Partial pressure of He in this gas mixture
In summary, partial pressure is the pressure exerted by a single gas in a mixture of gases, calculated by multiplying the total pressure by the mole fraction of the gas. It is important in understanding gas behavior and solubility, and is affected by temperature according to the ideal gas law. The unit of measurement is typically atmospheres, millimeters of mercury, or kilopascals.
Levy98
A container at 0.877 atm contains only 0.500 g H2 (g) and 0.750 g He (g).
What is the partial pressure of He?
P(HE) = 0.877*0.75/(0.75+0.5) = 0.5262 atm
My progress:
is this right?
You need to work with the number of moles of each, rather than the mass of each.
:welcome:
Likes Astronuc and Chestermiller
Related to Partial pressure of He in this gas mixture
1. What is partial pressure of He in a gas mixture?
The partial pressure of He in a gas mixture refers to the pressure that would be exerted by the He gas if it were the only gas present in the same volume at the same temperature. It is a measure of the concentration of He in the mixture.
2. How is partial pressure of He calculated in a gas mixture?
The partial pressure of He can be calculated by multiplying the total pressure of the gas mixture by the mole fraction of He in the mixture. The mole fraction is the ratio of the number of moles of He to the total number of moles in the mixture.
3. Why is partial pressure important in gas mixtures?
Partial pressure is important in gas mixtures because it helps determine the behavior of each gas component in the mixture. It also plays a role in gas diffusion, gas solubility, and gas reactions.
4. How does temperature affect the partial pressure of He in a gas mixture?
According to the ideal gas law, the partial pressure of He in a gas mixture is directly proportional to the temperature of the mixture. As temperature increases, the partial pressure of He also increases.
5. What is the unit of measurement for partial pressure of He?
The unit of measurement for partial pressure of He is typically in units of pressure, such as atmospheres (atm) or kilopascals (kPa). However, it can also be expressed in other units such as torr or millimeters of mercury (mmHg).
  • Materials and Chemical Engineering
