Spaceship moves away from the Earth
In summary, the conversation is discussing the time difference between a clock on Earth and a clock on a spaceship moving away from Earth at a constant speed of 300 m/s. The concept of proper time, as well as the Einstein synchronization convention and the assumptions made in answering this question, are also mentioned. However, there is no unique answer to this question and it may be based on individual perspectives and assumptions.
Pritamstar
Spaceship moves away from the Earth at a constant speed of 300 m/s. How long would it take for a clock on the Earth to differ from a clock in the spaceship by 1 second.
Likes ISamson
Member warned that posting complete solutions is against our rules
Interesting question.
Recall that
$$t=\frac{\tau}{\sqrt{1-\left(\frac{v}{c}\right)^2}}$$
Where ##t## is the time measured on Earth, ##\tau## is the proper time measured on the spaceship, ##v## is the velocity of the spaceship, and ##c## is the speed of light.
What we want to find is ##\tau## when
$$\tau+1=\frac{\tau}{\sqrt{1-\left(\frac{300}{299\,729\,458}\right)^2}}$$
which gives
$$\Rightarrow\tau+1=1.000000000000500692525630328937507832865359772...\tau$$
which means that for every second that passes on the spaceship, ~1.0000000000005 passes on Earth. Making ##1.0000000000005...=\gamma## for ease,
$$\tau+1=\gamma\tau$$
$$\frac{\tau+1}{\tau}=\gamma$$
$$\Rightarrow\frac{\tau}{\tau}+\frac{1}{\tau}=\gamma$$
$$\Rightarrow 1+\frac{1}{\tau}=\gamma$$
$$\Rightarrow \tau=\frac{1}{\gamma-1}$$
$$\therefore \tau=1.9972337289059503848273053279826226...\times 10^{12}$$
Therefore, it would take ##~1.997234\times 10^{12}## seconds, or around ##63\,332## years(!), for a clock on the Earth to differ from a clock in the spaceship by 1 second.
Likes Pritamstar and ISamson
There is no non-arbitrary answer to this question (@A Lazy Shisno is making assumptions). There is no unique way to compare clocks that aren't in the same place, so there is a range of possible approaches to answering the question.
Conventionally, you would adopt the Einstein synchronisation convention. But you didn't say how long it takes for who. An observer in Earth's rest frame? An alien passing by at half the speed of light? Somebody doing 300m/s relative to the Earth in the opposite direction? All will have different answers.
That may be so, but both you and I know what answer the OP was looking for ;)
On the contrary, I believe that the OP was making the false (and very common among laypeople) assumption that there somehow is a unique and objective time difference. As such, the OP might be looking for an answer that does not exist and Ibix is certainly correct in pointing this out rather than perpetuating the OP's misconceptions about relativity.
Likes Ibix
Failing to be aware of the assumptions you made is how people end up with the notion that relativity is inconsistent. The thread is marked for university-level answers and anyone not developing a reflex of worrying about this kind of detail is going to start struggling with relativity at that level.
Likes Vanadium 50, jbriggs444 and Orodruin
Thread closed for Moderation.
@Pritamstar -- Is this question for homework? You have posted homework in the technical forums in the past with no effort shown. Please send me a Private Message (click on my username to start a conversation) to let me know.
And a reminder to the other posters in this thread -- if it looks like it might be homework (especially with zero effort shown), please click the Report button rather than replying. Thank you.
Related to Spaceship moves away from the Earth
1. How does a spaceship move away from the Earth?
A spaceship moves away from the Earth by using a combination of propulsion and gravity. The propulsion system, such as rockets or ion engines, provides the initial thrust to overcome the pull of Earth's gravity. Once the spaceship is in orbit, it can use the gravitational pull of other planets or the sun to continue moving away from the Earth.
2. What type of fuel is used to power a spaceship's propulsion system?
The type of fuel used depends on the specific propulsion system. Traditional rockets typically use liquid hydrogen and liquid oxygen, while ion engines use electricity to ionize and accelerate gas particles such as xenon or argon. Some newer propulsion systems, such as solar sails, use the sun's energy as a source of propulsion.
3. How fast can a spaceship move away from the Earth?
The speed at which a spaceship moves away from the Earth depends on a variety of factors, such as the type of propulsion system, the amount of fuel, and the gravitational pull of other celestial bodies. However, the fastest recorded speed achieved by a spacecraft moving away from the Earth is 36,373 miles per hour, achieved by the New Horizons spacecraft in 2006.
4. What challenges do astronauts face when traveling away from the Earth?
Astronauts face a variety of challenges when traveling away from the Earth, including exposure to radiation, limited resources such as food and water, and psychological effects such as isolation and homesickness. They also must undergo extensive training and preparation to adapt to the different conditions and challenges of space travel.
5. Is it possible for a spaceship to return to Earth after moving away from it?
Yes, it is possible for a spaceship to return to Earth after moving away from it. This is known as a "return trajectory" and involves using the gravitational pull of other celestial bodies to slingshot the spacecraft back towards Earth. However, the timing and precision of this maneuver can be challenging and requires careful planning and calculations by mission control.
