parch
- 17
hi, Is there any way, to find a point whether it lies inside a irregular cube. other than finding volume. where cube can be rotated in any direction.
The most common method is to use the point-in-polygon algorithm which checks if a given point lies within a polygon or not. In this case, the cube is treated as a 3D polygon with 6 faces.
Yes, an irregular cube can have different dimensions for each side, as long as it has 6 faces and satisfies the definition of a cube - all 6 faces are square and perpendicular to each other.
Yes, there is a formula based on the dot product of vectors. The dot product of the vector connecting the point to a vertex of the cube and the normal vector of a face should have the same sign for all faces if the point is inside the cube.
No, a point on the surface of a cube is considered to be outside of the cube. This is because the point-in-polygon algorithm only checks for points inside the boundaries of a shape, not on the boundaries.
Yes, there are a few special cases such as when the point is exactly on a vertex or edge of the cube, or when the cube is skewed or tilted. In these cases, a more advanced algorithm may be needed to accurately determine if the point is inside the cube.
