- #36
- 24,492
- 15,013
Sure, there are also the neutral-current reactions. The point is that it's with neutrinos as with any other (von Neumann) measurements in QT. You get some result of the measured quantities with probabilities given by Born's rule using the state the measured object is prepared in.Vanadium 50 said:First, it is absolutely not true that neutrinos only interact with matter in flavor eigenstates. There are neutral current events: ν + X → ν + X.
Second, the term "flavor eigenstate" is confusing people. It may be helpful to think "flavor projection of the mass eigenstate" instead.
If you had mass resolution that was good enough, the decay [itex]X \rightarrow Y + e^+ + \nu_1[/itex] would occur with twice the rate as [itex]X \rightarrow Y + e^+ + \nu_2[/itex] (I am going to use positron emission as an example so I don't have a zillion overlines to include.)
If I had a beam of pure [itex]\nu_1[/itex], it would have twice the reaction cross-section on a target of Y as [itex]\nu_2[/itex]. (The inverse process)
If I get a beam of neutrinos from X decay and use them to induce the inverse process on a target of Y, the rate is 5/9 in appropriate units.
Now, if I cannot tell whether I have a [itex]\nu_1[/itex] or [itex]\nu_2[/itex] in flight, the two states interfere (which some people call "oscillate") and the strength varies (with L/E) between 1 and 1/9.
The phenomenon is called "oscillations" because all kinds of similar cases are called "oscillations" (e.g., Rabi oscillations). Of course, everything is described by Hilbert space vectors and operators as for any quantum system.
