- #36
pbuk
- 2,926
Yes but that is trivial, what @Office_Shredder was asking is more interesting: 1060 * ? + 980 * ? = ?Feynstein100 said:1020 * 0.5 + 980 * 0.5 = 1000
Eh idk. In the end it should still come out to 1000. 1060 may be a higher value but it's less likely to happen than 980. These two factors balance each other out and the result is still 1000.pbuk said:Yes but that is trivial, what @Office_Shredder was asking is more interesting: 1060 * ? + 980 * ? = ?
@BWVHornbein said:The expected value is not a function of standard deviation.
We are trying to solve for the probability ratio. I do not know if @Office_Shredder has a particular approach in mind, but here is how I would attack it.Feynstein100 said:Eh idk. In the end it should still come out to 1000. 1060 may be a higher value but it's less likely to happen than 980. These two factors balance each other out and the result is still 1000.
Oh.....kay? Don't get me wrong. That was quite interesting but I was kinda expecting a cheat or a workaround of some kind As it stands, we're right where we started. Conservation of expectation value shall not be violated.jbriggs444 said:We are trying to solve for the probability ratio. I do not know if @Office_Shredder has a particular approach in mind, but here is how I would attack it.
Let ##p## be the probability of first hitting 980. Then ##1-p## is the probability of first hitting 1060. We are in an infinite random walk (as I recall), so the probability of never hitting either is obviously zero.
We know that the mean of the infinite random walk needs to be 1000 because that is the starting point and every step is unbiased. So we write down an equation: ##980 p + 1060(1-p) = 1000##
Now we just have to solve for p. Easy algebra. Then write down the ratio in the form ##p:1-p##.
If intuition serves, we should find that the sides of the ratio are in inverse proportion to each side's deviation from the mean. The deviations are 20:60 so the probability ratio will be 3:1.
[It feels like there should be some more directly compelling algebra if I'd made a better choice of variables. But I will not change horses mid-stream]
Let us see whether the algebra bears this out...
##980p + 1060 (1-p) = 1000##
##(980 - 1060)p + 1060 = 1000##
##-80p = -60##
##p = \frac{3}{4}##
##1-p = \frac{1}{4}##
Ratio = 3:1
Bingo.
Right. Re-read #31. @Office_Shredder is not trying to prove conservation of expected value. He is trying to use the principle of conservation of expected value to reach a conclusion about the probability of hitting the stop points.Feynstein100 said:Oh.....kay? Don't get me wrong. That was quite interesting but I was kinda expecting a cheat or a workaround of some kind As it stands, we're right where we started. Conservation of expectation value shall not be violated.
Ah okay. It's more nuanced than I'd anticipated. Btw the equations don't tell us how they change when we use a stop-loss to change sigma. I mean, I kind of discovered it empirically from my python code but is there a way to see it happen mathematically? A proof or something? Idk. I tried to read the proof of the optional stopping theorem but it was beyond me. Way too abstract lol.Office_Shredder said:This is a general statement that if you want to compute the standard deviation, you have to subtract the mean out. This is actually what prevents them from usually being related - if you adjust the mean by adding some quantity to every outcome, that doesn't affect the standard deviation at all.
Oh. My bad. I thought we were trying to find a workaround/loopholejbriggs444 said:Right. Re-read #31. @Office_Shredder is not trying to prove conservation of expected value. He is trying to use the principle of conservation of expected value to reach a conclusion about the probability of hitting the stop points.
There are none unless you decide to allow shenanigans such as unbounded bets. e.g. a Martingale scheme. There was a reference upthread to a relevant theorem.Feynstein100 said:Oh. My bad. I thought we were trying to find a workaround/loophole
If you want to see where the variance influence the mean, change the payoff to + or - 10% of the previous value then compare to another where it is + or - 50% (does not change the mean but the expectation relates to the difference between the mean and median: at + or - 50% you almost surely will go broke if you play long enough even though the expected gain/loss is zeroFeynstein100 said:@BWV
Turns out, there's more to this. I took this from Wikipedia:
Here, mu is the mean/expected value. So while mu isn't a function of sigma, the two do interact with each other. It's just that when you change sigma, you also change the probability and the resulting data points, in just such a way that mu remains unchanged. My hunch was correct, in a sense
Sorry I didn't get that. Could you explain it again?BWV said:Is conservation of expected value is just another way of stating the process is a Martingale - defined as E(T1)=E(Tn) for all n. Not every process would have this attribute
Does this wiki page make it any more clear?Feynstein100 said:Sorry I didn't get that. Could you explain it again?
@jbriggs444Office_Shredder said:The average profit should not be higher @FactChecker the graph they put in the original post is a terrible way of visualizing what is going on.
Thanks for the recommendations. I'll check them out. However, I don't see any problem with playing around. There's really no substitute for firsthand experience. For instance, if I hadn't messed around with this, I wouldn't have learned that stop-losses and take-profits don't change the expected value. I can't help but wonder what profound implications that might have for daytrading. But then again, is the stock market inherently probabilistic? I'm inclined to think not. And even if it were, it has a net positive expectation value over time. How does that affect our simulation? Is the simulation even applicable? Those are the kinds of questions that interest me.pbuk said:Rather than play around with this, do you think it would be a good idea to learn about probability and statistics in a more structured way? This would prevent you wasting time going down blind alleys, help you focus on what is important, and perhaps also introduce you to even more interesting problems.
You could look at this open course which covers the material touched on in this post:
https://ocw.mit.edu/courses/18-440-probability-and-random-variables-spring-2014/
Or for a more general introduction to probablity and statistics try here:
https://ocw.mit.edu/courses/18-05-introduction-to-probability-and-statistics-spring-2014/
Feynstein100 said:Thanks for the recommendations. I'll check them out. However, I don't see any problem with playing around. There's really no substitute for firsthand experience. For instance, if I hadn't messed around with this, I wouldn't have learned that stop-losses and take-profits don't change the expected value. I can't help but wonder what profound implications that might have for daytrading. But then again, is the stock market inherently probabilistic? I'm inclined to think not. And even if it were, it has a net positive expectation value over time. How does that affect our simulation? Is the simulation even applicable? Those are the kinds of questions that interest me.
I don't know what that means But based on personal experience, stop-losses do seem to make a difference in daytrading. How can we explain that?Office_Shredder said:giving the stock positive drift
You could try following the advice I gave a few days ago.Feynstein100 said:I don't know what that means But based on personal experience, stop-losses do seem to make a difference in daytrading. How can we explain that?
pbuk said:@Feynstein100 you don't need to do any maths to see that the stop loss does not change the expected value if returns are symmetrical, you just need to look at the symmetry. Think about the expected value of the investments you sell at 980.
Once you have thought this through, see if you can predict what a stop loss will do in a rising market, then run a simulation.
Maybe your personal experience is not reliable?Feynstein100 said:I don't know what that means But based on personal experience, stop-losses do seem to make a difference in daytrading. How can we explain that?
Yeah I didn't find that helpful at all. I mean, the whole reason I posted here is because based on the symmetry, I anticipated an increasing expected value then couldn't figure out why that wasn't true.pbuk said:You could try following the advice I gave a few days ago.
Define bull vs bear market - how do you know which state you are in until after the fact?Feynstein100 said:Yeah I didn't find that helpful at all. I mean, the whole reason I posted here is because based on the symmetry, I anticipated an increasing expected value then couldn't figure out why that wasn't true.
I have no idea what a stop-loss would do in a bull market. I expect it to not even be relevant because if the market is indeed ascending then the stop-loss shouldn't even be triggered. That's kind of the point, isn't it? In a bull market, a stop-loss is basically non-existent. In a bear market, the stop-loss minimizes your losses. Looks good on paper but how does it fare in reality?
Well, you don't. That's kind of why we're doing all this? If you knew beforehand whether you were going to get a heads or tails, you wouldn't have to worry about the probabilities now, would you?BWV said:Define bull vs bear market - how do you know which state you are in until after the fact?
A rising market is not a negative sum game.jbriggs444 said:But it is a negative sum game. Somebody has to lose.
No we don't have perfect knowledge, so we make assumptions, build a model, make predictions using the model, and test them. This is science.Feynstein100 said:Well, you don't. That's kind of why we're doing all this? If you knew beforehand whether you were going to get a heads or tails, you wouldn't have to worry about the probabilities now, would you?
outperforming a rising market is zero sum before fees and expenses, negative sum afterpbuk said:A rising market is not a negative sum game.
But the game we are discussing here is the market itself (which by definition when rising is positive sum before fees and expenses), not outperformance of the market.BWV said:outperforming a rising market is zero sum before fees and expenses, negative sum after
With daytrading, it is.pbuk said:A rising market is not a negative sum game
That sounds interesting. Would you care to elaborate?jbriggs444 said:With daytrading, it is.
Every time you make a trade, some money rubs off. Trade often enough and the amount of money that rubs off will exceed any reasonable ROI that would accrue from a "buy and hold" strategy.Feynstein100 said:That sounds interesting. Would you care to elaborate?
I don't think that applies to commission-free trading we have these daysjbriggs444 said:Every time you make a trade, some money rubs off. Trade often enough and the amount of money that rubs off will exceed any reasonable ROI that would accrue from a "buy and hold" strategy.
Google bid/ask spreadFeynstein100 said:I don't think that applies to commission-free trading we have these days
No, I know what that is. Unless you're a high-frequency trader, it doesn't really make much of a difference from what I know.BWV said:Google bid/ask spread
