Magnetic force relation with v and r?
In summary, the equation F=qvBsinθ states that the strength of the magnetic force acting on a charge moving in a magnetic field is inversely proportional to the speed of the charge and is maximum when the charge is at the center of the field. Additionally, it is possible for a charge to move around a circle of a given radius if its speed is greater than the magnetic field's force.
Hardik Batra
130
(1) Magnetic force acting on charge moving in magnetic field is given by,
F = qvBsinθ...F ∝ v
This means that if moving charge particle has more velocity then more magnetic force will act on it.
Due to more magnetic force the direction of velocity changes rapidly and it will move on the circular path of smaller radius.
(2). Now, Radius of circular path , R = mv/qB.
Here, R ∝ v
This equation implies that if velocity of charge particle is more then it will move on a circular path of larger radius.
In the first situation if v is more then it will move on a circular path of smaller radius.
and in the second situation if v is more then it will move on a circular path of larger radius.
There is a contradiction or am i misleading?
Please correct me if i wrong.
True.
False. Realize that since it's moving faster, even more force is needed to keep it moving in a circle of a given radius.
Likes Hardik Batra
Thanks.
There are two different situations. In the first case we are visualising the relationship between the magnetic force acting on the body due to the velocity. in other words, the force depends on the velocity. The second relation keeps F constant and describes the motion of the charge in the B field. Hope that helps you
##\begin{cases}
F=q \cdot v \cdot B \cdot sin(θ)\\
a=\frac{F}{m}\\
a=\frac{v^2}{r}\\
\end{cases}\Rightarrow r=v \cdot \frac{m}{q \cdot B \cdot sin(θ)}##
θ(angle between B-field and v (speed)) has to be 90° aka ##\frac{2\pi}{4}##, because otherwise F(force), θ nor r(radius), were not constant.
Related to Magnetic force relation with v and r?
1. How does velocity affect the magnetic force between two objects?
The magnetic force between two objects is directly proportional to the velocity of the objects. This means that as the velocity increases, the magnetic force also increases. However, the direction of the magnetic force depends on the direction of the velocity and the orientation of the magnetic fields of the objects.
2. Is there a relationship between the distance between two objects and the magnetic force between them?
Yes, there is a relationship between the distance (r) between two objects and the magnetic force between them. According to the inverse square law, the magnetic force decreases as the distance between two objects increases. This means that the force is stronger when the objects are closer together and weaker when they are farther apart.
3. How does the direction of the magnetic field affect the magnetic force between two objects?
The direction of the magnetic field plays a crucial role in determining the direction of the magnetic force between two objects. The magnetic force is strongest when the magnetic fields of the objects are parallel and weakest when they are anti-parallel. Additionally, the direction of the magnetic force is perpendicular to both the velocity and the magnetic field.
4. Can the magnetic force between two objects be zero?
Yes, the magnetic force between two objects can be zero. This occurs when the objects have no relative velocity or when their magnetic fields are perpendicular to each other. In these cases, the magnetic force does not contribute to the overall force between the objects.
5. What are the units of magnetic force?
The units of magnetic force are newtons (N) in the SI (International System of Units) system. In the CGS (centimeter-gram-second) system, the unit of magnetic force is dyne (dyn). The direction of the force is indicated by a vector, so it is often represented in the form of N/m or dyn/cm, which is force per unit length.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
