Loop-and-allied QG bibliography
In summary, Rovelli's program for loop gravity involves coupling the standard model to quantized QG loops, allowing for interactions between eigenvalues of length and momentum. This approach allows for non-perturbative calculations without infinity problems and does not require a continuum limit. The main difference in loop gravity is that the excitations of space are represented by polymers, or ball-and-stick models, that can be labeled with numbers to determine the volume and area of any region or surface. This allows for a more intuitive understanding of the geometry of the universe.
  • #2,101
http://arxiv.org/abs/1312.7273
On How Neutrino Protects the Axion
Gia Dvali, Sarah Folkerts, Andre Franca
(Submitted on 27 Dec 2013)
We show how the neutrino can sacrifice itself to quantum gravity and save the axion solution to the strong-CP problem. This mechanism puts an upper bound on the lightest neutrino mass.
9 pages
[my comment on the paper's significance is to quote its conclusion section]
==excerpt==
In this work we have put forward yet another example of the highly profound connection between particle physics and non-perturbative quantum gravity. The main players in this connection are the axion and the neutrino.
Quantum gravity is believed to violate global symmetries, and among other things, ruin the axion solution of the strong-CP problem. ...By identifying the source of the danger, we were able to see the possible protection mechanism against it. This mechanism is built-in in the Standard Model in form of light neutrinos. ...This mechanism gives a phenomenological bound on the neutrino mass. The precise measurement of this mass would reveal a bound on non-perturbative gravity scale.
==endquote==
in case anyone is following GFT and Rivasseau's tensor track program:
http://arxiv.org/abs/1312.7226
The Multiscale Loop Vertex Expansion
Razvan Gurau, Vincent Rivasseau
The loop vertex expansion (LVE) is a constructive technique which uses only canonical combinatorial tools and no space-time dependent lattices. It works for quantum field theories without renormalization. Renormalization requires scale analysis. In this paper we provide an enlarged formalism which we call the multiscale loop vertex expansion (MLVE). We test it on what is probably the simplest quantum field theory which requires some kind of renormalization, namely a combinatorial model of the vector type with quartic interaction and a propagator which mimicks the power counting of ϕ42. An ordinary LVE would fail to treat even this simplest superrenormalizable model, but we show how to perform the ultraviolet limit and prove its analyticity in the Borel summability domain of the model with the MLVE.
20 pages
  • #2,102
http://arxiv.org/abs/arXiv:1312.7747
Lorentz Spin-Foam with Non Unitary Representations by use of Holomorphic Peter-Weyl Theorem
Leonid Perlov
(Submitted on 30 Dec 2013)
We use the non-unitary spinor representations of SL(2,C) and the recently proved Holomorphic Peter-Weyl theorem to define the Hilbert space based on the holomorphic spin-networks, the non-unitary spin-foam, solve the simplicity constraints and calculate the vertex amplitude. The diagonal simplicity constraint provides two solutions. The first solution: Immirzi γ=i with the irreducible representations (j1,j2) projected to (0,j) and the second solution: Immirzi γ=−i and the irreducible non-unitary representations projected to (j,0). The off-diagonal constraint selects only the first of these two solutions. The solution is interesting in two aspects: a) it turns to be a topological BF model. b) Immirzi parameter γ=i corresponds to Ashtekar's self-dual connection of the complexified algebra sl(2,C)⊗C. The transition amplitude is finite and very similar to BF Euclidean model. We discuss the inner product Lorentz invariance and the viability of the non-unitary representations in the Loop Quantum Gravity (LQG) models. We also discuss the unitary versus non-unitary evolution as a consequence of the Schrödinger equation in classical quantum mechanics versus Wheeler-DeWitt equation in GR. We address the problem of a quantum measurement in the end.
14 pages
possibly of general interest:
http://arxiv.org/abs/1312.7454
Adaptive Coarse Graining, Environment, Strong Decoherence, and Quasiclassical Realms
Murray Gell-Mann, James B. Hartle
(Submitted on 28 Dec 2013)
Three ideas are introduced that when brought together characterize the realistic quasiclassical realms of our quantum universe as particular kinds of sets of alternative coarse-grained histories defined by quasiclassical variables: (1) Branch dependent adaptive coarse grainings that can be close to maximally refined and can simplify calculation. (2) Narrative coarse grainings that describe how features of the universe change over time and allow the construction of an environment. (3) A notion of strong decoherence that characterizes realistic mechanisms of decoherence.
11 pages
[Comment: a classical spacetime is used, so this is something of a "toy model" paper. One of a series by Gell-Mann and Hartle over the years, addressing the (somewhat philosophical) problems of applying QM to the cosmos as a whole.]
  • #2,103
http://arxiv.org/abs/1312.7797
Quantum indeterminacy in local measurement of cosmic expansion
Craig J. Hogan
For a system of two small bodies in an expanding universe, bounds on mass and separation are estimated, from standard gravity and quantum mechanics, such that both their gravity and the process of quantum measurement affect their motion less than the cosmic expansion does. It is shown that such a direct local measurement of cosmic expansion or acceleration at rate H is only possible, even in principle, in a region of size greater than H −3/5 in Planck units, or about 60 meters in the current universe, a new scale that defines a boundary between quantum and classical expansion. A generalization to spatially extended linear density perturbations shows the same scale. Matching vacuum energy or directional information in localized field states to gravity on this system length scale yields a particle mass scale of H 3/10 , or about 7 GeV today. Possible connections of cosmic acceleration with the QCD vacuum are discussed.
http://arxiv.org/abs/1312.7798
Directional Entanglement of Quantum Fields with Quantum Geometry
Craig J. Hogan
Using transversely localized solutions of the relativistic wave equation, the path of a massless particle with wavelength λ that travels a distance z is shown to have a wave function with indeterminacy in direction given by the diffraction scale, ⟨Δθ 2 ⟩>2 √ λ/πz . It is conjectured that the spatial structure of quantum field states is influenced by quantum directional indeterminacy of geometry set by the Planck length, l P . Entanglement of field and geometry states is described in the small angle approximation. The entanglement has almost no effect on local measurements, microscopic particle interactions, or measurements of propagating states that depend only on longitudinal coordinates, but significantly alters field states in systems larger than ≈λ 2 /l P that depend on transverse coordinates or direction. It reduces the information content of fields in large systems, consistent with holographic bounds from gravitation theory, and may lead to quantum-geometrical directional fluctuations of massive bodies detectable with interferometers. Possible connections are discussed with field vacuum energy, black hole information, and inflationary fluctuations.
http://arxiv.org/abs/1312.7767
Quantization and fixed points of non-integrable Weyl theory
Carlo Pagani, Roberto Percacci
We consider a simple but generic model of gravity where Weyl--invariance is realized thanks to the presence of a gauge field for dilatations. We quantize the theory by suitably defining renormalization group flows that describe the integration of successive momentum shells, in such a way that Weyl--invariance is maintained in the flow. When the gauge fields are massless the theory has, in addition to Weyl invariance, an abelian gauge symmetry. According to the definition of the cutoff, the flow can break or preserve this extended symmetry. We discuss the fixed points of these flows.
http://arxiv.org/abs/1312.7842
Twistors and antipodes in de Sitter space
Yasha Neiman
We develop the basics of twistor theory in de Sitter space, up to the Penrose transform for free massless fields. We treat de Sitter space as fundamental, as one does for Minkowski space in conventional introductions to twistor theory. This involves viewing twistors as spinors of the de Sitter group SO(4,1). When attached to a spacetime point, such a twistor can be reinterpreted as a local SO(3,1) Dirac spinor. Our approach highlights the antipodal map in de Sitter space, which gives rise to doublings in the standard relations between twistors and spacetime. In particular, one can generate a field with both handedness signs from a single twistor function. Such fields naturally live on antipodally-identified de Sitter space dS_4/Z_2, which has been put forward as the ideal laboratory for quantum gravity with positive cosmological constant.
http://arxiv.org/abs/1312.7856
Gravitation from Entanglement in Holographic CFTs
Thomas Faulkner, Monica Guica, Thomas Hartman, Robert C. Myers, Mark Van Raamsdonk(Submitted on 30 Dec 2013)
Entanglement entropy obeys a 'first law', an exact quantum generalization of the ordinary first law of thermodynamics. In any CFT with a semiclassical holographic dual, this first law has an interpretation in the dual gravitational theory as a constraint on the spacetimes dual to CFT states. For small perturbations around the CFT vacuum state, we show that the set of such constraints for all ball-shaped spatial regions in the CFT is exactly equivalent to the requirement that the dual geometry satisfy the gravitational equations of motion, linearized about pure AdS. For theories with entanglement entropy computed by the Ryu-Takayanagi formula S=A/(4G N ) , we obtain the linearized Einstein equations. For theories in which the vacuum entanglement entropy for a ball is computed by more general Wald functionals, we obtain the linearized equations for the associated higher-curvature theories. Using the first law, we also derive the holographic dictionary for the stress tensor, given the holographic formula for entanglement entropy. This method provides a simple alternative to holographic renormalization for computing the stress tensor expectation value in arbitrary higher derivative gravitational theories.
http://arxiv.org/abs/1312.7878
Into the Amplituhedron
Nima Arkani-Hamed, Jaroslav Trnka
We initiate an exploration of the physics and geometry of the amplituhedron, starting with the simplest case of the integrand for four-particle scattering in planar N=4 SYM. We show how the textbook structure of the unitarity double-cut follows from the positive geometry. We also use the geometry to expose the behavior of the multicollinear limit, providing a direct motivation for studying the logarithm of the amplitude. In addition to computing the two and three-loop integrands, we explore various lower-dimensional faces of the amplituhedron, thereby computing non-trivial cuts of the integrand to all loop orders.
http://arxiv.org/abs/1312.7828
First order gravity: Actions, topological terms and boundaries
Alejandro Corichi, Irais Rubalcava, Tatjana Vukasinac
We consider first order gravity in four dimensions. This means that the fundamental variables are a tetrad e and a SO(3,1) connection ω . We study the most general action principle compatible with diffeomorphism invariance. This implies, in particular, considering besides the standard Einstein-Hilbert term, other terms that either do not change the equations of motion, or are topological in nature. Having a well defined action principle also implies adding additional boundary terms, whose detailed form may depend on the particular boundary conditions at hand. We consider spacetimes that include a boundary at infinity, satisfying asymptotically flat boundary conditions and/or an internal boundary satisfying isolated horizons boundary conditions. For our analysis we employ the covariant Hamiltonian formalism where the phase space Γ is given by solutions to the equation of motion. For each of the possible terms contributing to the action we study the well posedness of the action, its finiteness, the contribution to the symplectic structure, and the Hamiltonian and Noether charges. While some of the results are not new, we have several results that are novel and have not appeared elsewhere. Furthermore, we point out and clarify some issues that have not been clearly understood in the literature. The aim of the paper is to present a comprehensive and self-contained treatment of the subject, so the style is somewhat pedagogical.
  • #2,104
http://arxiv.org/abs/1401.0327
Quantum volume and length fluctuations in a midi-superspace model of Minkowski space
Jeremy Adelman, Franz Hinterleitner, Seth Major
(Submitted on 1 Jan 2014)
In a 1+1 dimensional midi-superspace model for gravitational plane waves, Minkowski space-time flatness is imposed with constraints derived from null Killing vectors. Solutions to a straightforward regularization of these constraints have diverging length and volume expectation values. Physically acceptable solutions in the kinematic Hilbert space are obtained with constraints weakened by multiplying with a power of the the volume operator, or by a similar modification of the Hamiltonian constraint. The solutions of the modified constraint have finite expectation values of geometric quantities. Further, the expectation value of the original constraint vanishes, but its moment is non-vanishing. As the power of the volume grows, while the moments of volume and length decrease. In this way possible kinematic states for flat space, with fluctuations, arise. As a consequence of the regularization of operators in quantum geometry, the quantum uncertainty relations between geometric quantities such as length and its conjugate momentum do not reflect naive expectations from the classical Poisson bracket relations.
41 pages
==quote==
I. INTRODUCTION
Loop quantum gravity (LQG) quantizes the spatial geometry by introducing “atoms of spatial geometry” in form of quanta of volume, area, length, and angle [1–6]. Unlike the Minkowski vacuum in quantum field theories of different kinds of matter, the quantum model of flat space appears to be, not a “no particle” state but rather, a highly excited state with a macroscopically homogeneous distribution of excited quanta of geometry. In this paper we explore…
==endquote==
Sabine resolves the "firewall" problem:
http://arxiv.org/abs/1401.0288
Disentangling the Black Hole Vacuum
S. Hossenfelder
We study the question whether disentanglement of Hawking radiation can be achieved with any local operation. We assume that the operation we look for is unitary and can be described by a Bogoliubov transformation. This allows to formulate requirements on the operation of disentanglement. We then show that these requirements can be fulfilled by a timelike boundary condition in the near-horizon area and that the local observer does not notice the presence of the boundary and does not encounter a firewall.
16 pages, 2 figures
[my comment: Acknowledgements section thanks Raffael Bousso, Steve Giddings, Steve Hsu, Ted Jacobson, Don Marolf and Joe Polchinski for feedback and other assistance.]
  • #2,105
http://arxiv.org/abs/1401.0931
Hamiltonian constraint in Euclidean LQG revisited: First hints of off-shell Closure
Alok Laddha
(Submitted on 5 Jan 2014)
We initiate the hunt for a definition of Hamiltonian constraint in Euclidean Loop Quantum Gravity (LQG) which faithfully represents quantum Dirac algebra. Borrowing key ideas from previous works on Hamiltonian constraint in LQG and several toy models, we present some evidence that there exists such a continuum Hamiltonian constraint operator which is well defined on a suitable generalization of the Lewandowski-Marolf Habitat and is anomaly free off-shell.
68 pages, 6 figures
  • #2,106
Alok Laddha
68 pages, 6 figures
briefly noted, possibly of general interest:
http://arxiv.org/abs/1401.1146
Is the Universe Simpler than LCDM?
Matthew G. Walker, Abraham Loeb
(Submitted on 6 Jan 2014)
In the standard cosmological model, the Universe consists mainly of two invisible substances: vacuum energy with mass density rhov = Lambda /(8 pi G), and cold dark matter (CDM). This model has the virtue of simplicity, enabling straightforward calculation of the formation and evolution of cosmic structure against the backdrop of the Hubble flow. Here we discuss apparent discrepancies with observations on small galactic scales, which LCDM must attribute to complexity in the baryon physics of galaxy formation. Yet galaxies exhibit structural scaling relations that evoke simplicity, presenting a clear target for formation models. We use published data to examine the relationship between dynamical components of such relations. Tracers of gravitational potentials dominated by dark matter show a correlation between orbital size, R, and velocity, V, that can be expressed most simply as a characteristic acceleration, aDM ~ 1 km2/s2/pc ~ 3 x 10-9 cm/s2 ~ 0.2c(G rhov)1/2. It remains to be seen whether LCDM predicts such behavior.
22 pages, 1 figure, submitted to Contemporary Physics
http://arxiv.org/abs/1401.0774
Quantum Limit on Stability of Clocks in a Gravitational Field
Supurna Sinha, Joseph Samuel
(Submitted on 4 Jan 2014)
Accurate and stable clocks are of importance both to fundamental physics and for applications in astronomy, metrology and global positioning systems. In a recent technological breakthrough, researchers at NIST have been able to achieve a stability of 1 part in 1018 using an Ytterbium clock. This naturally raises the question of whether there are fundamental limits to the stability of clocks. In this paper we point out that gravity and quantum mechanics set a fundamental limit on the stability of clocks. This limit comes from a combination of the uncertainty relation, the gravitational redshift and the relativistic time dilation effect. For example, a single ion hydrogen maser clock in a terrestrial gravitational field cannot achieve a stability better than one part in 1022. This observation has implications for laboratory experiments involving both gravity and quantum theory. Our result implies that quantum interference effects can be destroyed by a sufficiently strong gravitational field, which would be of interest to theorists attempting to combine gravity and quantum theory.
10 pages, 2 figures, 1 table
  • #2,107
http://arxiv.org/abs/1401.1523
Firewalls and flat mirrors: An alternative to the AMPS experiment which evades the Harlow-Hayden obstacle
Jonathan Oppenheim, William G. Unruh
(Submitted on 7 Jan 2014)
If quantum gravity does not lead to a breakdown of predictability, then Almheiri, Marolf, Polchinski and Sully (AMPS) have argued that an observer falling into a black hole can perform an experiment which verifies a violation of entanglement monogamy - that late time Hawking radiation is maximally entangled with early time Hawking radiation and also with infalling radiation - something impossible in quantum field theory. However, as pointed out by Hayden and Harlow, this experiment is infeasible, as the time required to perform the experiment is almost certainly longer than the lifetime of the black hole. Here we propose an alternative firewall experiment which could actually be performed within the black hole's lifetime. The alternative experiment involves forming an entangled black hole in which the unscrambling of information is precomputed on a quantum memory prior to the creation of the black hole and without acting on the matter which forms the black hole or emerges from it. This would allow an observer near a black hole to signal faster than light. As another application of our precomputing strategy, we show how one can produce entangled black holes which acts like "flat mirrors'', in the sense that information comes out almost instantly (as in the Hayden-Preskill scenario), but also emerge unscrambled, so that it can actually be observed instantly as well. Finally, we prove that a black hole in thermal equilibrium with its own radiation, is uncorrelated with this radiation.
19 pages, 3 figures
  • #2,108
http://arxiv.org/abs/1401.2057
Generally covariant formulation of Relative Locality in curved spacetime
Francesco Cianfrani, Jerzy Kowalski-Glikman, Giacomo Rosati
(Submitted on 9 Jan 2014)
We construct a theory of particles moving in curved both momentum space and spacetime, being a generalization of Relative Locality. We find that in order to construct such theory, with desired symmetries, including the general coordinate invariance, we have to use non local position variables. It turns out that free particles move on geodesics and momentum dependent translations of Relative Locality are replaced with momentum dependent geodesic deviations.
14 pages
http://arxiv.org/abs/1401.2026
Quantum fields in curved spacetime
Stefan Hollands, Robert M. Wald
We review the theory of quantum fields propagating in an arbitrary, classical, globally hyperbolic spacetime. Our review emphasizes the conceptual issues arising in the formulation of the theory and presents known results in a mathematically precise way. Particular attention is paid to the distributional nature of quantum fields, to their local and covariant character, and to microlocal spectrum conditions satisfied by physically reasonable states. We review the Unruh and Hawking effects for free fields, as well as the behavior of free fields in deSitter spacetime and FLRW spacetimes with an exponential phase of expansion. We review how nonlinear observables of a free field, such as the stress-energy tensor, are defined, as well as time-ordered-products. The "renormalization ambiguities" involved in the definition of time-ordered products are fully characterized. Interacting fields are then perturbatively constructed. Our main focus is on the theory of a scalar field, but a brief discussion of gauge fields is included. We conclude with a brief discussion of a possible approach towards a nonperturbative formulation of quantum field theory in curved spacetime and some remarks on the formulation of quantum gravity.
52 pages, 7 figures, invited contribution to "100 Years of General Relativity" monograph series
http://arxiv.org/abs/1401.1838
Comments On Torsion and MacDowell-Mansouri gravity
J. C. López-Domínguez, J. E. Rosales-Quintero, M. Sabido
(Submitted on 8 Jan 2014)
We construct a generalization for the MacDowell-Mansouri formulation of gravity. New parameters are introduced into the action to include the non-dynamical Holst term, independently from the topological Nieh-Yan class. Finally, we consider the new parameters as fields and analyze the solutions coming from their equations of motion. The new fields introduce torsional contributions to the theory that modify Einstein's equations.
15 pages
  • #2,109
http://arxiv.org/abs/1401.3054
The Entropy of BTZ Black Hole from Loop Quantum Gravity
Jingbo Wang
(Submitted on 14 Jan 2014)
In this paper, we calculated the entropy of the BTZ black hole in the framework of loop quantum gravity. We got the result that the horizon degrees of freedom can be described by the 2D SO(1,1) punctured BF theory. Finally we got the area law for the entropy of BTZ black hole.
12 page
  • #2,110
http://arxiv.org/abs/1401.3416
Wormholes and Entanglement
John C. Baez, Jamie Vicary
(Submitted on 15 Jan 2014)
Maldacena and Susskind have proposed a correspondence between wormholes and entanglement, dubbed ER=EPR. We study this in the context of 3d topological quantum field theory, where we show that the formation of a wormhole is the same process as creating a particle-antiparticle pair. A key feature of the ER=EPR proposal is that certain apparently entangled degrees of freedom turn out to be the same. We name this phenomenon "fake entanglement", and show how it arises in our topological quantum field theory model.
http://arxiv.org/abs/1401.3578
Conceptual Problems in Quantum Gravity and Quantum Cosmology
Claus Kiefer
The search for a consistent and empirically established quantum theory of gravity is among the biggest open problems of fundamental physics. The obstacles are of formal and of conceptual nature. Here, I address the main conceptual problems, discuss their present status and outline further directions of research. For this purpose, the main current approaches to quantum gravity are briefly reviewed and compared.
http://arxiv.org/abs/1401.3393
Universal coordinates for Schwarzschild black holes
W G Unruh
A variety of historical coordinates in which the Schwarzschild metric is regular over the whole of the extended spacetime are compared and the hypersurfaces of constant coordinate are graphically presented. While the Kruscal form (one of the later forms) is probably the simplest, each of the others has some interesting features.
Likes 1 person
  • #2,111
http://arxiv.org/abs/1401.4452
Black holes within Asymptotic Safety
Benjamin Koch, Frank Saueressig
(Submitted on 17 Jan 2014)
Black holes are probably among the most fascinating objects populating our universe. Their characteristic features found within general relativity, encompassing spacetime singularities, event horizons, and black hole thermodynamics, provide a rich testing ground for quantum gravity ideas. We review the status of black holes within a particular proposal for quantum gravity, Weinberg's asymptotic safety program. Starting from a brief survey of the effective average action and scale setting procedures, an improved quantum picture of the black hole is developed. The Schwarzschild black hole and its generalizations including angular momenta, higher-derivative corrections and the implications of extra dimensions are discussed in detail. In addition, the quantum singularity emerging for the inclusion of a cosmological constant is elucidated and linked to the phenomenon of a dynamical dimensional reduction of spacetime.
  • #2,112
http://arxiv.org/abs/1401.5262
Spacetime thermodynamics without hidden degrees of freedom
Goffredo Chirco, Hal M. Haggard, Aldo Riello, Carlo Rovelli
(Submitted on 21 Jan 2014)
A celebrated result by Jacobson is the derivation of Einstein's equations from Unruh's temperature, the Bekenstein-Hawking entropy and the Clausius relation. This has been repeatedly taken as evidence for an interpretation of Einstein's equations as equations of state for unknown degrees of freedom underlying the metric. We show that a different interpretation of Jacobson result is possible, which does not imply the existence of additional degrees of freedom, and follows only from the quantum properties of gravity. We introduce the notion of quantum gravitational Hadamard states, which give rise to the full local thermodynamics of gravity.
12 pages, 1 figure
http://arxiv.org/abs/1401.5083
Non-Commutative Geometry, Non-Associative Geometry and the Standard Model of Particle Physics
Latham Boyle, Shane Farnsworth
(Submitted on 20 Jan 2014)
Connes has developed a notion of non-commutative geometry (NCG) that generalizes Riemannian geometry, and provides a framework in which the standard model of particle physics, coupled to Einstein gravity, may be concisely and elegantly reformulated. We point out that his formalism may be recast in a way that generalizes immediately from non-commutative to non-associative geometry. In the process, several of the standard axioms and formulae are conceptually reinterpreted. This reformulation also suggests a new constraint on the finite NCG corresponding to the standard model of particle physics. Remarkably, this new condition resolves a long-standing puzzle about the NCG embedding of the standard model, by precisely eliminating from the action the collection of 7 unwanted terms that previously had to be removed by an extra (empirically-motivated) assumption.
5 pages
http://arxiv.org/abs/1401.4275
Strict Deformation Quantisation of the G-connections via Lie Groupoid
Alan Lai
Motivated by the compactification process of the space of connections in loop quantum gravity literature. A description of the space of G-connections using the tangent groupoid is given. As the tangent groupoid parameter is away from zero, the G-connections are (strictly) deformation quantised to noncommuting elements using C*-algebraic formalism. The approach provides a means to obtain a semi-classical limit in loop quantum gravity.
9 pages
http://arxiv.org/abs/1401.5352
Effective Casimir Conditions and Group Coherent States
Martin Bojowald, Artur Tsobanjan
Properties of group coherent states can be derived "effectively" without knowing full wave functions. The procedure is detailed in this article as an example of general methods for effective constraints. The role of constraints in the present context is played by a Casimir condition that puts states within an irreducible representation of a Lie group (or, equivalently, on a quantization of a co-adjoint orbit of the dual Lie algebra). Simplifications implied by a Casimir condition, compared with general first-class constraints, allows one to show that the correct number of degrees of freedom is obtained after imposing the condition. When combined with conditions to saturate uncertainty relations, moments of group coherent states can be derived. A detailed example in quantum cosmology (cosmic forgetfulness) illustrates the usefulness of the methods.
23 pages
http://arxiv.org/abs/1401.5313
Hot big bang or slow freeze?
C.Wetterich
9 pages, 1 figure
  • #2,113
http://arxiv.org/abs/1401.5495
RG flows of Quantum Einstein Gravity on maximally symmetric spaces
Maximilian Demmel, Frank Saueressig, Omar Zanusso
We use the Wetterich-equation to study the renormalization group flow of f(R)-gravity in a three-dimensional, conformally reduced setting. Building on the exact heat kernel for maximally symmetric spaces, we obtain a partial differential equation which captures the scale-dependence of f(R) for positive and, for the first time, negative scalar curvature. The effects of different background topologies are studied in detail and it is shown that they affect the gravitational RG flow in a way that is not visible in finite-dimensional truncations. Thus, while featuring local background independence, the functional renormalization group equation is sensitive to the topological properties of the background. The detailed analytical and numerical analysis of the partial differential equation reveals two globally well-defined fixed functionals with at most a finite number of relevant deformations. Their properties are remarkably similar to two of the fixed points identified within the R2-truncation of full Quantum Einstein Gravity. As a byproduct, we obtain a nice illustration of how the functional renormalization group realizes the "integrating out" of fluctuation modes on the three-sphere.
35 pages, 6 figures
http://arxiv.org/abs/1401.5256
Effective dynamics of scalar perturbations in a flat Friedmann-Robertson-Walker spacetime in Loop Quantum Cosmology
Mikel Fernández-Méndez, Guillermo A. Mena Marugán, Javier Olmedo
We study the evolution of a homogeneous and isotropic spacetime whose spatial sections have three-torus topology, coupled to a massless scalar field with small scalar perturbations within loop quantum cosmology. We consider a proposal for the effective dynamics based on a previous hybrid quantization completed by us. Consequently, we introduce a convenient gauge fixing and adopt reduced canonical variables adapted to that hybrid quantum description. Besides, we keep backreaction contributions on the background coming from terms quadratic in the perturbations in the action of the system. We carry out a numerical analysis assuming that the inhomogeneities were in a massless vacuum state at distant past (where the initial data are set). At distant future, we observe a statistical amplification of the modes amplitude in the infrared region, as well as a phase synchronization arising from quantum gravity phenomena. A description of the perturbations in terms of the Mukhanov-Sasaki gauge invariants provides the same qualitative results. Finally, we analyze some consequences of the backreaction in our effective description.
15 pages, 9 figures. Accepted for publication in Phys. Rev. D
not QG but possibly of general interest:
http://arxiv.org/abs/1401.5761
Information Preservation and Weather Forecasting for Black Holes
S. W. Hawking
(Submitted on 22 Jan 2014)
It has been suggested [1] that the resolution of the information paradox for evaporating black holes is that the holes are surrounded by firewalls, bolts of outgoing radiation that would destroy any infalling observer. Such firewalls would break the CPT invariance of quantum gravity and seem to be ruled out on other grounds. A different resolution of the paradox is proposed, namely that gravitational collapse produces apparent horizons but no event horizons behind which information is lost. This proposal is supported by ADS-CFT and is the only resolution of the paradox compatible with CPT. The collapse to form a black hole will in general be chaotic and the dual CFT on the boundary of ADS will be turbulent. Thus, like weather forecasting on Earth, information will effectively be lost, although there would be no loss of unitarity.
4 pages, talk given at KITP workshop, Santa Barbara, August 2013
  • #2,114
http://arxiv.org/abs/1401.5819
Asymptotic analysis of Ponzano-Regge model with non-commutative metric variables
Daniele Oriti, Matti Raasakka
We apply the non-commutative Fourier transform for Lie groups to formulate the non-commutative metric representation of the Ponzano-Regge spin foam model for 3d quantum gravity. The non-commutative representation allows to express the amplitudes of the model as a first order phase space path integral, whose properties we consider. In particular, we study the asymptotic behavior of the path integral in the semi-classical limit. First, we compare the stationary phase equations in the classical limit for three different non-commutative structures corresponding to symmetric, Duflo and Freidel-Livine-Majid quantization maps. We find that in order to unambiguously recover discrete geometric constraints for non-commutative metric data through stationary phase method, the deformation structure of the phase space must be accounted for in the variational calculus. When this is understood, our results demonstrate that the non-commutative metric representation facilitates a convenient semi-classical analysis of the Ponzano-Regge model, which yields as the dominant contribution to the amplitude the cosine of the Regge action in agreement with previous studies. We also consider the asymptotics of the SU(2) 6j-symbol using the non-commutative phase space path integral for the Ponzano-Regge model, and explain the connection of our results to the previous asymptotic results in terms of coherent states.
32 pages, 2 figures
  • #2,115
http://arxiv.org/abs/1401.6441
A new vacuum for Loop Quantum Gravity
Bianca Dittrich, Marc Geiller
(Submitted on 24 Jan 2014)
We construct a new vacuum for loop quantum gravity, which is dual to the Ashtekar-Lewandowski vacuum. Because it is based on BF theory, this new vacuum is physical for (2+1)-dimensional gravity, and much closer to the spirit of spin foam quantization in general. To construct this new vacuum and the associated representation of quantum observables, we introduce a modified holonomy-flux algebra which is cylindrically consistent with respect to the notion of refinement by time evolution suggested in [1]. This supports the proposal for a construction of a physical vacuum made in [1,2], also for (3+1)-dimensional gravity. We expect that the vacuum introduced here will facilitate the extraction of large scale physics and cosmological predictions from loop quantum gravity.
10 pages, 5 figures
  • #2,116
http://arxiv.org/abs/1401.6562
Planck stars
Carlo Rovelli, Francesca Vidotto
(Submitted on 25 Jan 2014)
A star that collapses gravitationally can reach a further stage of its life, where quantum-gravitational pressure counteracts weight. The duration of this stage is very short in the star proper time, yielding a bounce, but extremely long seen from the outside, because of the huge gravitational time dilation. Since the onset of quantum-gravitational effects is governed by energy density --not by size-- the star can be much larger than Planckian in this phase. The object emerging at the end of the Hawking evaporation of a black hole can then be larger than Planckian by a factor (m/mP)n, where m is the mass fallen into the hole, mP is the Planck mass, and n is positive. The existence of these objects alleviates the black-hole information paradox. More interestingly, these objects could have astrophysical and cosmological interest: they produce a detectable signal, of quantum gravitational origin, around the 10−14cm wavelength.
5 pages, 3 figures. Nice paper.
  • #2,117
http://arxiv.org/abs/1401.6940
Towards measuring the Archimedes force of vacuum
Enrico Calloni, Martina De Laurentis, Rosario De Rosa, Luciano Di Fiore, Giampiero Esposito, Fabio Garufi, Luigi Rosa, Carlo Rovelli, Paolo Ruggi, Francesco Tafuri
(Submitted on 27 Jan 2014)
We discuss the force exerted by the gravitational field on a Casimir cavity in terms of Archimedes' force of vacuum, we identify the force that can be tested against observation and we show that the present technology makes it possible to perform the first experimental tests. We motivate the use of suitable high-Tc superconductors as modulators of Archimedes' force. We analyze the possibility of using gravitational wave interferometers as detectors of the force, transported through an optical spring from the Archimedes vacuum force apparatus to the gravitational interferometers test masses to maintain the two systems well separated. We also analyze the use of balances to actuate and detect the force, we compare different solutions and discuss the most important experimental issues.
20 pages, 6 figures
http://arxiv.org/abs/1401.7358
Propagator with Positive Cosmological Constant in the 3D Euclidian Quantum Gravity Toy Model
William Bunting, Carlo Rovelli
(Submitted on 28 Jan 2014)
We study the propagator on a single tetrahedron in a three dimensional toy model of quantum gravity with positive cosmological constant. The cosmological constant is included in the model via q-deformation of the spatial symmetry algebra, that is, we use the Tuarev-Viro amplitude. The expected repulsive effect of dark energy is recovered in numerical and analytic calculations of the propagator at large scales comparable to the infrared cutoff. However, due to the simplicity of the model we do not obtain the exact Newton limit of the propagator. This is a first step toward the similar calculation in the full 3+1 dimensional theory with larger numbers of simplicies.
7 pages, 2 figures
http://pirsa.org/14010098/
Black hole entropy and the case for self-dual loop quantum gravity
Marc Geiller
By focusing on aspects of black hole thermodynamics, I will present some evidences supporting the unexpected role of the complex self-dual variables in quantum gravity. This will also be the occasion of revisiting some aspects of three-dimensional gravity, and in particular the link between the BTZ black hole and the Turaev-Viro state sum model.
Date: 29/01/2014 - 3:30 pm
  • #2,118
http://arxiv.org/abs/1401.6062
Quantization of systems with temporally varying discretization I: Evolving Hilbert spaces
Philipp A Hoehn
(Submitted on 23 Jan 2014)
A temporally varying discretization often features in discrete gravitational systems and appears in lattice field theory models subject to a coarse graining or refining dynamics. To better understand such discretization changing dynamics in the quantum theory, an according formalism for constrained variational discrete systems is constructed. While the present manuscript focuses on global evolution moves and, for simplicity, restricts to Euclidean configuration spaces, a companion article discusses local evolution moves. In order to link the covariant and canonical picture, the dynamics of the quantum states is generated by propagators which satisfy the canonical constraints and are constructed using the action and group averaging projectors. This projector formalism offers a systematic method for tracing and regularizing divergences in the resulting state sums. Non-trivial coarse graining evolution moves lead to non-unitary, and thus irreversible, projections of physical Hilbert spaces and Dirac observables such that these concepts become evolution move dependent on temporally varying discretizations. The formalism is illustrated in a toy model mimicking a `creation from nothing'. Subtleties arising when applying such a formalism to quantum gravity models are discussed.
44 pages, 1 appendix, 6 figures
http://arxiv.org/abs/1401.7731
Quantization of systems with temporally varying discretization II: Local evolution moves
Philipp A Hoehn
(Submitted on 30 Jan 2014)
Several quantum gravity approaches and field theory on an evolving lattice involve a discretization changing dynamics generated by evolution moves. Local evolution moves in variational discrete systems (1) are a generalization of the Pachner evolution moves of simplicial gravity models, (2) update only a small subset of the dynamical data, (3) change the number of kinematical and physical degrees of freedom, and (4) generate a dynamical coarse graining or refining of the underlying discretization. To systematically explore such local moves and their implications in the quantum theory, this article suitably expands the quantum formalism for global evolution moves, constructed in a companion paper, by employing that global moves can be decomposed into sequences of local moves. This formalism is spelled out for systems with Euclidean configuration spaces. Various types of local moves, the different kinds of constraints generated by them, the constraint preservation and possible divergences in resulting state sums are discussed. It is shown that non-trivial local coarse graining moves entail a non-unitary projection of (physical) Hilbert spaces and `fine grained' Dirac observables defined on them. Identities for undoing a local evolution move with its (time reversed) inverse are derived. Finally, the implications of these results for a Pachner move generated dynamics in simplicial quantum gravity models are commented on.
36 pages, many figures, 2 appendices (5 pages)
  • #2,119
http://arxiv.org/abs/1402.1038
A note on entanglement entropy and quantum geometry
Norbert Bodendorfer
(Submitted on 5 Feb 2014)
It has been argued that the entropy which one is computing in the isolated horizon framework of loop quantum gravity is closely related to the entanglement entropy of the gravitational field and that the calculation performed is not restricted to horizons. We recall existing work on this issue and explain how recent work on generalising these computations to arbitrary spacetime dimensions D+1>2 supports this point of view and makes the duality between entanglement entropy and the entropy computed from counting boundary states manifest. In a certain semiclassical regime in 3+1 dimensions, this entropy is given by the Bekenstein-Hawking formula.
14 pages
  • #2,120
http://arxiv.org/abs/1402.1427
The Black Hole Uncertainty Principle Correspondence
B. J. Carr
(Submitted on 6 Feb 2014)
The Black Hole Uncertainty Principle correspondence proposes a connection between the Uncertainty Principle on microscopic scales and black holes on macroscopic scales. This is manifested in a unified expression for the Compton wavelength and Schwarzschild radius. It is a natural consequence of the Generalized Uncertainty Principle, which suggests corrections to the Uncertainty Principle as the energy increases towards the Planck value. It also entails corrections to the event horizon size as the black hole mass falls to the Planck value, leading to the concept of a Generalized Event Horizon. One implication of this is that there could be sub-Planckian black holes with a size of order their Compton wavelength. Loop quantum gravity suggests the existence of black holes with precisely this feature. The correspondence leads to a heuristic derivation of the black hole temperature and suggests how the Hawking formula is modified in the sub-Planckian regime.
8 pages, 4 figures, to appear in Proceedings of 2013 Karl Schwarzschild Meeting on Gravitational Physics.
http://arxiv.org/abs/1402.1437
Primordial Black Holes and Quantum Effects
B. J. Carr
Primordial black holes (PBHs) are of special interest because of the crucial role of quantum effects in their formation and evaporation. This means that they provide a unique probe of the early universe, high-energy physics and quantum gravity. We highlight some recent developments in the subject, including improved limits on the fraction of the Universe going into evaporating PBHs in the mass range 109−1017 g and the possibility of using PBHs to probe a cosmological bounce.
8 pages, 6 figures, to appear in Proceedings of 2013 Karl Schwarzschild Meeting on Gravitational Physics.
  • #2,121
http://arxiv.org/abs/1402.2084
Black Hole Entropy in Loop Quantum Gravity, Analytic Continuation, and Dual Holography
Muxin Han
(Submitted on 10 Feb 2014)
A new approach to black hole thermodynamics is proposed in Loop Quantum Gravity (LQG), by defining a new black hole partition function, followed by analytic continuations of Barbero-Immirzi parameter to γ ∈ iℝ and Chern-Simons level to k∈iℝ. The analytic continued partition function has remarkable features: The black hole entropy S=A/4ℓ2P is reproduced correctly for infinitely many γ=iη, at least for η ∈ ℤ∖{0}. The near-horizon Unruh temperature emerges as the pole of partition function. Interestingly, by analytic continuation the partition function can have a dual statistical interpretation corresponding to a dual quantum theory of γ ∈ iℤ. The dual quantum theory implies a semiclassical area spectrum for γ ∈ iℤ. It also implies that at a given near horizon (quantum) geometry, the number of quantum states inside horizon is bounded by a holographic degeneracy d=eA/4ℓP, which produces the Bekenstein bound from LQG.
On the other hand, the result in http://arxiv.org/abs/1212.4060 receives a justification here.
5 pages
  • #2,122
http://arxiv.org/abs/1402.2323
Deformed phase space for 3d loop gravity and hyperbolic discrete geometries
Valentin Bonzom, Maité Dupuis, Florian Girelli, Etera R. Livine
We revisit the loop gravity space phase for 3D Riemannian gravity by algebraically constructing the phase space T*SU(2)∼ISO(3) as the Heisenberg double of the Lie group SO(3) provided with the trivial cocyle. Tackling the issue of accounting for a non-vanishing cosmological constraint Λ≠0 in the canonical framework of 3D loop quantum gravity, SL(2,ℂ) viewed as the Heisenberg double of SU(2) provided with a non-trivial cocyle is introduced as a phase space. It is a deformation of the flat phase space ISO(3) and reproduces the latter in a suitable limit. The SL(2,ℂ) phase space is then used to build a new, deformed LQG phase space associated to graphs. It can be equipped with a set of Gauss constraints and flatness constraints, which form a first class system and Poisson-generate local 3D rotations and deformed translations. We provide a geometrical interpretation for this lattice phase space with constraints in terms of consistently glued hyperbolic triangles, i.e. hyperbolic discrete geometries, thus validating our construction as accounting for a constant curvature Λ<0. Finally, using ribbon diagrams, we show that our new model is topological.
30 pages 12 figures
http://arxiv.org/abs/1402.2274
Anyonic statistics and large horizon diffeomorphisms for Loop Quantum Gravity Black Holes
Andreas G. A. Pithis, Hans-Christian Ruiz Euler
In this article we investigate the role played by large diffeomorphisms of quantum Isolated Horizons for the statistics of LQG Black Holes by means of their relation to the braid group. To this aim the symmetries of Chern-Simons theory are recapitulated with particular regard to the aforementioned type of diffeomorphisms. For the punctured spherical horizon, these are elements of the mapping class group of S2, which is almost isomorphic to a corresponding braid group on this particular manifold. The mutual exchange of quantum entities in 2-dimensions is communicated by the braid group, rendering the statistics anyonic. With this we argue that the quantum Isolated Horizon model of LQG based on SU(2)k-Chern-Simons theory exhibits non-abelian anyonic statistics. In this way a connection to theory behind the fractional quantum Hall effect and that of topological quantum computation is established, where non-abelian anyons play a significant role.
17 pages, largely based on work taken from AP's diploma thesis from 09/2012
http://arxiv.org/abs/1402.2384
Turaev-Viro amplitudes from 2+1 Loop Quantum Gravity
Daniele Pranzetti
(Submitted on 11 Feb 2014)
The Turaev-Viro state sum model provides a covariant spin foam quantization of three-dimensional Riemannian gravity with a positive cosmological constant Λ. We complete the program to canonically quantize the theory in the BF formulation using the formalism of Loop Quantum Gravity. In particular, we show first how quantum group structures arise from the requirement of the constraint algebra to be anomaly free. This allows us to generalize the construction of the physical scalar product, from the Λ = 0 case, in presence of a positive Λ. We prove the equivalence between the covariant and canonical quantizations by recovering the spin foam amplitudes.
23 pages, many figures
  • #2,123
Non-technical piece on QG for wide audience:
http://arxiv.org/abs/1402.2757
Quantum Gravity for Dummies
Deepak Vaid
(Submitted on 12 Feb 2014)
I have been asked to write brief, gentle introduction to the basic idea behind the field of "quantum gravity" in 1500 words or less. Doing so appears to be almost as great a challenge as coming up with a consistent theory of quantum gravity. However, I will try. Disclaimer: The views expressed in this article are my own and do not represent the consensus of the quantum gravity community.
7 pages; non-technical article; invited contribution for NITK annual magazine "Vitruvian"
  • #2,124
http://arxiv.org/abs/1402.3155
Quantum Reduced Loop Gravity: Semiclassical limit
Emanuele Alesci, Francesco Cianfrani
(Submitted on 13 Feb 2014)
We discuss the semiclassical limit of Quantum Reduced Loop Gravity, a recently proposed model to address the quantum dynamics of the early Universe. We apply the techniques developed in full Loop Quantum Gravity to define the semiclassical states in the kinematical Hilbert space and evaluating the expectation value of the euclidean scalar constraint we demonstrate that it coincides with the classical expression, i.e. the one of a local Bianchi I dynamics. The result holds as a leading order expansion in the scale factors of the Universe and opens the way to study the subleading corrections to the semiclassical dynamics. We outline how by retaining a suitable finite coordinate length for holonomies our effective Hamiltonian at the leading order coincides with the one expected from LQC. This result is an important step in fixing the correspondence between LQG and LQC.
23 pages
http://arxiv.org/abs/1402.3071
On R+αR2 Loop Quantum Cosmology
J. Amorós, J. de Haro, S.D. Odintsov
Working in Einstein frame we introduce, in order to avoid singularities, holonomy corrections to the f(R)=R+αR2 model. We perform a detailed analytical and numerical study when holonomy corrections are taken into account in both Jordan and Einstein frames obtaining, in Jordan frame, a dynamics which differs qualitatively, at early times, from the one of the original model. More precisely, when holonomy corrections are taken into account the universe is not singular, starting at early times in the contracting phase and bouncing to enter in the expanding one where, as in the original model, it inflates. This dynamics is completely different from the one obtained in the original R+αR2 model, where the universe is singular at early times and never bounces. Moreover, we show that these holonomy corrections may lead to better predictions for the inflationary phase as compared with current observations.
22 pages, 5 figures
http://arxiv.org/abs/1402.3009
Non-singular bounce scenarios in loop quantum cosmology and the effective field description
Yi-Fu Cai, Edward Wilson-Ewing
A non-singular bouncing cosmology is generically obtained in loop quantum cosmology due to non-perturbative quantum gravity effects. A similar picture can be achieved in standard general relativity in the presence of a scalar field with a non-standard kinetic term such that at high energy densities the field evolves into a ghost condensate and causes a non-singular bounce. During the bouncing phase, the perturbations can be stabilized by introducing a Horndeski operator. Taking the matter content to be a dust field and an ekpyrotic scalar field, we compare the dynamics in loop quantum cosmology and in a non-singular bouncing effective field model with a non-standard kinetic term at both the background and perturbative levels. We find that these two settings share many important properties, including the result that they both generate scale-invariant scalar perturbations. This shows that some quantum gravity effects of the very early universe may be mimicked by effective field models.
12 pages, 5 figures
  • #2,125
http://arxiv.org/abs/1402.3586
LQG for the Bewildered
Sundance Bilson-Thompson, Deepak Vaid
(Submitted on 14 Feb 2014)
We present a pedagogical introduction to the notions underlying the connection formulation of General Relativity - Loop Quantum Gravity (LQG) - with an emphasis on the physical aspects of the framework. We explain, in a concise and clear manner, the steps leading from the Einstein-Hilbert action for gravity to the construction of the quantum states of geometry, known as spin-networks, which provide the basis for the kinematical Hilbert space of quantum general relativity. Along the way we introduce the various associated concepts of tetrads, spin-connection and holonomies which are a pre-requisite for understanding the LQG formalism. Having provided a minimal introduction to the LQG framework, we discuss its applications to the problems of black hole entropy and of quantum cosmology. A list of the most common criticisms of LQG is presented, which are then tackled one by one in order to convince the reader of the physical viability of the theory.
An extensive set of appendices provide accessible introductions to several key notions such as the Peter-Weyl theorem, duality} of differential forms and Regge calculus, among others. The presentation is aimed at graduate students and researchers who have some familiarity with the tools of quantum mechanics and field theory and/or General Relativity, but are intimidated by the seeming technical prowess required to browse through the existing LQG literature. Our hope is to make the formalism appear a little less bewildering to the un-initiated and to help lower the barrier for entry into the field.
84 pages, many figures
http://arxiv.org/abs/1402.3544
Quantum fields in curved space-time, semiclassical gravity, quantum gravity phenomenology, and analogue models: Report on session D4 at GR20
Christopher J Fewster, Stefano Liberati
The talks given in parallel session D4 at the 20th International Conference on General Relativity and Gravitation (Warsaw 2013) are summarized.
15 pages. To appear in the GR20 Proceedings issue of General Relativity and Gravitation
Likes 1 person
  • #2,126
Wow, there is a lot of information in this thread. It's too bad I can't understand any of it. Whenever I try and read into any part of the physics beyond GR and QM, I'm flooded with higher level mathematics which keep compounding on themselves until I'm thoroughly confused. I think if if I could figure out what a manifold is, that would be a big step in the right direction, but I'm always just as confused by the explanations as I am about the manifold itself.
  • #2,127
I think this might be very interesting:
http://arxiv.org/abs/1402.3055
Black Holes, Firewalls and Chaos from Gravitational Collapse
Pankaj S. Joshi, Ramesh Narayan
One of the most spectacular predictions of the general theory of relativity is the black hole, an object that plays a central role in modern physics [1,2,3] and astrophysics [4,5]. Black holes are, however, plagued by fundamental paradoxes that remain unresolved to this day. First, the black hole event horizon is teleological in nature [6], which means that we need to know the entire future space-time of the universe to determine the current location of the horizon. This is essentially impossible. Second, any information carried by infalling matter is lost once the material falls through the event horizon. Even though the black hole may later evaporate by emitting Hawking radiation [7], the lost information does not reappear, which has the rather serious and disturbing consequence that quantum unitarity is violated [8]. Here we propose that the above paradoxes are restricted to a particular idealized model of collapse first studied in the 1930s [9, 10] in which the event horizon, which defines the boundary of the black hole, forms initially, and the singularity in the interior of the black hole forms at a later time. In contrast, gravitational collapse from more reasonable and/or physically more realistic initial conditions often leads to models in which the event horizon and the singularity form simultaneously. We show that this apparently simple modification mitigates the causality and teleological paradoxes and at the same time lends support to two recently proposed solutions to the information paradox, namely, the "firewall" [11] and "classical chaos" [12].
  • #2,128
http://arxiv.org/abs/1402.4138
Near-Horizon Radiation and Self-Dual Loop Quantum Gravity
Marc Geiller, Karim Noui
(Submitted on 17 Feb 2014)
We compute the near-horizon radiation of quantum black holes in the context of self-dual loop quantum gravity. For this, we first use the unitary spinor basis of SL(2,ℂ) to decompose states of Lorentzian spin foam models into their self-dual and anti self-dual parts, and show that the reduced density matrix obtained by tracing over one chiral component describes a thermal state at Unruh temperature. Then, we show that the analytically-continued dimension of the SU(2) Chern-Simons Hilbert space, which reproduces the Bekenstein-Hawking entropy in the large spin limit in agreement with the large spin effective action, takes the form of a partition function for states thermalized at Unruh temperature, with discrete energy levels given by the near-horizon energy of Frodden-Gosh-Perez, and with a degenerate ground state which is holographic and responsible for the entropy.
6+2 pages
  • #2,129
http://arxiv.org/abs/1402.5130
Discreteness corrections and higher spatial derivatives in effective canonical quantum gravity
Martin Bojowald, George M. Paily, Juan D. Reyes
(Submitted on 20 Feb 2014)
Canonical quantum theories with discrete space may imply interesting effects. This article presents a general effective description, paying due attention to the role of higher spatial derivatives in a local expansion and differences to higher time derivatives. In a concrete set of models, it is shown that spatial derivatives one order higher than the classical one are strongly restricted in spherically symmetric effective loop quantum gravity. Moreover, radial holonomy corrections cannot be anomaly-free to this order.
46 pages
http://arxiv.org/abs/1402.4854
Quantum Einstein-Cartan theory with the Holst term
Ilya L. Shapiro, Poliane M. Teixeira
Holst term represents an interesting addition to the Einstein-Cartan theory of gravity with torsion. When this term is present the contact interactions between vector and axial vector fermion currents gain an extra parity-violating component. We re-derive this interaction using a simple representation for the Holst term. The same representation serves as a useful basis for the calculation of one-loop divergences in the theory with external fermionic currents and cosmological constant. Furthermore, we explore the possibilities of the on-shell version of renormalization group and construct the equations for the running of dimensionless parameters related to currents and for the effective Barbero-Immirzi parameter.
Comments: 19 pages
Probably the current favorite in the Dark Matter sweepstakes is the "keV scale sterile neutrino" for instance:
http://arxiv.org/abs/1402.2301
Detection of An Unidentified Emission Line in the Stacked X-ray spectrum of Galaxy Clusters
Esra Bulbul, Maxim Markevitch, Adam Foster, Randall K. Smith, Michael Loewenstein, Scott W. Randall
We detect a weak unidentified emission line at E=(3.55-3.57)+/-0.03 keV in a stacked XMM spectrum of 73 galaxy clusters spanning a redshift range 0.01-0.35. MOS and PN observations independently show the presence of the line at consistent energies. When the full sample is divided into three subsamples (Perseus, Centaurus+Ophiuchus+Coma, and all others), the line is significantly detected in all three independent MOS spectra and the PN "all others" spectrum. It is also detected in the Chandra spectra of Perseus with the flux consistent with XMM (though it is not seen in Virgo). However, it is very weak and located within 50-110eV of several known faint lines, and so is subject to significant modeling uncertainties. On the origin of this line, we argue that there should be no atomic transitions in thermal plasma at this energy. An intriguing possibility is the decay of sterile neutrino, a long-sought dark matter particle candidate. Assuming that all dark matter is in sterile neutrinos with ms=2E=7.1 keV, our detection in the full sample corresponds to a neutrino decay mixing angle sin2(2θ)=7e-11, below the previous upper limits. …
25 pages, 14 figures, submitted to ApJ
  • #2,130
http://arxiv.org/abs/1402.5719
Singularity avoidance in classical gravity from four-fermion interaction
Cosimo Bambi, Daniele Malafarina, Antonino Marciano, Leonardo Modesto
(Submitted on 24 Feb 2014)
We derive the dynamics of the gravitational collapse of a homogeneous and spherically symmetric cloud in a classical set-up endowed with a topological sector of gravity and a non-minimal coupling to fermions. The effective theory consists of the Einstein-Hilbert action plus Dirac fermions interacting through a four-fermion vertex. At the classical level, we obtain the same picture that has been recently studied by some of us within a wide range of effective theories inspired by a super-renormalizable and asymptotically free theory of gravity. The classical singularity is replaced by a bounce, beyond which the cloud re-expands indefinitely. We thus show that, even at a classical level, if we allow for a non-minimal coupling of gravity to fermions, black holes may never form for a suitable choice of some parameters of the theory.
5 pages
http://arxiv.org/abs/1402.5880
Fermi-bounce Cosmology and scale invariant power-spectrum
Stephon Alexander, Cosimo Bambi, Antonino Marciano, Leonardo Modesto
We develop a novel non-singular bouncing cosmology, due to the non-trivial coupling of general relativity to fermionic fields. The resolution of the singularity arises from the negative energy density provided by fermions. Our theory is ghost-free because the fermionic operator that generates the bounce is equivalent to torsion, which has no kinetic terms. The physical system is minimal in that it consists of standard general relativity plus a topological sector for gravity, a U(1) gauge field reducing to radiation at late times and fermionic matter described by Dirac fields with a non-minimal coupling. We show that a scale invariant power-spectrum generated in the contracting phase can be recovered for a suitable choice of the fermion number density and the bare mass, hence providing a possible alternative to the inflationary scenario.
Comments: 6 pages
  • #2,131
http://arxiv.org/abs/1402.6613
Numerical simulations of a loop quantum cosmos: robustness of the quantum bounce and the validity of effective dynamics
Peter Diener, Brajesh Gupt, Parampreet Singh
(Submitted on 26 Feb 2014)
A key result of isotropic loop quantum cosmology is the existence of a quantum bounce which occurs when the energy density of the matter field approaches a universal maximum close to the Planck density. Though the bounce has been exhibited in various matter models, due to severe computational challenges some important questions have so far remained unaddressed. These include the demonstration of the bounce for widely spread states, its detailed properties for the states when matter field probes regions close to the Planck volume and the reliability of the continuum effective spacetime description in general. In this manuscript we rigorously answer these questions using the Chimera numerical scheme for the isotropic spatially flat model sourced with a massless scalar field. We show that as expected from an exactly solvable model, the quantum bounce is a generic feature of states even with a very wide spread, and for those which bounce much closer to the Planck volume. We perform a detailed analysis of the departures from the effective description and find some expected, and some surprising results. At a coarse level of description, the effective dynamics can be regarded as a good approximation to the underlying quantum dynamics unless the states correspond to small scalar field momenta, in which case they bounce closer to the Planck volume, or are very widely spread. Quantifying the amount of discrepancy between the quantum and the effective dynamics, we find that the departure between them depends in a subtle and non-monotonic way on the field momentum and different fluctuations. Interestingly, the departures are generically found to be such that the effective dynamics overestimates the spacetime curvature, and underestimates the volume at the bounce.
46 pages, 26 figures
briefly noted as possibly of interest:
http://arxiv.org/abs/1402.6332
Common origin of reactor and sterile neutrino mixing
Alexander Merle, Stefano Morisi, Walter Winter
(Submitted on 25 Feb 2014)
If the hints for light sterile neutrinos from short-baseline anomalies are to be taken seriously, global fits indicate active-sterile mixings of a magnitude comparable to the known reactor mixing. We therefore study the conditions under which the active-sterile and reactor mixings could have the same origin in an underlying flavour model. As a starting point, we use μ−τ symmetry in the active neutrino sector,…
http://arxiv.org/abs/1402.6319
A Globular Cluster Toward M87 with a Radial Velocity < -1000 km/s: The First Hypervelocity Cluster
Nelson Caldwell (CfA), Jay Strader (Michigan St), Aaron J. Romanowsky (San Jose St/Santa Cruz), Jean P. Brodie (Santa Cruz), Ben Moore (Zurich), Jurg Diemand (Zurich), Davide Martizzi (Berkeley)
  • #2,132
http://arxiv.org/abs/1402.6708
A one-dimensional action for simplicial gravity in three dimensions
Wolfgang M. Wieland
This article presents a derivation of the Ponzano--Regge model from a one-dimensional spinor action. The construction starts from the first-order Palatini formalism in three dimensions. We then introduce a simplicial decomposition of the three-dimensional manifold and study the discretised action in the spinorial representation of loop gravity. A one-dimensional refinement limit along the edges of the discretisation brings us back to a continuum formulation. The three-dimensional action turns into a line integral over the one-skeleton of the simplicial manifold. All fields are continuous but have support only along the one-dimensional edges. We define the path integral, and remove the redundant integrals over the local gauge orbits through the usual Faddeev--Popov procedure. The resulting state sum model reproduces the Ponzano--Regge amplitudes.
19 pages, two figures
not loop-and-allied QG but possibly of general interest:
http://arxiv.org/abs/1402.6980
Inflationary schism after Planck2013
Anna Ijjas, Paul J. Steinhardt, Abraham Loeb
(Submitted on 27 Feb 2014)
Classic inflation, the theory described in textbooks, is based on the idea that, beginning from typical initial conditions and assuming a simple inflaton potential with a minimum of fine-tuning, inflation can create exponentially large volumes of space that are generically homogeneous, isotropic and flat, with nearly scale-invariant spectra of density and gravitational wave fluctuations that are adiabatic, Gaussian and have generic predictable properties. In a recent paper, we showed that, in addition to having certain conceptual problems known for decades, classic inflation is for the first time also disfavored by data, specifically the most recent data from WMAP, ACT and Planck2013. Guth, Kaiser and Nomura and Linde have each recently published critiques of our paper, but, as made clear here, we all agree about one thing: the problematic state of classic inflation. Instead, they describe an alternative inflationary paradigm that revises the assumptions and goals of inflation, and perhaps of science generally.
7 pages, 2 tables
:biggrin:
http://arxiv.org/abs/1402.6703
The Characterization of the Gamma-Ray Signal from the Central Milky Way: A Compelling Case for Annihilating Dark Matter
Tansu Daylan, Douglas P. Finkbeiner, Dan Hooper, Tim Linden, Stephen K. N. Portillo, Nicholas L. Rodd, Tracy R. Slatyer
Past studies have identified a spatially extended excess of ~1-3 GeV gamma rays from the region surrounding the Galactic Center, consistent with the emission expected from annihilating dark matter. We revisit and scrutinize this signal with the intention of further constraining its characteristics and origin. By applying cuts to the Fermi event parameter CTBCORE, we suppress the tails of the point spread function and generate high resolution gamma-ray maps, enabling us to more easily separate the various gamma-ray components. Within these maps, we find the GeV excess to be robust and highly statistically significant, with a spectrum, angular distribution, and overall normalization that is in good agreement with that predicted by simple annihilating dark matter models. For example, the signal is very well fit by a 31-40 GeV dark matter particle annihilating to b quarks with an annihilation cross section of sigma v = (1.4-2.0) x 10^-26 cm^3/s (normalized to a local dark matter density of 0.3 GeV/cm^3). Furthermore, we confirm that the angular distribution of the excess is approximately spherically symmetric and centered around the dynamical center of the Milky Way (within ~0.05 degrees of Sgr A*), showing no sign of elongation along or perpendicular to the Galactic Plane. The signal is observed to extend to at least 10 degrees from the Galactic Center, disfavoring the possibility that this emission originates from millisecond pulsars.
Comments: 26 pages, 28 figures
http://arxiv.org/abs/1402.6795
Multidimensional finite quantum gravity
Leonardo Modesto
We advance a class of unitary higher derivative theories of gravity that realize an ultraviolet completion of Einstein general relativity in any dimension. This range of theories is marked by an entire function, which averts extra degrees of freedom (including poltergeists) and improves the high energy behavior of the loop amplitudes. It is proved that only one-loop divergences survive and the theory can be made super-renormalizable regardless of the spacetime dimension. Moreover, using the Pauli-Villars regularization procedure introduced by Diaz-Troost-van Nieuwenhuizen-van Proeyen (DTPN) and applied to Einstein's gravity by Anselmi, we are able to remove the divergences also at one-loop, making the theory completely finite in any dimension as expected by Anselmi and Asorey-Lopez-Shapiro.
8 pages, 2 figures
  • #2,133
Useful review, could serve as source for Planck star discussion:
http://arxiv.org/abs/1403.1198
Primordial Black Holes: sirens of the early Universe
Anne M. Green
(Submitted on 5 Mar 2014)
Primordial Black Holes (PBHs) are, typically light, black holes which can form in the early Universe. There are a number of formation mechanisms, including the collapse of large density perturbations, cosmic string loops and bubble collisions. The number of PBHs formed is tightly constrained by the consequences of their evaporation and their lensing and dynamical effects. Therefore PBHs are a powerful probe of the physics of the early Universe, in particular models of inflation. They are also a potential cold dark matter candidate.
21 pages. To be published in "Quantum Aspects of Black Holes", ed. X. Calmet (Springer, 2014)
Briefly noted as possibly relevant to discussion thread:
http://arxiv.org/abs/1403.1146
Why I am not a QBist
Louis Marchildon
Quantum Bayesianism, or QBism, is a recent development of the epistemic view of quantum states, according to which the state vector represents knowledge about a quantum system, rather than the true state of the system. QBism explicitly adopts the subjective view of probability, wherein probability assignments express an agent's personal degrees of belief about an event. QBists claim that most if not all conceptual problems of quantum mechanics vanish if we simply take a proper epistemic and probabilistic perspective. Although this judgement is largely subjective and logically consistent, I explain why I do not share it...
  • #2,134
One thing that I miss from discussions about cosmogony, cosmology in general, star system formation, is the role of turbulence (if any) in structure formation. The author made some mention talking about fluctuations, which made me happy.
There are some quite good papers about it, but I am afraid of posting them here since people could call it crackpotish. Not that I agree with everything, but they have a flavor of oddness on them, like you'd expect from the mind of Alven (though they have nothing to do with electric universe or similar).
  • #2,135
Chronos keeps spotting good papers about the possible composition of DM by 7 keV sterile neutrinos. Here is another that came out this month
http://arxiv.org/abs/1403.0954
Resonantly-Produced 7 keV Sterile Neutrino Dark Matter Models and the Properties of Milky Way Satellites
Kevork N. Abazajian
(Submitted on 4 Mar 2014)
Sterile neutrinos produced through a resonant Shi-Fuller mechanism are arguably the simplest model for a dark matter interpretation origin of the recent unidentified X-ray line seen toward a number of objects harboring dark matter. Here, I calculate the exact parameters required in this mechanism to produce the signal. The suppression of small scale structure predicted by these models is consistent with Local Group and high-z galaxy count constraints. Very significantly, the parameters necessary in these models to produce the full dark matter density fulfill previously determined requirements to successfully match the Milky Way Galaxy's total satellite abundance, the satellites' radial distribution and their mass density profile, or "too big to fail problem." I also discuss how further precision determinations of the detailed properties of the candidate sterile neutrino dark matter can probe the nature of the quark-hadron transition, which takes place during the dark matter production.
4 pages, 3 figures.
The author (PhD 2001, 60 papers with good average cites) is someone I think I will be keeping track of.
  • Beyond the Standard Models
