Least Desirable hydration product in concrete
In summary, the least desirable hydration product in concrete is calcium hydroxide, also known as portlandite. This product can negatively affect the properties of concrete, such as increasing porosity and decreasing strength. Factors such as the type and amount of cement, water-cement ratio, and curing conditions contribute to its formation. While it cannot be completely removed, the use of pozzolanic materials, proper curing techniques, and sealers can help reduce its presence. There are also alternative hydration products, such as fly ash and slag, that can improve the strength and durability of concrete.
physicsss
319
I'm debating between ettringite and calcium hydroxide...ettringite is responsible for expansion in volume during a sulfate attack while calcium hydroxide affects the durability of concrete...any ideas?
Both ettringite and calcium hydroxide can have negative effects on the durability of concrete, but if I had to choose the least desirable hydration product, I would go with ettringite. While calcium hydroxide can lead to increased porosity and decreased strength in concrete, ettringite can cause even more significant issues such as expansion and cracking during a sulfate attack. This can greatly compromise the structural integrity of the concrete and potentially lead to costly repairs or replacements. In contrast, the impact of calcium hydroxide can be mitigated through proper mix design and curing techniques. However, both hydration products should be carefully monitored and controlled in order to ensure the overall durability of concrete.
Related to Least Desirable hydration product in concrete
1. What is the least desirable hydration product in concrete?
The least desirable hydration product in concrete is calcium hydroxide, also known as portlandite. This product is formed during the hydration process of cement and can cause issues such as efflorescence and low strength in concrete.
2. How does calcium hydroxide affect the properties of concrete?
Calcium hydroxide can have a negative impact on the properties of concrete. It can increase porosity, decrease strength, and cause cracking and efflorescence. It is also less durable and can lead to a shorter lifespan for concrete structures.
3. What factors contribute to the formation of calcium hydroxide in concrete?
The formation of calcium hydroxide in concrete is influenced by a few factors such as the type and amount of cement used, the water-cement ratio, and the curing conditions. Higher amounts of cement and higher water-cement ratios can lead to increased formation of calcium hydroxide.
4. Can calcium hydroxide be removed from concrete?
While it is not possible to completely remove calcium hydroxide from concrete, there are some methods that can help reduce its presence. These include using pozzolanic materials in the concrete mix, proper curing techniques, and the use of sealers to prevent moisture from entering the concrete and causing the formation of calcium hydroxide.
5. Are there any alternative hydration products that are more desirable for concrete?
Yes, there are alternative hydration products that are more desirable for concrete. These include pozzolanic materials like fly ash and slag, which can react with calcium hydroxide to form additional cementitious compounds and improve the strength and durability of concrete. Other alternatives include using supplementary cementitious materials like silica fume and metakaolin, which can also reduce the formation of calcium hydroxide in concrete.
  • Mechanical Engineering
  • Chemistry
  • DIY Projects
