Does the Series Sum of Differences Converge Given a Contractive Condition?
  • MHB
  • Thread starter evinda
  • Tags
    Series
In summary, the most common way to determine if a series converges is by using one of the convergence tests, such as the ratio test, comparison test, or integral test. No, a series can only converge to a positive or zero value. Absolute convergence refers to a series that converges regardless of the order in which the terms are arranged, while conditional convergence refers to a series that only converges when the terms are arranged in a specific order. Yes, a series can diverge to infinity if the terms in the series are constantly increasing without bound. To prove that a series converges, you need to show that the limit of the partial sums approaches a finite value as n approaches infinity, which can be done by using one of the
evinda
MHB
3,836
Hello! (Wave)
Let $0< \theta<1$ and a sequence $(a_n)$ for which it holds that
$$|a_{n+2}-a_{n+1}| \leq \theta |a_{n+1}-a_{n}|, n=1,2, \dots$$
We have already shown that $(a_n)$ converges. Could you give me a hint how we could also show that $\sum_{n=1}^{\infty} (a_{n+1}-a_n)$ converges?
evinda said:
Hello! (Wave)
Hey evinda!
That's a telescoping sum isn't it?
That is:
$$\sum_{n=1}^{\infty} (a_{n+1}-a_n)
= \lim_{n\to\infty} \sum_{k=1}^{n} (a_{k+1}-a_k)
= \lim_{n\to\infty} \big((a_{n+1} - a_n) + (a_{n} - a_{n-1}) + \ldots + (a_2 - a_1)\big)
= \lim_{n\to\infty} (a_{n+1} - a_1)
(Thinking)
Hi there! Sure, here's a hint for showing that the series $\sum_{n=1}^{\infty} (a_{n+1}-a_n)$ converges: First, use the given inequality to show that the sequence $(a_n)$ is Cauchy. Then, use the Cauchy criterion for series to show that the series $\sum_{n=1}^{\infty} (a_{n+1}-a_n)$ converges. Let me know if you need any further clarification or help with the proof. Good luck!
Related to Does the Series Sum of Differences Converge Given a Contractive Condition?
1. How do you determine if a series converges?
The most common way to determine if a series converges is by using one of the convergence tests, such as the ratio test, comparison test, or integral test. These tests analyze the behavior of the terms in the series to determine if they approach a finite limit or if they continue to increase without bound.
2. Can a series converge to a negative value?
No, a series can only converge to a positive or zero value. This is because the terms in a series can never be negative, and as the number of terms approaches infinity, the sum of these positive terms can never become negative.
3. What is the difference between absolute convergence and conditional convergence?
Absolute convergence refers to a series that converges regardless of the order in which the terms are arranged. Conditional convergence, on the other hand, refers to a series that only converges when the terms are arranged in a specific order. This means that the sum of a conditionally convergent series can change depending on the order of the terms.
4. Can a series diverge to infinity?
Yes, a series can diverge to infinity if the terms in the series are constantly increasing without bound. This is known as divergent series, and they do not have a finite sum.
5. How do you prove that a series converges?
To prove that a series converges, you need to show that the limit of the partial sums (the sum of the first n terms) approaches a finite value as n approaches infinity. This can be done by using one of the convergence tests or by finding the exact sum of the series using mathematical techniques such as telescoping or geometric series.
  • Topology and Analysis
