Math Myth: The rationals are numbers
  • I
  • Thread starter Greg Bernhardt
  • Tags
    Numbers
In summary, the conversation discusses the concept of rational numbers as equivalence classes and the difference between equality and equivalence relations. It also delves into the perspective of constructing quotients from different sets and how it affects the understanding of rational numbers. The main point is that while we commonly treat ##1## and ##\frac{12}{12}## as equal, they are technically not the same as they belong to different equivalence classes. However, this does not diminish their value as rational numbers and the emphasis should be on the structure rather than the elements.
  • #141
How can you prove that ##\frac{12}{12}\neq 1##? Show me a proof if you know.What is your definition of equality?
Mathematics news on Phys.org
  • #142
pinball1970 said:
The sets are not equal
In mathematics, a set is a collection of distinct elements.[1][2][3] The elements that make up a set can be any kind of things: people, letters of the alphabet, numbers, points in space, lines, other geometrical shapes, variables, or even other sets.[4] Two sets are equal if and only if they have precisely the same elements.[5]
12/12 has 12 elements 1 has 1, could you use that?
I thought that 12/12 had infinitely many elements, each element being an ordered pair. Each ordered pair would naturally be equivalent to every other ordered pair in the set under our standard equivalence relation for the rationals. An ordered pair, following the Kuratowski definition would be a two-element set {a,{a,b}}. In the case of this particular equivalence class, each ordered pair would collapse to {a,{a}}.
So the infinite set would be something like { {1,{1}}, {2,{2}}, {3,{3}}, ... {12,{12}}, ... }
We would likely adopt the notation where 0 = {}, 1 = {0}, 2 = {0,1}, etc. So, for instance, 12 would be a twelve element set.
Of course, this is assuming that "12/12" is to be interpreted as a ratio of naturals. If it is to be a ratio of signed integers, there are additional layers to the construction.
Meanwhile, we all understand that none of this folderol is relevant to what someone means when they write 12/12=1.
Likes dextercioby and pbuk
  • #143
The thread seems to have run its course, and is now closed.
  • General Math
  • General Math
  • General Math
  • General Math
  • Math Proof Training and Practice
