Jackson Classical Electrodynamics: page 35 expansion of charge
In summary, the conversation discusses the calculation of the Taylor distribution of charge at the end of section 1.7 in Jackson's book. It is concluded that this distribution can be obtained through a second order Taylor series expansion, where first order terms integrate to zero due to the even integrand. The conversation also touches on the meaning of O notation and the evaluation of integrals using spherical coordinates. Ultimately, it is agreed that Jackson's conclusion is correct and is based on a formal proof of the important formula for the Green's function.
qnach
142
Could anyone explain how did Jackson obtain the Taylor distribution of charge distribution at the end of section 1.7 (version 3)?
Without verifying it in detail, I believe it may be a second order Taylor series expansion, where first order terms ## \nabla \rho(x) \cdot (x-x') ## will integrate to zero because of the even integrand, and similarly for the second order mixed partials. @vanhees71 Is this assessment correct?
Edit: Note: I'm getting a factor of ## \frac{1}{2} ##, instead of ## \frac{1}{6} ## on the ## \nabla^2 ## term. See Perhaps it is because of the spherical symmetry, and the ## (\frac{\partial^2 \rho}{\partial x^2}) ## term gets a factor of ## (x-x_o)^2 ##, etc. With ## (\frac{\partial^2 \rho}{\partial x^2}) (x-x_o)^2=(\nabla^2 \rho) r^2/3 ##, (when integrated, etc., along a single direction ##dr ##), it may then be a ## \frac{1}{6} ##, (edit=I'm handwaving here). Note also the ## 4 \pi r^2 ## factor, that canceled the ## 4 \pi ## out front in the denominator. It's covered up with tape, but I think it is then ## r^2 \, dr ##.
Likes qnach
The print isn't real clear, but I worked the next step. (The exponent in the denominator is ## \frac{5}{2} ##. It looks like ## \frac{3}{2} ##, but correctly it should be ## \frac{5}{2} ##).
## \int\limits_{0}^{+\infty} \frac{3 a^2 r^2}{(r^2+a^2)^{5/2}} \, dr ## can be readily solved by letting ## r=a \tan{\theta} ##.
To resolve the handwaving in post 2, ## \nabla^2 \rho =(\frac{\partial^2{\rho}}{\partial{x^2}}) + ## y and z second partial terms at ## \vec{x} ##, so that ## \nabla^2 \rho =3 (\frac{\partial^2{\rho}}{\partial{x^2}}) ## at ## \vec{x} ##. This ## \nabla^2 ## term is a constant when integrating over dr. It also is useful to look at the integrals of ## \int x^2 \, d^3 r ## vs. ## \int r^2 \, d^3 r ##, etc. Upon working through all the details, I agree with his ## \frac{1}{6} ##.
Likes etotheipi, vanhees71 and qnach
Could anyone please explain the meaning of the last term of the second last equation in this page.
What does O(a^2,a^2 log a) mean? The O notation contains only one term inside the bracket.
But this guy has two inside.
I think that's correct though I find the conclusion by Jackson a bit too quick, but after some detailed analysis, I think it's correct too.
What's behind it is a formal proof of the very important formula
$$-\Delta_x G(\vec{x},\vec{x}')=-\Delta_x \frac{1}{4 \pi |\vec{x}-\vec{x}'|}=\delta^{(3)}(\vec{x}-\vec{x}').$$
The standard proof is to integrate a test function in the sense of distributions
$$\phi(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 x' G(\vec{x},\vec{x}') \rho(\vec{x}')$$
and then show that indeed
$$-\Delta \phi(\vec{x})=\rho(\vec{x}).$$
The integral is evaluated by integrating not over ##\mathbb{R}^3##, because of the singularity of the Green's function at ##\vec{x}'=\vec{x}## but to leave out a little spherical ball or radius ##\epsilon## around the singular point ##\vec{x}## and then taking the limit ##\epsilon \rightarrow 0##, using the fact that
$$\Delta_x G(\vec{x},\vec{x}')=\Delta_{x'} G(\vec{x},\vec{x}')=0 \quad \text{for} \quad \vec{x}' \neq \vec{x}.$$
Jackson provides the proof in a different way, i.e., he regularized the Green's function and then takes the weak limit.
The advantage is that the original integral over entire ##\mathbb{R}^3## is well defined to begin with, and
$$\Delta \phi_a(\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \Delta_x G_a(\vec{x},\vec{x}') \rho(\vec{x}')$$
is well defined.
Now he wants to show that for ##a \rightarrow 0## this integral goes to ##-\rho(\vec{x})##. The first observation is that the only contribution can come from an arbitrarily little region around ##\vec{x}'=\vec{x}##, i.a., for taking the limit you can just evaluate the integral over a sphere of radius ##R## around ##\vec{x}##, because for the rest of the integral you can exchange the limit with the integral, giving ##0##.
So he sets ##\vec{x}'=\vec{x}+\vec{r}## with ##\vec{r}=\vec{x}'-\vec{x}##. Now
$$\Delta G_a(\vec{x},\vec{x}')=-\frac{3 a^2}{(r^2+a^2)^{5/2}}.$$
So the integral is
$$I(\vec{r})=-3 a^2\int_{K_R} \mathrm{d}^3 r \frac{1}{(r^2+a^2)^{5/2}} \rho(\vec{x}+\vec{r}),$$
where ##K_R## is the solid sphere of radius ##R## around the origin ##\vec{r}=0##. Next Jackson expands ##\rho## around ##\vec{r}=0##. Formally
$$\rho(\vec{x}+\vec{r})=\exp(\vec{r} \cdot \vec{\nabla}) \rho(\vec{x}).$$
Now all you need is to evaluate the integrals
$$I_{j_1,\ldots,j_k}=-3 a^2\int_{K_R} \mathrm{d}^3 r \frac{1}{(r^2+a^2)^{5/2}} r_{j_1} \cdots r_{j_k}.$$
Of course one introduces spherical coordinates for ##\vec{r}## to do the integral. Fortunately all that's interesting here is the integral over ##r=|\vec{r}|##. We don't need the complicated integration over the angles for all ##k##. So let's only do the ##r## integral:
$$I_k=-3a^2 \int_0^R \mathrm{d} r \frac{r^{k+2}}{(r^2+a^2)^{5/2}}.$$
Substitution of ##r=a \sinh \lambda## leads to
$$I_k=-3a^k \int_0^{\mathrm{arsinh(R/a)}} \mathrm{d} \lambda \frac{\sinh^{k+2} \lambda}{\cosh^4 \lambda}.$$
Now the integrand is increasing for ##k \geq 4##, i.e., for these ##k##
$$|I_k| \leq \frac{3 a^2 R^{k+2}}{(a^2+R^2)^2}\mathrm{arsinh}(R/a) \rightarrow 0 \quad \text{for} \quad a \rightarrow 0.$$
So we need only the cases ##k=0## and ##k=1##, for which
$$I_0=-\frac{R^3}{(a^2+R^2)^{3/2}} \rightarrow -1 \quad \text{for} \quad a \rightarrow 0$$
and
$$I_1=a \left (-2+\frac{a(2a^2+3R^2)}{(a^2+R^2)^{3/2}} \right) \rightarrow 0 \quad \text{for} \quad a \rightarrow 0.$$
So the only contribution is for ##k=0##, and together with the integral over the angles, which gives ##4 \pi## indeed leads to
$$\lim_{a \rightarrow 0} \Delta \phi_a(\vec{x})=-\rho(\vec{x}),$$
as claimed.
Likes etotheipi and Charles Link
That's the Landauer big-O symbol. It tells you how in some limit of a variable a function behaves. In this case it's the limit ##a \rightarrow 0##, and
$$f(a)=\mathcal{O(a^2,a^2 \ln a)}$$
means that
$$f(a)=A a^2 + B a^2 \ln a$$
with some constants ##A## and ##B##. My lengthy calculation shows that this is correct since
$$\mathrm{arsinh}(R/a)=\ln[R/a+\sqrt{1+(R/a)^2}] \simeq \ln(2 R/a)=-\ln(a/R)+\ln 2.$$
Related to Jackson Classical Electrodynamics: page 35 expansion of charge
1. What is the expansion of charge on page 35 of Jackson Classical Electrodynamics?
The expansion of charge on page 35 of Jackson Classical Electrodynamics refers to the mathematical representation of a charge distribution using a series of point charges. This is known as the multipole expansion and is used to simplify the calculation of electric and magnetic fields.
2. Why is the expansion of charge important in classical electrodynamics?
The expansion of charge is important because it allows us to approximate complex charge distributions with simpler point charge distributions. This makes it easier to calculate the electric and magnetic fields, which are crucial in understanding the behavior of electromagnetic waves and particles.
3. How is the expansion of charge related to the concept of multipole moments?
The expansion of charge is closely related to the concept of multipole moments. Each term in the expansion represents a different multipole moment, which is a measure of the distribution of charge in an object. The higher the order of the multipole moment, the more complex the charge distribution is.
4. Can the expansion of charge be used for any type of charge distribution?
Yes, the expansion of charge can be used for any type of charge distribution, as long as it is well-behaved and can be represented as a continuous function. However, for highly irregular charge distributions, the accuracy of the expansion may be limited and higher order terms may be needed.
5. Is the expansion of charge a theoretical concept or is it used in practical applications?
The expansion of charge is both a theoretical concept and a practical tool. It is an important part of classical electrodynamics theory and is used to understand the behavior of electromagnetic fields. It is also used in practical applications such as antenna design, where the multipole expansion is used to model the radiation pattern of an antenna.
  • Electromagnetism
  • Quantum Interpretations and Foundations
  • Electromagnetism
  • Science and Math Textbooks
