Pushing a block against the wall of an elevator that is accelerating
  • #36
Both g and a are negative (or they are both positive) as long as they are in the same direction - downwards. You need a minus in front of the "ma" term because the friction force is opposite to the weight, not because the acceleration is negative. This is so as long as the acceleration is less than g.
If the acceleration becomes larger than g, the friction force has to acts downwards, otherwise the block will move towards the ceiling of the elevator. The formula for F will change for this case becaue the friction and weight act in the same direction.
Likes MatinSAR
  • #37
So...
You are disagree with my answer in post 1? (for condition that "a" is less than g)
I only need to find answer for first condition. (a < g)
  • #38
For a<g, the force (F) should be less than for the case with zero acceleration. And both accelerations have the same sign. Obviously, your guess is not right. Why don't you write Newton's second law rather than guessing? It's just one line.
Likes MatinSAR
  • #39
If |a|<|g| : (I consider down as negative.)
##u_{s}F - mg = ma##​
So we have :
## F = \dfrac {m(g+a)} {u_s}## (a<0 so F<##\dfrac {mg} {u_s}##)
  • #40
So, the formula that holds for all a is:
F = |mg-ma|/us - the absolute value of the resultant force is what matters to figure out the friction.
As an aside, since most elevators are suspended with cables, you might find that it is very difficult to make the elevator accelerate downward with an acceleration greater than g. Have you ever pushed a car up a hill with a rope? :cool:
Likes MatinSAR
  • #41
So we have :
Let's define down as negative. The elevator has an acceleration of -ael. For an elevator accelerating downward, this implies ael>0.
In the frame of the elevator, there are three forces on the brick
1) gravity = -mg
2) friction = μFnormal
3) a pseudo force due to the accelerating reference frame f=mael
If the brick is to remain stationary in this frame, the sum of the forces must be zero
-mg+μFnormal+mael=0
giving
Fnormal=(m/μ)(g-ael)
If you define a = -ael, this becomes what you have in your OP. This is a confusing definition, which is why I told you that you needed to define "a" clearly in an earlier post.
In an external non-moving frame, the acceleration of the brick (-abr) and of the elevator (-ael) must be identical for the brick to remain "stationary".
In this frame, there are two forces on the brick
1) gravity = -mg
The force on the brick is
-mabr=-mg+μFnormal
giving
-abr=-g+μFnormal/m=-ael
which gives
Likes MatinSAR
  • #42
So we have :
If you consider down as negative, both g and a should be negative. You are not consistent in your signs.
You should have ##u_{s}F - mg = - ma##
Likes MatinSAR
  • #43
