Magnetic forces in planetary orbits
In summary, the conversation discusses the role of magnetic fields in the formation and stability of planets and their orbits. While magnetic fields do play a significant role in the initial stages of planet and star formation, their influence diminishes as the objects build mass. However, there is an ongoing effect of magnetic fields on planetary atmospheres, which can impact the orbits of satellites in low Earth orbit. Overall, the gravitational force has a stronger influence on orbits compared to magnetic fields.
blueberrynerd
This suddenly entered my mind while studying magnetic fields. I know of course that it is the gravitational force that holds the planets in orbit, but do their magnetic fields also have an effect, even by an infinitesimal amount? Do the magnetic fields of the planets have a small influence on each other's orbits?
:smile:
It seems magnetic fields of planets do have an influence on each other's orbits. Here is a quotation from Scientific American:
“Magnetic fields also muck up planet and star formation, as Susana Lizano of the Universidad Nacional Autonoma de México in Morelia explained. The interstellar clouds of gas and dust out of which planets and stars coalesce are threaded with magnetic fields—weak ones, a thousandth as strong as Earth’s. (Astronomers gauge the field strength by looking at how light from the dust is polarized.) As these clouds collapse, basic theory predicts the field should intensify a billionfold. But if that happened, the field would become powerful enough to stop the collapse. Even leaving this problem aside, as the cloud settles into a swirling disk, the field should bring the swirling motion in the inner part of the disk to a halt. Somehow the fields must dissipate, perhaps through a variant of induction-stove effect.
Even when the magnetic field weakens, it sculpts the nascent planetary system. It causes gas to revolve around the star more slowly than freely orbiting objects do. Embryonic planets thus experience a drag force and spiral inward. The field also stabilizes the disk, keeping it from fragmenting—further evidence that planets form by step-by-step agglomeration rather than gravitational breakup of the disk. All in all, Lizano built a persuasive case that astrophysicists ignore magnetism at their peril.”
http://blogs.scientificamerican.com...-play-an-underappreciated-role-in-the-cosmos/
No.
Bobbywhy said:
It seems magnetic fields of planets do have an influence on each other's orbits. Here is a quotation from Scientific American: ...
Read the article again. Magnetism appears to play some role in the initial formation of a star and the protoplanetary disk. The role diminishes as the protostars and protoplanets build mass. Once the star system is formed, the affect on orbits is vanishingly small.
There is an ongoing magnetic effect: It puffs up planetary atmospheres. Right now the Sun is approaching solar max, and the Earth's atmosphere is puffing as a result. The F10.7 radio flux from the Sun is a fairly good indicator of how "puffed up" the Earth's atmosphere will be. The variations in magnetic flux over the course of the solar cycle has a measurable effect on the atmospheric drag on satellites in low Earth orbit.
Thank you, D H! I reread the article and found that you are correct: once planets form magnetism's effect is vanishingly small.
Thanks! That clears up a lot. :smile:
For a magnetic dipole, I believe the field falls of as the cube of the distance so the inverse square of the gravitational field beats it pretty damn soon as you get a long way away - whatever the relative forces / fields are, nearby.
Related to Magnetic forces in planetary orbits
1. What is a magnetic force in planetary orbits?
A magnetic force in planetary orbits is a force exerted by the magnetic field of a planet on an object in its orbit, such as a moon or a spacecraft. This force can affect the trajectory and speed of the object.
2. How do magnetic forces affect planetary orbits?
Magnetic forces can affect planetary orbits in various ways. They can cause changes in the shape and orientation of the orbit, alter the speed and direction of the orbiting object, and even lead to orbital resonances and disruptions in the orbit.
3. What causes magnetic forces in planetary orbits?
Magnetic forces in planetary orbits are caused by the interaction between the magnetic fields of the planet and the orbiting object. This interaction is based on the principle of electromagnetism, where charged particles in motion create magnetic fields and can be affected by existing magnetic fields.
4. How do scientists study magnetic forces in planetary orbits?
Scientists study magnetic forces in planetary orbits through various methods, including mathematical models, computer simulations, and observations using spacecraft and telescopes. They also use data collected from previous missions and experiments to better understand the nature and effects of these forces.
5. Can magnetic forces affect the habitability of a planet?
Yes, magnetic forces can have a significant impact on the habitability of a planet. For example, a strong magnetic field can protect a planet's atmosphere and surface from harmful solar radiation, making it more suitable for life. On the other hand, a weak or unstable magnetic field can lead to the loss of atmosphere and make a planet less habitable.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
