Projectile with different landing height
In summary, to find the total time of flight for a handball projected at an angle of 30 degrees from a 20 meter tower with an initial vertical velocity of 10 ms and an initial horizontal velocity of 20 ms, you can use the equation y = 20 + 10t - 4.9t^2 to describe the position of the handball at any given time t. By solving for 0, you can find the total time of flight.
bionut
54
A handball is projected at an angle of 30 degrees with the horizontal from a 20 meter tower with an initial vertical velocity of 10 ms and an initial horizontal velocity of 20 ms. Find the total time of flight.
I know that 0=Vi + at will give me time up X2 will give total time for a projectile with same landing height, but what do I need to use if it has a different landing height?
IIRC that's a lot more info than you need, you only need a function to describe the position of y at any given t, and solve for 0. Since they didn't give you a vector, but an explicit description of vertical velocity, this shouldn't be hard.
If your position is initially 20m, then
y = 20 +...
Your velocity is 10 m/s
y = 20 + 10t
Minus acceleration due to gravity..
Should describe your projectile at any t.
Related to Projectile with different landing height
What is a projectile with different landing height?
A projectile with different landing height refers to an object that is launched or thrown into the air and eventually lands at a different height from where it was released.
What factors affect the landing height of a projectile?
The landing height of a projectile is affected by several factors such as the angle of launch, initial velocity, air resistance, and the height at which it was released.
How does the angle of launch affect the landing height of a projectile?
The angle of launch has a significant impact on the landing height of a projectile. A higher launch angle will result in a higher landing height, while a lower launch angle will result in a lower landing height.
What is the relationship between initial velocity and landing height of a projectile?
The initial velocity of a projectile is directly proportional to its landing height. This means that the higher the initial velocity, the higher the landing height will be.
How does air resistance impact the landing height of a projectile?
Air resistance, also known as drag, can reduce the landing height of a projectile. This is because air resistance opposes the motion of the projectile, causing it to lose some of its initial velocity and therefore land at a lower height.
21K
