Isolated points must be boundary points?
In summary, the textbook defines an isolated point as a point that is not in any open set, and a boundary point as a point that is in at least one open set. This definition is most practical for working with R^n, as any isolated point is a boundary point when working with R^n. However, this definition does not work for metric spaces, as there can be isolated points that are not boundary points.
Bipolarity
776
In the textbook I am working with, an isolated point of A is defined to be a point X in A such that there exists a neighborhood (open ε-ball) centered on X containing no point in A other than X itself.
A boundary point of A (which need not be in A) is defined as a point X in A such that every open ε-ball centered on X contains at least one point in A and at least one point not in A.
Is it the case that isolated points must be boundary points? Most textbooks use definitions other than the one I'm using, hence I am very confused.
Also, maybe this is true for metric spaces but not for topological spaces?
BiP
That is how I first saw these concepts defined, and are probably the most practical definitions when dealing with R^n. Isolated points are indeed boundary points when working with R^n.
A quick way to see that isolated points need not be boundary points is to take any non-empty set, X, and equip it with the discrete topology (all subsets are open). Then for any subset A of X, all points of A are isolated but A has no boundary points (since singletons are open in the discrete topology).
This can also fail for metric spaces, which can be seen by considering the integers with the metric topology. The metric topology is the discrete topology in this case, hence the above argument holds.
I see. But on the standard Euclidean space with Euclidean metric, it is true? What is the most general metric space for which this is true?
BiP
Yes. Let ##A\subset ℝ^n##, and let ##x\in A## be an isolated point of A. By definition of isolated point, there is some ##r>0## s.t. ##B(x,r)\cap A = \{x\}##. Given any ##ε>0##, ##x\in B(x,ε)\Rightarrow B(x,ε)\cap A≠∅##. Moreover, ##B(x,r)\cap A = \{x\}\Rightarrow x+(\frac{1}{2}min\{ε,r\}, 0,..., 0) \in A^c\Rightarrow B(x,ε)\cap A^c≠∅##. We've shown that ##B(x,ε)\cap A≠∅## and ##B(x,ε)\cap A^c≠∅##, by definition this shows that ##x## is a boundary point of A. Thus any isolated point of A is a boundary point of A.
This property holds in a metric space if and only if the metric space does not have any isolated points to begin with. A topological space as a whole does not have any boundary points, so the condition clearly fails if we have an isolated point. Conversely, if we have a metric space ##X## s.t. there is a subset ##A\subset X## and a point ##x\in A## which is an isolated point but not a boundary point, then we can show that x must be an isolated point of ##X## (sketch: x isolated in A => no points of A are nearby, x not a boundary pt. of A=> no points of A^c are nearby, hence no points of X are nearby).
The other common way to define the boundary of A is to let it be the points in the closure of A that are not in the interior of A, where the closure is defined as the intersection of all closed sets containing A, and the interior is defined as the union of all open sets contained in A. Starting with the definition of boundary that you have been using, you can alternatively define the interior of A to be the set A with boundary points removed. There are other ways to define these concepts, but they all end up being equivalent in the end.
: Thank you for your question. The answer to whether isolated points must be boundary points depends on the definitions used and the context in which they are being applied. In the textbook you are using, an isolated point is defined as a point in A that has a neighborhood containing only itself. On the other hand, a boundary point is defined as a point in A that has a neighborhood containing both points in A and points not in A.
Based on these definitions, it is not necessarily true that isolated points must be boundary points. This is because an isolated point can exist in a neighborhood that contains only itself, while a boundary point must exist in a neighborhood that contains both points in A and points not in A.
However, in some other contexts or definitions, it may be possible for an isolated point to also be a boundary point. For example, in a metric space, an isolated point can also be a boundary point if it is the only point in its ε-ball.
Furthermore, the definitions and concepts of isolated and boundary points may vary in different mathematical contexts, such as in topological spaces. Therefore, it is important to carefully consider the definitions being used and the context in which they are being applied in order to determine if isolated points must necessarily be boundary points.
Related to Isolated points must be boundary points?
1. What is an isolated point?
An isolated point is a point in a set that does not have any other points in its immediate vicinity. This means that it is not surrounded by any other points in the set and is considered to be "alone."
2. How do you determine if a point is an isolated point?
To determine if a point is an isolated point, you can visualize the set and look for any points that do not have any other points close to them. You can also use the definition of an isolated point, which states that it must not have any other points in its immediate vicinity.
3. Can an isolated point also be a boundary point?
Yes, an isolated point can also be a boundary point. This is because a boundary point is defined as a point that belongs to both the set and its complement. Since an isolated point does not have any other points in its vicinity, it can be considered a boundary point for both the set and its complement.
4. Is every isolated point a boundary point?
No, not every isolated point is a boundary point. While an isolated point can be a boundary point, it is not a requirement for all isolated points. An isolated point can also be an interior point, which means it only belongs to the set and not its complement.
5. Why is it important for isolated points to be boundary points?
It is important for isolated points to be boundary points because they help define the boundaries of a set. This can be useful in mathematical analysis and topology, as it allows us to better understand the structure and properties of a set. Additionally, isolated points being boundary points can also have practical applications, such as in computer graphics and image processing.
  • Topology and Analysis
