Simple Harmonic Motion - Acceleration and Time Period
In summary, the relation between acceleration and time period in simple harmonic motion is affected by the mass and amplitude of the oscillation. When the mass is increased, the acceleration decreases and the time period increases. This is because the same force must move a greater mass over the same distance, resulting in a decrease in acceleration. The frequency also decreases, as it is dependent on the spring stiffness compared to the inertia. The amplitude remains the same, as the oscillation has the same total energy. The time period increases by the square root of 2, as the mass is doubled and the acceleration is halved.
ProPM
66
Hi,
I am a bit confused regarding the relation between the acceleration and time period in simple harmonic motion.
This questions asks what would be one change to the motion of a car's wing mirror in case the glass was switched for a heavier one. I don't understand for example, how would the period change. I can think that the same force will have to move a greater mass over the same distance but, wouldn't the amplitude decrease if the mass increases?
Thanks.
the oscillation is going to occur around the _equilibrium_ location
(more massive glass will have a lower equilibrium);
the oscillation Energy depends on Amplitude (squared, times ½k)
but the frequency depends on the spring "stiffness" compared to the inertia
(inside a square root). If you have the same Force, but a bigger mass, what can you tell about the acceleration at these turn-around points?
(that is where it spends most of its time, since its speed is slow there).
Sorry, I couldn't follow very well the beginning. But, for the same force with a bigger mass the acceleration will decrease.
So, from the equation, either omega must decrease (frequency decreases/time period increases) or the displacement will decrease...
How do I know which of these will happen?
IF the oscillation has the same (total) Energy, it has the same maximum PE (spring),
so it will have the same amplitude (maximum displacement from equilibrium).
. . . . if the mass is doubled . . .
acceleration will be halved, in x = ½at^2 , (here, t is roughly time for ¼ oscillation)
but it has to get just as far, so t^2 is doubled . . . so t is increased by sqrt(2)
that's why the omega formula is squareroot(k/m).
I can provide some clarification on the relationship between acceleration and time period in simple harmonic motion. In simple harmonic motion, the acceleration of an object is directly proportional to its displacement from its equilibrium position. This means that as the object moves further away from its equilibrium, the acceleration increases, and as it moves closer to its equilibrium, the acceleration decreases. This relationship is described by Hooke's Law, which states that the force applied on an object is directly proportional to its displacement from its equilibrium position.
Now, in the context of the car's wing mirror, the switch to a heavier glass would indeed result in a change in the time period of its simple harmonic motion. This is because the heavier glass would require more force to move it, and therefore the acceleration would be lower compared to the lighter glass. This decrease in acceleration would result in a longer time period for the mirror's motion.
Additionally, you are correct in your observation that the amplitude (the maximum displacement from equilibrium) would decrease with the heavier glass. This is because as the mass increases, the force required to move it a certain distance also increases, making it more difficult to achieve a larger displacement.
I hope this helps to clarify the relationship between acceleration and time period in simple harmonic motion. Feel free to ask any further questions if needed.
Related to Simple Harmonic Motion - Acceleration and Time Period
1. What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object moves back and forth along a straight line with a constant amplitude and a sinusoidal pattern. It occurs when the restoring force on an object is directly proportional to its displacement from its equilibrium position.
2. How is acceleration related to simple harmonic motion?
In simple harmonic motion, acceleration is directly proportional to displacement and is always directed towards the equilibrium position. This means that as the object moves away from the equilibrium position, the acceleration increases and as it approaches the equilibrium position, the acceleration decreases.
3. What factors affect the time period of simple harmonic motion?
The time period of simple harmonic motion is affected by the mass of the object, the force constant of the restoring force, and the amplitude of the motion. It is also inversely proportional to the square root of the mass and directly proportional to the square root of the force constant.
4. How can we calculate the time period of simple harmonic motion?
The time period of simple harmonic motion can be calculated using the following formula: T = 2π√(m/k), where T is the time period, m is the mass of the object, and k is the force constant. This formula assumes that the amplitude of the motion is small compared to the length of the pendulum or the spring.
5. What are some real-life examples of simple harmonic motion?
Some common examples of simple harmonic motion include the swinging of a pendulum, the motion of a mass attached to a spring, and the vibration of guitar strings. Other examples include the motion of a child on a swing, the motion of a diving board, and the motion of a ceiling fan.
  • Classical Physics
