Replacing gas in a fixed volume without losing pressure?
In summary, the conversation discussed the experimental setup for forming methane hydrates and the challenge of replacing methane molecules with carbon dioxide. Ideas were suggested such as using a separation process and a gas booster, while also considering potential chemical and physical effects. The experiment aims to examine the kinetics of a CO2-CH4 exchange and measure pH. Suggestions were also made to flush the system with an inert liquid and use helium or a gas centrifuge for separation.
methanehydrate
Hi everyone! Sorry if I am posting this in the wrong place.
Im doing my Msc in chemistry, and I have a little problem with my current experimental setup. This setup have been used before by Phd students, but not for the same experiments I want to do. Any advice would be greatly appriciated!
The experimental setup consists of a stainless steel cell with a fixed volume placed inside an incubator (large fridge). There are three valves connected to the incubator, (1) introduction of water (by applying a vacuum to the cell beforehand) and evacuating the cell of water, (2) application of pressure, which is connected to a chosen gas flask, (3) a sampling valve for gas sampling and evacuating the cell of gas.
Im want to form methane hydrates, which form at high pressures and low temperatures. I fill the cell with an amount of water, and apply pressure determined through the pressure of the gas flask. The container is then cooled to form hydrates, which gives two phases: hydrate and excess methane gas. What I would like to do is apply carbon dioxide gas, which is thought to replace the methane molecules in the hydrates. However, if I evacuate all the methane gas from the container, the hydrates will melt. I need to evacuate the cell of excess methane gas, while adding CO2 gas without a pressure drop.
I was thinking of gradually adding CO2 gas, while evacuating the excess methane gas from another valve. But I think they will form a mixture through diffusion, which makes it hard to completely evacuate the methane gas, no matter how many times i try.
Any ideas?
If your temperature remains low enough, the bulk of the methane hydrate will remain frozen.
There will be some residual methane in any event as you introduce the CO2, from slow breakup of methane hydrate. So you must expect some mixing.
What reactions are you working to determine? CO2 mixes very well with water and gives rise to carbonic acid.
So there will be both chemical as well as physical effects to monitor in your experiment.
You will need to devise a separation process - for example, if one of the gasses is lighter than the other, remove the lighter gas from the top of the cell while introducing the heavier gas at the bottom. Or vice versa.
If you can get any kind of separation you can then continue to bleed off the "unwanted" gas plus an admixture of the CO2 by injecting CO2 at an over-pressure, and continue to flow the gasses in and out for a longer time. Then the CO2 will slowly dilute the remaining methane, while maintaining pressure. When you are done you can reduce the CO2 pressure.
First, thank you for your answer.
As one of the valves is located at the bottom of the cell (introduction of water), it might be possible to attach this one to the CO2 source after the hydrates have been formed? Considering that methane is the lighter gas, this can then be removed through the sampling valve at the top of the cell, like you explained. However as the hydrates which form in the cell are solid will the CO2 be able to "pass" this solid phase and displace the methane?
What about replacing the sampling valve with a "safety valve" that automatically releases gas above a certain set pressure. By applying CO2 gas at the bottom, this valve will "bleed of" gas higher than this set pressure, eg at pressures above 80bar. I guess this method will consume much gas before the cell is diluted of methane?
I know there is also a gas booster available on my faculty. By incorporating this, the pressures are not limited by the pressure in the gas flasks.
I would like to examine the kinetics of a CO2-CH4 exchange in the hydrates. Pressure and temperature will be logged on a computer, while gas sampling will be analyzed and quantified on a GC. I am aware of the high solubility of CO2, which is why I would probably measure the pH after each experiment.
Seems to me the solution might be to flush the system with an inert liquid such as propane before introducing the CO2.
That way you do not have unknown methane residues to confuse your measurement and you avoid the need to depressurize.
Maybe use lighter weight helium from above to expel the heavier reaction gases from the bottom of the container.
Maybe consider a gas centrifuge for separation of the expelled gas.
Related to Replacing gas in a fixed volume without losing pressure?
1. How can gas be replaced in a fixed volume without losing pressure?
Gas can be replaced in a fixed volume without losing pressure through the process of gas displacement. This involves introducing a new gas into the volume while simultaneously removing the current gas. As long as the volume remains constant and the gas is continuously being replaced, the pressure will remain constant.
2. What factors affect the pressure when replacing gas in a fixed volume?
The pressure in a fixed volume can be affected by the amount of gas being introduced and removed, as well as the temperature of the gas. The ideal gas law, PV=nRT, states that pressure is directly proportional to the number of moles of gas and the temperature, and inversely proportional to the volume. Therefore, any changes in these factors can impact the pressure in the fixed volume.
3. Can gas be replaced in a sealed container without changing the pressure?
Yes, gas can be replaced in a sealed container without changing the pressure as long as the volume of the container remains constant. This can be achieved through careful control of the amount of gas being introduced and removed, as well as the temperature of the gas.
4. Is it possible to completely remove one type of gas from a fixed volume without changing the pressure?
No, it is not possible to completely remove one type of gas from a fixed volume without changing the pressure. This is because the pressure of a gas is dependent on the number of moles of gas present, so removing all of one type of gas will result in a change in pressure.
5. How does the volume of the container affect the process of replacing gas without losing pressure?
The volume of the container is a crucial factor in maintaining a constant pressure while replacing gas. The ideal gas law states that pressure and volume are inversely proportional, so a larger volume will result in a lower pressure and a smaller volume will result in a higher pressure. Therefore, the volume must be carefully controlled to ensure that the pressure remains constant during the gas replacement process.
  • Mechanical Engineering
  • Mechanics
