- #36
- 21,790
- 13,003
The OP is working on manifolds though. There may be no such thing as a Cartesian basis.stevendaryl said:Or, if you know what the relationship is between your basis vectors eμ and a set of local Cartesian basis
When in doubt, just always write down the parantheses in place.Orodruin said:To me this is one of those cases where practicality trumps cumbersome notation. I can agree that there is no a priori clear indication as to if ##\nabla_\nu V^\mu## means ##(\nabla_\nu V)^\mu## or ##\nabla_\nu(V^\mu)##. However, we already have the notation ##\partial_\nu V^\mu## for ##\nabla_\nu (V^\mu)## so we do not really need another one. With this in mind, the notation is pretty consistent. As for the basis ##e_\mu##, the connection coefficient would be most easily expressed as ##\nabla_\mu e_\nu = \Gamma_{\mu\nu}^\lambda e_\lambda## - I don't really see a problem with this. Alternatively, ##\Gamma_{\mu\nu}^\lambda = e^\lambda(\nabla_\mu e_\nu)##, where ##e^\lambda## is the dual basis. The only notational rule is that when you have an expression of the form ##\nabla_\nu T^{\ldots}_{\ldots}##, the indices represented by ##\ldots## refer to the additional indices of the expression ##\nabla_\nu T##, i.e., it is understood as ##(\nabla_\nu T)_\ldots^\ldots##. I do not really see any possible misinterpretation here.
Regardless, I think this entire discussion is distracting from the OP's inquiry. It should perhaps be moved to a thread of its own?
Orodruin said:The OP is working on manifolds though. There may be no such thing as a Cartesian basis.
This is fine and usually how I introduce my own students to covariant derivatives. However, the differences in the manifold case need to be pointed out. I have seen too many examples if what happens to some students that somehow miss that part.stevendaryl said:Yes, but it seems that understanding covariant derivatives in flat space using non-Cartesian coordinates is good practice for understanding the case of curved space.
To me is clear that covariant derivative operator ##\nabla## is actually an operator and not a tensor itself -- I believe it could be better to use ##\nabla()## for it. The argument inside the brackets () is a tensor field thus if we "pass" it a vector field ##X## it actually returns a (1,1) tensor.PeterDonis said:The covariant derivative operator takes any (p, q) tensor and produces a (p, q + 1) tensor. The directional derivative operator is not formed by "fixing " on ; it's formed by contracting with , i.e., it's the operator . This operator takes a (p, q) tensor and produces another (p, q) tensor.
cianfa72 said:covariant derivative operator ##\nabla## is actually an operator and not a tensor itself
Well, yes and no. On the one hand it is true that the object as such is a (p,q+1) tensor. On the other hand the usual notation makes it clearer which index is which.PeterDonis said:As you note, it makes more sense to put the indexes on the entire expression ∇V instead of on the ∇ and the V separately.
Orodruin said:the usual notation makes it clearer which index is which.
Of course there is. If not all tensors would be symmetric. In the particular case of this operator, the singled out argument is that for which the operator becomes a directional derivative when taking an argument.PeterDonis said:But there is no "which index is which";
Orodruin said:Of course there is. If not all tensors would be symmetric.
Orodruin said:In the particular case of this operator, the singled out argument is that for which the operator becomes a directional derivative when taking an argument.
PeterDonis said:But there is no "which index is which"; that's the point.
PeterDonis said:I don't understand.
PeterDonis said:Yes, that's correct; the common notation ##\nabla_\mu## is really a shorthand for saying that ##\nabla## is an operator that takes a (p, q) tensor and produces a (p, q + 1) tensor, i.e., it "adds" one lower index. As you note, it makes more sense to put the indexes on the entire expression ##\nabla V## instead of on the ##\nabla## and the ##V## separately.
stevendaryl said:I don’t understand what is wrong with considering ##\nabla_\mu V## to be a vector.
stevendaryl said:##\nabla_\mu## makes perfect sense as an operator on vectors
stevendaryl said:a new vector with components
##\partial_\mu V^\nu + \Gamma^\nu_{\mu \lambda} V^\lambda##
PeterDonis said:That isn't a vector, it's a (1, 1) tensor. It has two free indexes, one upper and one lower.
PeterDonis said:If by ##\nabla_\mu V## you mean ##\left( e_\mu \right)^\mu \nabla_\mu V## (which shows the abuse of notation involved in confusing "which vector" indexes with component indexes), then, yes, that's a vector. I just don't think that's what the notation ##\nabla_\mu## usually means.
If by ##\nabla_\mu V## you mean ##\nabla_\mu V^\nu##.
etotheipi said:Just my humble opinion, I think we're really going round in circles here getting bogged down in semantics. Something of the form ##\nabla_{\mu} V^{\nu}## can be completely justifiably viewed as either a (1,1) tensor, or a (1,0) tensor [vector], depending on the context.
The (p,q+1) tensor is a linear map that takes p+q+1 arguments (p dual vectors and q+1 vectors) to real numbers.PeterDonis said:I don't understand how the term "argument"
stevendaryl said:My feeling is that it should never be considered a tensor or a vector, but should be considered components of a tensor or a vector. That's what I consider confusing about physics notation is that they don't distinguish carefully between a vector and a component of a vector, and they don't distinguish between a function and the value of a function at a point.
etotheipi said:Yes sorry, I agree; I was just using the sloppy physicist's parlance that you mentioned right now
[Only exception is if we're using Penrose's abstract indices, in which case ##\nabla_{a} V^{b}## does refer to the abstract tensor itself.]
stevendaryl said:Yes, I understand Penrose abstract indices, but sometimes you want to talk about a component of a vector. Then you have to do something like ##(V^b)^\mu##, which is very weird looking.
stevendaryl said:This is something that drives me crazy about physics notation, which is that the notation doesn't distinguish between a vector and a component of a vector, and doesn't distinguish between a tensor and a component of a tensor.
If ##U## and ##V## are vectors, then ##\nabla_U V## is another vector.
stevendaryl said:it's NOT a tensor, it's a vector.
stevendaryl said:Look, if instead of ##\mu##, I used "x",
etotheipi said:It's just notation!
PeterDonis said:Yes, but since there are multiple different, contradictory conventions for notation, and since it's often not clear which convention a particular person is using, it's at least worth trying to describe the different conventions and have some debate about their pros and cons.
etotheipi said:I actually think it's quite nice.
PeterDonis said:We've already been around this merry-go-round once. I'm sorry, but I simply don't see the point of trying to gerrymander the interpretation of individual indexes of the same kind on expressions the way you are doing.
To me, the whole point of having indexes on expressions is to denote what kind of object the thing is.
Then you would be writing a different expression, which at least would give some indication that you intended the ##x## index to mean something different from the other ones (although even then the "directional derivative" interpretation is not the one that I would intuitively assign, nor, I think, would most physics readers--we would intuitively think you mean the ##x## component of the 1, 1 tensor).
pervect said:The only difference between index notation and abstract index notation is that if we require a specific basis (for instance, a coordinate basis), then we use greek letters in the subscripts and superscripts as a warning of this requirement.
stevendaryl said:If ##V^\nu## does not mean a component of vector ##V##
stevendaryl said:I think you're defending a convention that causes no end of confusion.
stevendaryl said:Doesn't calling it a ##(1,1)## tensor already indicate that?
stevendaryl said:You keep making a distinction where there is no distinction.
stevendaryl said:I think that the two sides can be reconciled if people do always use roman letters for abstract indices, and use greek letters for concrete indices.
PeterDonis said:It does. That's not the issue.
The issue is that, while you're fine with using the Greek index ##\nu## to indicate a component, you insist on using the Greek index ##\mu## to indicate something else, like a directional derivative.
No, you keep ignoring the fact that the double meaning you are trying to get away with only works if you are using a coordinate basis. We've already been around this merry-go-round as well.
stevendaryl said:##\nabla_\mu V^\nu## is, for a particular choice of ##\mu## and ##\nu##, just a number.
stevendaryl said:The index tells you which one.
stevendaryl said:How does it depend on a coordinate basis?
