Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
  • #13,511
tsutsuji said:
25 June 2012 government-Tokyo Electric mid and long term response committee, steering committee (7th meeting)
3-1 Cooling by closed loop water injection
http://www.meti.go.jp/earthquake/nuclear/pdf/120625/120625_02g.pdf Unit 2 alternative thermometers installation progress status
1) Previous related topics:
1 March 2012 report ( https://www.physicsforums.com/showpost.php?p=3795578&postcount=12465 part 1, https://www.physicsforums.com/showpost.php?p=3796935&postcount=12485 part 2, https://www.physicsforums.com/showpost.php?p=3799356&postcount=12492 part 3)
tsutsuji said:
28 March 2012 government-Tokyo Electric mid and long term response committee, steering committee (4th meeting)
http://www.meti.go.jp/earthquake/nuclear/pdf/120328_02f.pdf page 7 is about the revision of priorities for installation of alternative thermometers. The high radiation routes are cancelled. What is left is Jet Pump system B X-40C/D in area B with priority 1, SLC differential pressure sensor X-51 in area C with priority 2, and TIP in area D as priority (1) with a note. The note says: "there is a possibility that the TIP guide tubes are surviving in the outer surroundings of the core (see page 8). →If undamaged TIP guide tubes are left, they can be promoted to priority 1." The figure in the left part of page 8 shows a yellow area where surviving TIP tubes are believed to exist.
23 April 2012 report: https://www.physicsforums.com/showthread.php?p=3939578#post3939578 (insertion and freezing mock-ups)
28 May 2012 government-Tokyo Electric mid and long term response committee, steering committee (6th meeting): https://www.physicsforums.com/showt...ighlight=alternative+thermometers#post3941037 Results of the surveys on location concerning the environment improvement for the purpose of installing alternative thermometers in unit 2's RPV
01 June 2012 videos:
http://photo.tepco.co.jp/en/date/2012/201206-e/120601_02e.html "Decontamination around the truck bay door at Unit 2, Fukushima Daiichi NPS" (released on 1 June 2012)
http://photo.tepco.co.jp/en/date/2012/201206-e/120601_01e.html "Mock-up test to check the insertability of the alternative thermometer at Unit 2" (released on 1 June 2012)
2) Translation:
01/12
02/12
03/12
  • #13,512
Translation:
04/12
05/12
06/12
  • #13,513
Translation:
07/12
08/12
09/12
  • #13,514
Translation:
10/12
11/12
12/12
  • #13,515
Unit 4 top is almost clean now:
  • #13,516
Your image link isn't working for me but you can see the image here, and click it to see a higher resolution version:
http://enformable.com/2012/07/photo-of-the-week-fukushima-daiichi-reactor-4-building-debris-removal/
The removable concrete cap sections are visible in their storage positions under the yellow containment cap and to the south of it.
Some of the groundwork preparing the foundations for the fuel removal structure are partially visible south of the building.
  • #13,519
  • #13,520
a.ua. said:
Analyses of core melt and re-melt in the Fukushima Daiichi nuclear reactors
http://www.tandfonline.com/doi/full/10.1080/18811248.2011.636537
Thats a rather interesting study.
To look at something other than the later core remelt possibilities for a moment, I am rather interested in the reports suggestion that unlike reactors 1 & 3, the initial core melting at reactor 2 didn't result in a runaway zirconium-steam reaction, due to a lack of steam generation in the core.
This would certainly be an interesting alternative explanation as to why there was no hydrogen explosion at reactor 2. But I haven't quite got my head around the reasons this report thinks such a reaction did not occur. Could someone take a look at the report and attempt to explain this to me?
Many thanks.
  • #13,521
Many thanks.
Look at this part "3.3.1. Core boil-off process and meltdown into lower plenum"
  • #13,522
Tanabe's core remelting theories were first mentioned on Physics Forum on https://www.physicsforums.com/showpost.php?p=3443421&postcount=10864 (August 2011)
This was before Tepco revised its flow rate data for unit 3 http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110909_06-e.pdf (September 2011). See https://www.physicsforums.com/showpost.php?p=3494451&postcount=11193
I wonder why http://www.tandfonline.com/doi/full/10.1080/18811248.2011.636537 published in January 2012 is still using the older data in its "Figure 19:Injection water flow rate in comparison with MDHRFR in 1F-3".
  • #13,523
But it use also some other data (temp and pressure).
  • #13,524
Perhaps due to the close timing collision between Tepco's publishing of revised flow estimates, and the finalising of this particular article; it was received on 11 August 2011 and the final version was accepted for publication on 16 September 2011.
  • #13,525
Tsunami photo sequence released June 9th
A photo sequence of the March 11th tsunami hitting Daiichi, recent released at:
http://photo.tepco.co.jp/date/2012/201207-j/120709_01j.html
  • #13,526
The following is a version of the recent helicopter footage. Can see how far they have progressed with platform to east and south of reactor 3 at a few moments in the footage.
Sorry I couldn't find the original version of this video.
  • #13,527
Thank you, Steve. I think I've found the progenitor of that version, it is a published snippet of a video taken by a Kyodo News helicopter on July 5th 2012:
http://www.youtube.com/watch?v=-FgXPX5iYC4&feature=plcp
  • #13,528
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120710/index.html Tepco released 33 new pictures of the tsunami in response to the Diet investigation commission pointing out the existence of unreleased pictures. The picture were taken by a contractor company employee who was within the plant premises. Among the pictures taken before the tsunami arrival, one can see the white spray of the rising wave while it approaches, and a tanker seeking refuge by getting out of the port. The pictures taken after the tsunami arrival show the violent muddy stream, a large container being carried away by the stream and these pictures let one know again about the violence of the tsunami. Then, we see employees who had taken refuge on a roof who are worryingly looking at the stream. Tepco had released 17 Fukushima Daiichi tsunami pictures in May 2011, but the present pictures had not been released until the Diet investigation commission pointed them out. Tepco said:"Among the taken pictures, we selected for public release those that are the easiest for understanding how the tsunami came. We would like to apologize for the insufficient points in provision of information".
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120706/index.html The Diet's investigation commission report contains up to now unreleased transcripts of plant manager Yoshida's testimony where he says "the line of command was a mess" and contains his criticism of the interference by the Prime Minister's Office. Yoshida said: "If the Main Office had said "stop" [injecting seawater], that would be debatable, but there was no such instruction at all. A phone call came from supporting role Prime Minister's Office: what is this stop thing? As it is on phone, it is difficult to discuss. The line of command was a mess. I thought that in the end I would decide by my own judgement". [Also quoted by http://www.yomiuri.co.jp/dy/national/T120706003982.htm (English) and http://mainichi.jp/english/english/newsselect/news/20120706p2a00m0na010000c.html (English)]
  • #13,529
Reactor 3 torus room survey robot, which had sound monitoring equipment to listen for running water, got stuck and hasnt been retrieved. 360 mSv/h measured at side of the northern torus access hatch, 230 mSv/h in location where robot is stuck:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120712_03-e.pdf
Some photos of upper levels of reactor 3, but quality is poor. Some of the images have some signs of interlacing lines, which suggests to me that its from a video, but no video has been released.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120711_03-e.pdf
http://photo.tepco.co.jp/en/date/2012/201207-e/120711_02e.html
Images released as part of the announcement of completion of reactor 4 upper level debris removal, but they are all taken from unhelpful angles. Helicopter footage we've already seen was better than this stuff.
http://photo.tepco.co.jp/en/date/2012/201207-e/120711_01e.html
  • #13,530
TEPCO to release footage of video conferences
http://www3.nhk.or.jp/daily/english/20120712_15.html
  • #13,531
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120713/index.html No conspicuous damage was observed except the fact that the south-western door is broken.
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120713/0400_4gk.html The NISA approved the plan to retrieve 2 fresh fuel assemblies from unit 4 pool. The assemblies will be pulled with 4 wires. The operation will be controlled with the help of an underwater camera, and radiation measurement tools. The NISA said these safety measures are "appropriate". As a security measure concerning radioactive substances, Tepco will not announce the date beforehand.
http://www.meti.go.jp/press/2012/07/20120712003/20120712003.html NISA approval for unit 4 fresh fuel assembly removal
http://www.meti.go.jp/press/2012/07/20120712003/20120712003-3.pdf Figure 2 at the bottom of the page shows the rafter crane on the platform above the reactor well with two hooks. Figure 4 is the tool that will be used for inspecting the fuel at the common pool. This inspection is scheduled during the last ten days of August. Normally the radiation on the surface of the fresh fuel is 25 microsievert/hour.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120712_05-e.pdf Unit 2 RPV Alternative Thermometer: SLC Pipe Soundness Confirmation.
Why isn't the pipe already filled with water from the RPV ? Is there a check valve or something preventing water from flowing downwards ?
At 10:35, "no more water could be injected from that point". Why not ? What is preventing the water from pouring into the RPV ?
Does this result (soundness of SLC instrumentation pipe is confirmed) mean that the core is not as badly melted as could be thought ? It sounds like at least that pipe did not melt.
  • #13,532
Thanks for for continuing reporting efforts tsutsuji.
As Tepco says, the amount of water injected into the pipe and the retention of pressure point to a blocked pipe. The 15L injected was way less than the (as-designed) volume of the pipe, 33L. So there is potentially crud in the pipe, perhaps corrosion products, and these are blocking the pipe. It's also possible that the pipe has distorted (by heat or mechanical impact) which could block and reduce volume, or that the RPV internal section of the pipe has been penetrated and blocked by corium; or a combination.
The "result" is that the SLC pipe is not currently usable as a thermometer insertion route. Exactly why is not yet determined.
  • #13,533
Thanks Joffan. I was perplexed by this "soundess is confirmed" conclusion in the Tepco handout.
http://genpatsu-watch.blogspot.fr/2012/07/20127131800.html [transcript of July 13's press conference] Junichi Matsumoto:
"Normally, it is thought that the injected volume obtained from the pipe's length and diameter is 33 litres. Of course, in the hypothesis where the pipe is open up to the RPV, we presumed that water would go on entering even after filling 33 litres of water, but the situation in yesterday's soundness check is that injection becomes impossible at around 15 litres, and after the water filling was stopped, we observed the pressure decline status.
Today, when we checked at around 10:00, it was about 100 kPa as shown above. Well, as it was not the water head value of 68 kPa or 56 kPa measured by the water elevation when the extremity is open, we are suspecting that the pipe is somehow clogged.
Therefore, about anything special that we could say about this pressure, well, we understood that probably it is clogged, and we want to check the status of this clogging.
Also, checking methods are currently under study, but as we had been carrying out the preparations for alternative thermometer insertion, at present we are checking if we could not look inside the pipe using an industrial endoscope with that method".
  • #13,534
tsutsuji said:
Thanks Joffan. I was perplexed by this "soundness is confirmed" conclusion in the Tepco handout.
Me too, but I can speculate that, as the pipe did hold a very considerable pressure for a long time, in one sense it is "sound" in that it is probably not leaking to the PCV. Or perhaps - you would know better than me - it's a mistranslation of the idea that the the soundness has been confirmed... bad.
  • #13,535
That's right. It was a mistranslation.
計装配管の健全性を確認 should have been translated as "checking instrumentation pipe soundess" or "we shall check instrumentation pipe soundness".
There is a second handout on the same topic dated July 13: www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120713_04-e.pdf
  • #13,536
  • #13,538
Andres Arce said:
Does anybody know what that underwater tarpac is for ?
(at 01.22)
http://www.dailymotion.com/video/xs8r32_yyyyyyyyy-yyyyyyyy_news
Hello there Andres Arce. I believe this particular sequence of that video is from the May 26th tour to the top floor of unit 4. The camera appears to be looking into the cutaway in the southwest corner of the general floating plastic construction which composed the covering of the pool at that time. The cutaway gives access to the water surface of the pool. I think this cutaway is where water is circulated in and out of the pool and perhaps where e.g temperature sensors are interfaced. I am not sure what exactly we are seeing underwater, but since the general covering is there to protect from something falling into the pool, it would make sense to me that a similar protection has been put underwater in the cutaway in order to catch objects that might fall into the pool during operations there.
  • #13,539
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120719/index.html On 19 July at around 06:00 AM, Tepco took the second fresh fuel assembly out of unit 4 pool and put it into a special transportation container. There was not any trouble so far.
[I'm unsure if the fuel assemblies are still on the 5th floor or if they have already taken them away to the common pool]
  • #13,541
Apparently the rods were slightly contaminated, but nothing dramatic.
  • #13,542
  • #13,543
Fukushima contractor covers up worker exposure
http://www3.nhk.or.jp/daily/english/20120721_23.html
  • #13,544
http://icanps.go.jp/post-2.html Cabinet investigation committee final report (Japanese)
http://icanps.go.jp/eng/SaishyuRecommendation.pdf Final report recommendations (English)
  • #13,545
Asahi also covers it:
http://ajw.asahi.com/article/0311disaster/fukushima/AJ201207210069
Disgraceful, to say the least. Lack of oversight.
  • Nuclear Engineering
46K
51
420K
17K
260K
15K
11K
