Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
  • #13,686
SteveElbows said:
I'm not sure what that building is for, but looking at the high quality aerial images from early on, its the building that is directly west of the shared reactor 3/4 stack tower.
EDIT: that would be the switching area, according to this:
http://files.abovetopsecret.com/images/member/f9037506eaef.gif
The large pipe is the broken part of reactor 3 vent pipe that got plenty of attention at the time due to showing up so clearly on the same set of aerial photos.
So, yes. thanks, I was not sure. What a clean break, by the way! The bolts sheared and the whole thing just fell off. I wonder how hot it is.
EVEN LATER EDIT: here's another big pipe segment:
http://photo.tepco.co.jp/library/20120911_40/120911_590.jpg
from here
http://photo.tepco.co.jp/date/2012/201209-j/120911-40j.html
SOME MORE PIXEL-HUNTING LATER:
would this
http://photo.tepco.co.jp/library/20120911_39/120911_522.jpg
be the very same switching area? There is debris on the floor, apparently concrete from Unit 3 blowing up.
  • #13,687
SteveElbows said:
Meanwhile I see they have now removed the reactor cap from the reactor 4 refuelling floor, just like they did with the containment cap:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120913_03-e.pdf
I can be wrong but those big concrete pieces under the 'landed' cap looks like the top concrete shielding of the reactor well.
Ps.:
That will be a different pipe, not part of the venting system. You can see it's connections on this photo: http://photo.tepco.co.jp/library/20120911_40/120911_593.jpg
  • #13,688
LATER EDIT: are you sure it is not the entrance corridor to unit 3? Because otherwise, what blew up in there?
It traces of tsunami.
  • #13,689
No it is not, there is no silt. But upon looking more carefully, it appears that junk from the explosion hit it pretty hard. Some of it made it inside.
  • #13,690
zapperzero said:
<snip>
I'm not 100% sure but it's likely that the joints in the vent pipe are not bolted together as such, the joints have to allow for expansion so it's more like a "slip joint" hence the clean seperation.
zapperzero said:
Is that pipe the vertical stack that was attached to the exterior NW corner of [STRIKE]U3 [/STRIKE] U4 perhaps (edit cheers Steve, I should have checked)
would this
EDIT : I'm having a bad day - my mistake - answer should have been no, different building - that interior shot is the Units 1 & 2 UHV switch building. Up on the hill west of Units 1 & 2
impacted by U3 explosion.
  • #13,691
westfield said:
Is that pipe the vertical stack that was attached to the exterior NW corner of U3 perhaps
Yes, but reactor 4 not reactor 3.
  • #13,692
No visible tsunami damage to that building. The corner that is opened up is actually closer to unit 4. The images are not the best but it seems there might be more displaced cladding post U4 explosion.
After Tsunami, then after U3 explosion , finally after U4 explosion
  • #13,693
Yep. Thanks. You are of course referring to the concrete "cladding" of the switching building, yes?
  • #13,694
I was looking at the sheet steel cladding that's come off that U3 & 4 HV switch building and is laying on the ground around it. The images are not great but I thought there may be more of the wall cladding laying around after the U4 explosion vs before. Difficult to say either way...looking for something more interesting in that bunch of unreleased images now.
  • #13,695
Unit 2 transformer yard - oil level is a little on the low side
  • #13,696
tsutsuji said:
]27 August 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (8th meeting) ( http://www.meti.go.jp/earthquake/nuclear/20120827_02.html )
Document 2
http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_02c.pdf Progress status of development of machinery and equipments to prepare fuel debris removal
https://www.physicsforums.com/showthread.php?p=4064974&posted=1#post4064974 Translation [installment 1: abstract]
https://www.physicsforums.com/showthread.php?p=4068601&posted=1#post4068601 Translation [installment 2: remote decontamination]
https://www.physicsforums.com/showthread.php?p=4069889&posted=1#post4069889 Translation [installment 3: PCV leakage points identification]
https://www.physicsforums.com/showthread.php?p=4071111&posted=1#post4071111 Translation [installment 4: PCV repairs]
Translation [installment 5: surveys inside PCV]
17/34 1/3
17/34 2/3
17/34 3/3
  • #13,697
18/34
19/34 1/2
  • #13,698
19/34 2/2
20/34
  • #13,699
Document 2
https://www.physicsforums.com/showthread.php?p=4073726&posted=1#post4073726 Translation [installment 5: surveys inside PCV]
Translation [installment 6: RPV/PCV integrity assessment]
21/34 1/3
21/34 2/3
21/34 3/3
  • #13,700
22/34
23/34
  • #13,701
24/34
25/34
  • #13,702
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120914/1345_chusuiryo.html On 13 September Tepco said the injection rate problem had been solved, but the injection rate declined again on 14 September (a 10% decline at unit 1 from 09:00 PM on 13 September to 01:00 AM on 14 September, and a decline from 01:00 AM to 07:00 AM at unit 2). In both caes the needed rates were secured. As a countermeasure, Tepco is increasing the injection rates. Tepco suspects foreign bodies are remaining in the pipes.
  • #13,703
Guess it is not easy to put in a strainer just before the pipes enter the reactor when everything is seriously contaminated.
  • #13,704
Document 2
https://www.physicsforums.com/showthread.php?p=4076720&posted=1#post4076720 Translation [installment 6: RPV/PCV integrity assessment]
Translation [installment 7: open competitive biddings]
27/34
28/34
29/34
  • #13,705
30/34
31/34
32/34
  • #13,706
33/34
34/34
  • #13,707
Additional information about the long term research and development effort is included in the presentations from the 7 August "workshop on machinery and equipments toward the decommissioning of Fukushima Daiichi NPP" held in Koriyama city: http://www.meti.go.jp/earthquake/nuclear/20120810_01.html
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01b.pdf Program
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01c.pdf Presentation (1) Middle and long term roadmap and research and development
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01d.pdf Presentation (2) Fukushima Daiichi general situation
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01e.pdf Presentation (3) Practical use of technical catalogue public appeal results
Session 1:
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01f.pdf Development of remote decontamination techniques inside buildings
Session 2:
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01g.pdf Development of PCV leakage points identification techniques
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01h.pdf Development of PCV repair techniques
http://www.meti.go.jp/earthquake/nuclear/pdf/120810/120810_01j.pdf Development of PCV internal survey techniques
  • #13,709
Interesting paper describing the use of muons to image the core of Fukushima Daiichi Reactor #1:
Cosmic Ray Radiography of the Damaged Cores of the Fukushima Reactors.
Konstantin Borozdin, et al.; Physical Review Letters, September 12, 2012
http://arxiv.org/pdf/1209.2761v1.pdf
The paper describes simulations, and concludes that it is feasible.
Azby
  • #13,710
The simulations they did were about imaging an in-vessel melt. I wonder if/how this would work with the core being dug into the concrete at the bottom of the drywell, as simulations show it probably is.
  • #13,711
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120922/index.html A little after 11:00 AM on 22 September, a 470 kg heavy steel frame fell into unit 3's spent fuel pool. That steel frame was located on the south-eastern pool side, and it was hit by the tip of a crane during debris removal work. The fallen frame's dimensions are 0.2 m x 0.3 m x 7 m. There is no variation of surrounding air radiations or radioactive substance concentrations in pool water. Pool cooling is going on. Tepco says they will use an underwater camera to check if there is any fuel damage. The NISA is checking if any procedure or management mistake was done.
http://www.tepco.co.jp/en/news/topics/1220971_2266.html English press release on that event
http://www.tepco.co.jp/en/news/topics/1220972_2266.html Cs concentrations in pool water
  • #13,712
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120926/index.html Investigating with underwater camera into unit 3 spent fuel pool after the steel frame falling event, Tepco found other steel frame objects inside the pool, which are believed to have fallen during the hydrogen explosion. The underwater inspection started on 24 September, and by now around one eighth of the pool has been investigated and 3 steel frame pieces were found. One of them is immediately near a fuel rack. Tepco has not identified the piece that fell on 22 September, and believes the pieces found underwater are parts of the roof that fell during the hydrogen explosion. Having in mind that some fuel could be damaged, while radioactive substance concentrations and water level remain stable, the investigation is going on.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120925_01-e.pdf "Investigation of the Inside of Unit 3 Spent Fuel Pool Using an Underwater Camera at Fukushima Daiichi Nuclear Power Station"
http://photo.tepco.co.jp/en/date/2012/201209-e/120924-02e.html Steel frame falling video etc.
http://photo.tepco.co.jp/en/date/2012/201209-e/120925-01e.html underwater camera videos
  • #13,713
Funny how this stuff was of no interest whatsoever until the new agency told them to do it.
  • #13,714
http://www3.nhk.or.jp/news/html/20120926/k10015285931000.html
  • #13,716
There's water in there, which is good. Can't really tell, but I think I see convection. Maybe just compression artifacts though.
At 25 minutes in, they lose the feed and there is actual "snow" which makes me wonder once again, for the nth time, why in the name of Pete don't they use fiber optics instead of those el-cheapo CCTV cameras.
  • #13,718
According to water condensation visible in penetration and chamber fixture there probably was at least some moisture in the containment atmosphere.
Could visible "steaming" and condensation have been caused by (possibly relatively cold) nitrogen gas injection?
But, why didn it rain cats and dogs inside containment?
Is this good or bad?
  • #13,719
  • #13,720
Astronuc said:
Karlsruher Institut für Technologie - Tracking developments at Fukushima since the earthquake and tsunami
http://www.kit.edu/besuchen/6042.php
http://www.kit.edu/visit/pi_2011_6054.php - summary in English
Much of it is in German, but there may some good records and some in English.
Erdbeben/Tsunami in Japan – Folgen für die nuklearen Anlagen in Fukushima
Unfortunately the latest update is from March.
  • Nuclear Engineering
46K
51
420K
17K
260K
15K
11K
