askor
- 169
- 9
How did he found x = 1, y = 0, z = 0 and x = 1, y = 1, z = 2?
A parametric representation of a solution set is a way to describe all the possible solutions to a system of equations using variables (known as parameters). It allows for an infinite number of solutions to be represented in a concise and organized way.
A parametric representation of a solution set is useful because it allows for a visual and algebraic understanding of a system of equations. It can also help to identify patterns and relationships between the variables and solutions.
To create a parametric representation of a solution set, first solve the system of equations for one variable in terms of the others. Then, assign a parameter to each of the remaining variables and express the solutions in terms of the parameters.
One advantage of using a parametric representation of a solution set is that it can simplify complex systems of equations. It also allows for a more thorough understanding of the relationships between the variables and solutions.
One limitation of using a parametric representation of a solution set is that it may not always provide a unique solution. It also requires a good understanding of algebra and may not be suitable for more advanced systems of equations.
