Power, force, velocity and tension...
  • #36
MatinSAR said:
We don't care about whaat causes the motion.
You want to find speed of the object using ##P=\vec F. \vec v## and you have power of the Tension force so that F in above equation represents tension force.
why dont we care about it? how are we supposed to find the velocity then?
  • #37
hello478 said:
so which force am i supposed to use to calculate the velocity?
The ##F## in ##P = \vec F \cdot \vec v## is the one that does the work. The motor does the work and the only way it is exerting a force is in the form of tension in the cable. The ##T## you calculated in a .
We don't care about what causes the motion: we are given that the speed is constant (##\Rightarrow F_{net}=0##) and we know the opposing force component along the slope (##-mg\sin\theta## -- the minus sign is because its direction is to the left. g = 9.8 m/s2). So we know ##F## in #33 (aka The ##T## you calculated in a ).
(as you can see I also didn't bother to draw more than just ##F## in #33)
Likes hello478
  • #38
Earlier you've said :
yes, so then i would use the tension force and multiply with velocity, because it is the force causing upward motion? is this explanation correct?
And I disagree. You should use the force that is related to the motor power. It doesn't necessary for the force to cause upward/downward motion.
My interpretation of the question is apparently different from @haruspex . I can't understand why in his opinion the force is in the downslope direction. I think it is better for you to use the ideas of @BvU and @haruspex . I prefer not to contribute anymore. This way you don't get misled by different ideas.
  • #39
ok i sort of get it now... thank you very much!
