Is there always the same amount of spacetime curvature in the uni.?
In summary, Peter says that if matter and energy cannot be created or destroyed, and since they are what causes spacetime to curve, then there will always be the same amount of spacetime curvature in the universe. However, he is not sure that what you mean by "amount of spacetime curvature" matches up well with anything in the actual physics. He thinks the answer to your question is "no", but he also thinks you should clarify more precisely what you mean by "amount of spacetime curvature". One way to clarify would be to explain how you would measure it.
49ers2013Champ
31
Is there always the same "amount" of spacetime curvature in the uni.?
Universe is what I meant by uni.
Okay, if matter and energy cannot be created or destroyed, and since they are what causes spacetime to curve, does that mean there will always be the same amount of spacetime curvature occurring in the universe?
I understand that large marterial bodies curve spacetime more than the small ones, but regardless of their size or distribution, is there always the same amount of gravity occurring in the universe?
I am sure "amount" is probably not the best word, but I think you will understand what I'm asking.
Not really; more precisely, I'm not sure that what you mean by "amount of spacetime curvature" matches up well with anything in the actual physics. I think the answer to your question is "no", but I also think you should clarify more precisely what you mean by "amount of spacetime curvature". One good way to clarify would be to explain how you would measure it.
I suspect that you actually mean the curvature of the universe itself, at any given instant of time, and not the curvature of the space-time that models the universe's entire temporal history (extending backwards to the big bang of course). The sectional curvature of the universe itself is a constant ##k##, and can be either ##k = 1,-1,## or ##0## depending on what model you choose. Current experimental evidence hints towards something close to ##k = 0##.
As far as space-time curvature goes, there are various different curvature quantities one can look at. The Ricci scalar curvature of the FRW space-time for example is given by ##R = 6(\frac{\ddot{a}}{a} + \frac{\dot{a}^{2}}{a^{2}})## where ##a = a(\tau)## is the scale factor thus, as you can see, ##R## is a function of the cosmic time ##\tau##.
Yes, Wannabe. That's what I'm asking. Great answer. I'm going to read your answer a few more times to make sure it sinks in.
Peter, wait a minute. Wouldn't you agree that the sun curves spacetime more than "fill in the blank"? That's what I meant by amount. And so I'm saying, if the overall amount of energy and matter in the universe remains constant, regardless of its density or distribution in space, does that mean that there is always the same overall--or cumulative--"amount" of spacetime curvature, or, as Wannabe pointed out, curvature of the universe?
It depends on what fills in the blank. The Sun curves spacetime more than the Moon (for an appropriate definition of "the amount of curvature"--which you still haven't given), but less than the white dwarf Sirius B, for example.
As I just noted, you haven't really given any more information here. How would you measure "amount of spacetime curvature"?
If the universe is spatially infinite, which is what our current best-fit model says, then the overall amount of energy and matter in it is also infinite. Are you taking that into account?
No. Spacetime curvature certainly depends on density.
Probably not, but that's a guess. In general stuff evolves with time. wannabe gives one example...Physically, some things wethink we know :
intergalactic large scale distances are expanding,
Galaxies continue to form from primordial gases,
Stars continue to be born while others die,
Supernovas come and go,
black holes likely continue to evolve and grow bigger for a long long time,
our observable portion of the universe is expected to eventually be dark,cold,black,
the cosmological constant is interpreted as a fixed vacuum energy density as 'space' ...expands
...etc
on the other hand, nobody knows much yet about dark matter and dark energy...some 95% of matter/energy...
Well you get the idea: lots going on as the universe evolves...
wannabe shows one measure of curvature related to the scale factor, a basic measure of cosmological distance. That scale factor is based on the assumption of an isotropic and homogeneous universe...an FLRW model of the universe...so it remains valid even as the above physical factors I listed evolve...there are other measures of curvature within the EFE and the λCDM cosmological model.
One last thought: Leonard Susskind says of every 1010 bits of information in the universe, all but one lie within black holes...Do we understand the implications if that is roughly accurate?
Related to Is there always the same amount of spacetime curvature in the uni.?
1. What is spacetime curvature?
Spacetime curvature refers to the bending of the fabric of space and time caused by the presence of massive objects. It is a fundamental concept in Einstein's theory of general relativity.
2. Is spacetime curvature constant throughout the universe?
No, spacetime curvature is not constant throughout the universe. It varies based on the distribution of matter and energy in different regions of the universe.
3. How is spacetime curvature measured?
Spacetime curvature is measured using the curvature tensor, which is a mathematical quantity that describes the curvature of spacetime at a given point. This measurement is typically done through observations of the effects of gravity on objects.
4. Can spacetime curvature change over time?
Yes, spacetime curvature can change over time. This is because the distribution of matter and energy in the universe is constantly changing, leading to fluctuations in the curvature of spacetime.
5. What are the implications of varying spacetime curvature?
The varying spacetime curvature has significant implications for the behavior of objects in the universe. It affects the paths of objects in space and the rate at which time passes, among other things. Understanding the variations in spacetime curvature is crucial for studying the evolution and dynamics of the universe.
