Regarding Cantor's diagonal proof
  • I
  • Thread starter ATAUD
  • Tags
    Proof
In summary, the conversation discusses the concept of infinity and how it relates to Cantor's diagonal proof. The proof shows that there can be no counting of the real numbers and that the "infinity" of the real numbers (##\aleph##1) is a level above the infinity of the counting numbers (##\aleph##0). There is a debate about whether the diagonal is changed or copied and changed in the proof, with the conclusion that it is not changed. The question also raises the issue of adding or subtracting from infinity and how it relates to the diagonal. However, it is noted that the diagonal is a real number, not infinity, and should not be treated as such. The conversation ends with a discussion about
  • #71
stevendaryl said:
This discussion is completely fruitless. @AlienRenders doesn't seem to know what he's talking about. I should put that more strongly: He doesn't know what he's talking about. He is very confused about Cantor's proof, but rather than attempting to understand it, he thinks of himself as competent to show it wrong. This might sound boring, but Physics Forums is the place to go to understand mainstream mathematics and science, not to overturn it. Cantor's arguments are very thoroughly mainstream---they are the foundation of pretty much all advanced mathematics for the last 100 years or so. If they are going to be overturned by some brilliant new way of thinking, Physics Forums is not the place for that. I'm going to request that this thread be closed.
So because you get completely destroyed in your arguments, you resort to appeals to authority?
  • #72
Physics Forums is about mainstream mathematics and science. Mainstream mathematics and science can certainly be wrong, but THIS is not the place to overturn it.
  • #73
Fair enough. I was just looking for the proof that the digits and rows were one to one. If that proof doesn't exist, then so be it. I'm satisfied that Cantor's proof is incomplete.
  • #74
I think you are extremely confused. Digits and rows of WHAT? Cantor's proof is a proof by contradiction: You ASSUME that there are as many real numbers as there are digits in a single real number, and then you show that that leads to a contradiction. You want a proof of something that Cantor proves was false.
  • #75
AlienRenders said:
@FactChecker That's an extremely weak argument. The rows and digits are not one to one.
What? That is just obviously wrong. I will leave this discussion to others.
  • #76
You know very well what digits and rows. The diagonal uses it for goodness' sake. Please stop this nonsense.
When you ASSUME that there are as many real numbers as there are digits in a single real number, this isn't true for N either. It's a given that it isn't true. If it's not true for N, what does it matter that it's not true for R?
  • #77
Let me ask you this. How many rows in my list match a row in the infinite identity matrix when comparing digit by digit? Yet, this is not my entire list.
  • #78
It's a proof by contradiction. You assume something, then you show that that leads to a contradiction. That proves that the assumption is false.
The assumption that Cantor started with was that there are as many real numbers as there are digits in a single real number. He proved that that is false.
Now you seem to be agreeing with Cantor's conclusion.
You are very confused. A real number has as many digits as there are natural numbers. Every real number ##r \geq 0## can be represented by the form:
##r = K + \sum_{n=0}^{\infty} r_n##
where ##r_n## is the ##n^{th}## digit of ##r## and ##K## is the integer part of ##r##. That notation assumes that there is exactly one digit of ##r## for every natural number ##n##.
  • #79
@stevendaryl You're ignoring what I'm saying and throwing insults. I'll ask my same question again.
That's all of the rows from the identity matrix. There are infinitely many of them. They are even N of them. But it is not the entirety of MY list. This does not mean that |N| > |N|. But for some reason, it's enough to prove that |R| > |N|. That's nonsense.
I'm not going to quote your comment because you're still using two different sets that don't have a bijection.
  • #80
What do you think a real number is? What do you think a "decimal expansion" means? You are confused about the most basic concepts of mathematics.
Have you never learned how to represent a real number as an infinite sum?
  • #81
@stevendaryl You're again using the same variable n to index into two sets that don't have a bijection. You're just avoiding the issue now.
  • #82
Are there not infinitely many?
Yet it is not my entire list N which consists of only strings in base 2.
How can this be if there is a bijection between the rows and digits of my list?
Just answer these questions.
  • #83
Do you really not understand how to compute the ##n^{th}## decimal of a real number, when ##n## is any nonnegative integer?
  • #84
You don't understand the very basics. Your questions are not relevant until you understand the basics.
  • #85
If ##r## is a real number greater than or equal to 0, then let's define ##floor(r)## to be the largest integer that is less than or equal to ##r##. Now, we define the ones place of ##r## to be:
##ones(r) = floor(r) - floor(r/10) \cdot 10##
Then we can define the ##n^{th}## place of ##r## via:
##r_n = ones(r \cdot 10^n)##
That's a map from the naturals ##n## to the digits of ##r##.
  • #86
This thread needs to be closed. It is a waist of time, energy, and expertise.
  • #87
This thread is obviously running in - unpleasant - circles. There is nothing wrong with Cantor's argument.
It seems as if there is no common basis for a discussion anymore and we had to delete a couple of post which became personal.
Thread closed.
Likes Klystron and FactChecker
  • General Math
