Should the 'time' axis of a Minkowski diagram be time's imaginary unit?
In summary: I don't remember the title, sorry!I think it was Taylor, in "Space-time physics" who has a chapter heading entitled "Farewell to ict".
jk22
729
24
Since the metric is euclidean in coordinates ##(ict,x)## it can be drawn in a plane, but if the metric is ##diag(1,-1)##, can both axis still be drawn in a plane ?
You can draw anything two-dimensional in a plane. You do not even need a metric at all. What is going to differ is that the interpretation of the physical distance between points on your drawing is going to be irrelevant.
I strongly discourage the use of the ##\mathrm{i} c t## convention in relativity. It's maybe a bit inconvenient first to introduce the Minkowski-pseudometric coefficients ##\eta_{\mu \nu}## and to deal with upper and lower indices for vector and tensor components, but it pays off. At the end at latest when it comes to general relativity the ##\mathrm{i} c t## convention doesn't make any sense anymore!
Likes Dale
The ict notation is necessary to confuse people. If students cannot deal with confusing notation, they won't be able to become good theoretical physicists! :oldbiggrin: http://www.staff.science.uu.nl/~hooft101/lectures/genrel_2013.pdf
Likes vanhees71
Hm, ok. The logical conclusion from 't Hooft's many words about his awkward decision to do SRT with the infamous ##\mathrm{i} c t## convention and GRT in the more appropriate real-time formalism is that sign errors are unavoidable in GR. Well, then you have to live with that o0).
Likes atyy
Well the i comes too from taking squares when formulating the invariance of speed of light ##x=ct\Leftrightarrow x'=A(x,t) ct'##, whereas taking plus minus for the A function treats cases separately and has free parameters (unwanted ?), but squaring leads to bilinear forms but also implies the price to pay as a singularity (BTW why is it not called the speed of light catastrophe ?) and imaginary numbers.
jk22 said:
i comes too from taking squares when formulating the invariance of speed of light ##′x=ct\Leftrightarrow x'=A(x,t) ct'##, whereas taking plus minus for the A function treats cases separately and has free parameters (unwanted ?), but squaring leads to bilinear forms but also implies the price to pay as a singularity (BTW why is it not called the speed of light catastrophe ?) and imaginary numbers.
None of this makes sense. It appears that you do not understand either the rationale for, or the limitations of, the ##ict## convention.
In special relativity, the choice of whether to multiply the ##t## coordinate by ##i## to make the metric look Euclidean (notice I said "look" Euclidean, not "be" Euclidean) is a matter of preference and convention. For some purposes the ##ict## convention can be useful, which is why you sometimes see it in the literature.
However, you can't change the actual physics by changing conventions; the actual, physical spacetime still has timelike, null, and spacelike intervals, and Lorentz transformations still act differently on the three different kinds of intervals (or vectors in a more rigorous formulation) even if you obfuscate that fact by making the metric look Euclidean.
As @vanhees71 points out, once you move to general relativity, the ##ict## convention no longer works; this is its most important limitation, and the reason why GR textbooks will tell you that you have to unlearn it. (MTW, for example, has a clear explanation of the issue.)
PeterDonis said:
As @vanhees71 points out, once you move to general relativity, the ict convention no longer works
I would say it is sufficient to start writing down SR in general coordinate systems to make it no longer work.
Likes vanhees71 and pervect
I think it was Taylor, in "Space-time physics" who has a chapter heading entitled "Farewell to ict". The takeaway from this should be that one should expect to abandon "ict" at some point, that it's not fundamental.
I haven't verified that I got the source of the "farewell" quote right, this is from memory. But eventually, the ict convention is no longer used, it stops working. Basically, "ict" is a fudge that can delay the need for the introduction of a metric tensor if one uses cartesian coordinates in flat space-time. Cartesian coordinates do not exist in curved space-times, and even in flat space-times one may wish to use other coordinate systems. Using anything other than cartesian coordinates makes the "ict" fudge stop working.
It might be there, but it is definitely in MTW... not a full chapter, just a few short paragraphs in a named section.
jk22 said:
Since the metric is euclidean in coordinates (ict,x)(ict,x)(ict,x) it can be drawn in a plane, but if the metric is diag(1,−1)diag(1,−1)diag(1,-1), can both axis still be drawn in a plane ?
I would show another disadvantage to use imaginary time and real space coordinate.
In mathematics we know Gauss plane or complex plane z=x+iy the rules of which include
[tex]|z|=\sqrt{x^2+y^2} [/tex]
[tex]z^*=x-iy[/tex]
do not result our ##c^2t^2-x^2## or ##x^2-y^2##. To avoid unnecessary confusion it would be better to keep imaginary component for use in Gauss plane that is very useful in all the field of physics.
Just to add: if you write down spacetime intervals for solutions which are not static, (or app,y general coordinate transfo's to static solutions) you can end up wit loose factors of i due to cross terms between time and space
Likes vanhees71
Related to Should the 'time' axis of a Minkowski diagram be time's imaginary unit?
1. What is a Minkowski diagram?
A Minkowski diagram is a graphical representation of special relativity, where the horizontal axis represents space and the vertical axis represents time.
2. What is the time's imaginary unit in a Minkowski diagram?
The time's imaginary unit, denoted by i, is a mathematical concept used to represent the imaginary part of time in a Minkowski diagram. It is used to simplify calculations and visualize complex numbers in the diagram.
3. Why should the time's imaginary unit be included in a Minkowski diagram?
The inclusion of the time's imaginary unit in a Minkowski diagram allows for a more accurate representation of the relationship between space and time in special relativity. It also simplifies calculations and makes it easier to visualize complex numbers.
4. What is the significance of the time's imaginary unit in special relativity?
In special relativity, the time's imaginary unit is used to represent the imaginary part of time, which is necessary to account for the effects of time dilation and length contraction. It is also used to calculate spacetime intervals and Lorentz transformations.
5. Are there any alternative representations of time in a Minkowski diagram?
Yes, there are alternative representations of time in a Minkowski diagram, such as using a different imaginary unit or omitting the imaginary part altogether. However, using the time's imaginary unit is the most commonly accepted and widely used method in the scientific community.
