me up every time I went there,...
For each casting made, a wax model must be destroyed.
The wax models can be injection molded in a many-part mold that can be quickly cooled.
Related to Investment casting of complex shapes
1. What is investment casting and how is it used to create complex shapes?
Investment casting, also known as lost-wax casting, is a manufacturing process used to create intricate and complex shapes for metal parts. It involves creating a wax pattern of the desired shape, coating it in a ceramic shell, and then melting away the wax to leave a cavity. Molten metal is then poured into the cavity to create the final shape.
2. How does investment casting compare to other casting methods for creating complex shapes?
Investment casting offers several advantages over other casting methods when it comes to creating complex shapes. It allows for finer detail and tighter tolerances, as well as the ability to cast multiple parts at once. It also produces a smoother surface finish and can accommodate a wider range of materials.
3. What types of materials can be used in investment casting for complex shapes?
Investment casting can be used with a variety of materials, including ferrous and non-ferrous metals, as well as alloys such as steel, aluminum, bronze, and titanium. It can also be used with some non-metallic materials, such as glass and certain plastics.
4. What industries commonly use investment casting for complex shapes?
Investment casting is widely used in industries such as aerospace, automotive, medical, and jewelry. It is also commonly used for creating parts for musical instruments, firearms, and other high-precision applications where complex shapes are required.
5. What are the main considerations when designing for investment casting of complex shapes?
When designing for investment casting, it is important to consider factors such as draft angles, wall thickness, and the location of gates and risers to ensure a successful casting process. It is also important to consider the material properties and any post-casting processes that may be required.
  • Other Physics Topics
  • General Discussion
  • STEM Career Guidance
  • Computing and Technology
