Super small electronic variable resistor -- Exists?
In summary: I believe its possible to design an analog neural network that can out perform a digital representation. Ofcourse if I can build it all, my first version won't out perform anything, but maybe after I build it, I can build it again, faster, with smaller components. Kind of like how vacuum tubes advanced.Also I have an invention idea whoch requires a neural network that can be trained very fast, and very responsive.It sounds like you have an interesting problem. I'd like to help but I'm afraid I don't know anything about neural networks. I do know a thing or two about digital...
MeaningfromForm
Hi I couldn't find of these exist anywhere.
Is there a component that is a variable resistor that adjusts based solely on receiving an up/down signal? And maintains its state on powerdown? I don't want this solution to involve any type of software, just a hardware solution. Looking for something that will work in the 8hz frequency less than 12v and 100mA
I couldn't find anything.
Hi
welcome to PF
Resistors don't do that without a lot of other surrounding components/circuitry
so what are you really trying to achieve ?cheers
Dave
davenn said:
Hi
welcome to PF
Dave
Essentially I am trying to create a simple neural network using only electronics on a circuit board. This variable resistor I am talking about would act as a weight. And the next resistor in the line, whether it fires or not would represent the neuron
Just googled analog neural network circuit, don't know why I didnt do that before. Yes that's what I want to create. From what I am reading technology seems to be limiting in terms of precision variable resistors or amplifiers that can maintain their state in the off position.
I think you had better do some reading on resistors and what they are and other basic electronics :smile:
resistors don't do the things you are implyingDAve
I thought I had... okay let me try to explain better what I want to do logically
I want an input to be adjusted either up or down then into fed into a gate which has an activation potential, so that over a threshold current it will pass through, and under it will not pass through.
Further more, the component which amplifies or reduces the signal needs to be adjusted by the circuit itself, so the circuit needs to have some sort of feedback loop to the "adjuster".
There is only one thing that I can think of which will do what you want. Take a look at the memristor. Unfortunately it's cutting edge stuff that isn't available yet.
Yea that's basically exactly what I am looking for. Unfortunate that its only experimental at the moment. I wonder if there is any suitable macroscopic equivalent, its response speed isn't super important, for example water with salt in it, the salt could be electrically removed to increase resistivity, obviously water and electronics is a terrible idea, but the first one that came to mind.
I know of no such device.
But you could use an external laser to ablate away material, making resistance higher. An external ion gun could deposit material, making resistance lower. If those external guns could be aimed, they could adjust a large array of resistors. It would take LOTS of engineering to make that work in real life.
If you always start with a virgin array, then only ablation is needed, skipping deposition.
A
I like the idea, ofcourse like you said it would be difficult, too difficult of course, but these work around ideas are very welcome.
Out of curiosity, why do you not want to create a digital design? You could even do this completely with software in a general purpose computer.
Because the computations performed by a processor to train a neural network are prohibitive. I believe its possible to design an analog neural network that can out perform a digital representation. Ofcourse if I can build it all, my first version won't out perform anything, but maybe after I build it, I can build it again, faster, with smaller components. Kind of like how vacuum tubes advanced.
It sounds like you have an interesting problem. I'd like to help but I'm afraid I don't know anything about neural networks. I do know a thing or two about digital design. It is possible that something exists which you can buy off the shelf and use.
When someone says "computationally prohibitive" I start thinking about FPGA's. Have you considered using FPGA's? The Xilinx Zynq-7100 has about 2000 DSP blocks. With a realistic clock speed of 300MHz that means you could configure the chip to perform 600,000,000,000 multiply-add operations per second. Is that enough?
Im sure that would work for what I want to do, but if I am relying on a classical processor I can never hope to compete with companies like google and their AI efforts.
In addition to the vast computational resources they have they also have mathmaticians working out complex algorithms to make those virtual nets learn.
I want to approach neural nets from a new perspective. I think an analog model can outperform a digital one. Consider this, a standar computers memory can only be a 1 or 0. If you think of the amplifiers setting as memory(which in terms of neural nets that's what it is) then the value can be 0, 1 or anything in between this is where the analog version makes its gains over the digital version which has to simulate these values with floating point variables.
The question is can I build it, and with how much complexity.
But as you suggested I could already create my invention using the already available technology, that is tempting and Ill have to give that some thought.
Thanls for your feed back.
I've used digital pots in a number of designs, real handy devices. Availability is fairly wide on them. The volatile type are probably more common, but there are non-volatile ones available that remember the last setting on power up. Some provide a one wire up/down interface, but an SPI or I2C interface is most common. You can find them in very small SMD packages.
BTW, Microchip has a wide range available. Maxim makes a 1024 tap pot which can be handy if you need higher resolution. Most are 256 tap and less commonly 512 tap. That indicates how many steps they have.
There's nothing wrong with that, although I suspect that it has been done before. However, you could implement the neural network with something analog, but do the learning with something digital, or do learning all software. The final neural weights, once learned, could be burned into an analog network.
You could even take an existing neural network (I think of Google's speech recognition network; the result of massive deep learning.) and have it burned into an analog network. Then see how much better the analog one performs. That would be a reasonable way to investigate the value of your ideas.
The closest I can think of that is analog and 'holds' would be a sample and hold circuit. It of course not a resistance but a voltage. Power down would also be a compromise here. If you want to get really crude a motor driving a potentiometer technically fits your requirement if you are liberal about defining super small.
Hi MeaningfromForm.
Maybe if you gave us the block diagram of the network you want to make, we might find a way to do it with much lower power and a lower voltage supply for the analogue circuits and pots. Some of us are good at mapping functionality to available analogue circuits.
Nope it looks like what I wanted to create has already been invented so it's kind of pointless to continue, besides, I live in Edmonton Canada and I wouldn't be willing to share my idea with someone unless it was in person anyways...
Thank you everyone for the ideas, keywords to research and suggestions. Perhaps I will come back in the future and revisit this when I have a better understanding of the technical aspects.
I suppose a thermistor would retain its temperature for a short period and so exhibit a resistance which is determined by the last voltage applied.
Another possibility is an IGFET, where the gate-source capacitance would remember the last applied voltage.
I don't expect analogue to beat a digital processor emulating the analogue for the same silicon cost. We passed that point in the 1980s.
I think your standard cell could be designed like an analogue computer with a couple of integrators to remember the state.
Operational transconductance amplifiers can be driven by a voltage difference on the inputs and current pulses on the Ibc terminal, a capacitor on the output integrates charge which is the product of Ibc and the input voltage. One OTA with a capacitor gives you a difference amplifier, a multiplier and an integrator. Check out the LM3700 ( NE5517 ? ) which have two amplifiers and two buffers in one pack.
The LM3700 data sheet has plenty of OTA applications; http://www.ti.com/lit/ds/symlink/lm13700.pdf
Likes jim hardy
just musing here from an old hardware guy
...\start daydream with boring anecdote
i once encountered in a TTL system a 3 level logic circuit that used "High" and "Low" TTL voltage levels but also detected and acted on a third level "In Between" ,
its purpose was to detect multiple slave responses to an address query from master.
Address_Acknowledge line driven high meant no response yet, middle meant single response (good) , low meant multiple responses(failure, program should try again)
That astonished me because i had never heard of anything but base two Boolean " High Low " for logic circuits.
I asked my old mentor and he said said "Sure, you can do math with any radix you want and it doesn't even have to be an integer. Mathematically it can be shown that a base e machine will require the least number of gates but i don't know of anybody who's developed a base e arithmetic book. "
Base e arithmetic? I can't even count in base e.
I soon figured out "well sure, i guess one could use any number of voltage levels for his logic,
and analog computing is just the limit as that number approaches infinity."
I bought a book on irrational numbers planning to learn how to count in an irrational number base maybe √2 but it was way too abstract for my flea brain.
That was almost forty years ago. Now i find lots of links on ternary (base 3) computing and even a few on base e. Try a search if you're curious .
As i said analog implies an infinite number of levels/values. There's a major practical drawback to analog circuits you have to keep them calibrated so that everybody attached to a particular signal agrees on its value . Some smaller number of logic levels might be easier to build and keep working..
Point being , i laud your investigating alternatives to binary computing and suggest there might be diminishing returns beyond some number of levels .
"e" being closer to 3 than 2 the point of diminishing returns might be around there . I find it a fascinating concept.
Seems to me you could build a cell out of something like a dollar Pic microcontroller
http://www.digikey.com/product-search/en/integrated-circuits-ics/embedded-microcontrollers/2556109?k=&pkeyword=&v=150&FV=fff40027,fff800cd&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
controlling a digital potentiometer , a hybrid if you will,
and explore the behavior of multi-level computing machines.
It wouldn't get you to true analog though.\end daydream
sorry if I've bored you
old jim
Likes tech99
You sound a little discouraged here. Don't be. From your earlier posts it sounded you had an idea for applying neural networks to some problem. That's a patentable idea. If it's something good then it can be monetized. You don't necessarily have to make the neural network hardware for this to be worthwhile. The application itself may be worth something. HP labs is working on making memristor nets on Silicon. If you have a nifty use for these when they come out then you are on to something.
Hi MeaningfromForm, I think everyone reading this thread is inspired by your ideas. Good luck with it.
Likes Averagesupernova and jim hardy
Don't be discouraged because someone else beat you to it with some invention. When that happens think of it as your idea wasn't so horrible because someone else thought of it too. Just bad timing I guess, but it shows your thinking is on the right track.
You can patent an improvement to an existing one. But patent lawyers can be expensive. .
  • #31
tech99 said:
But it does not have memory action.
Indeed. That is one of the properties that makes an optoisolator very close to a pure resistance element. From an analog engineer's perspective, that is ideal.
  • #32
How about a FET with a capacitor on the gate. FET behaves like a voltage controlled resistor and the capacitor keeps it working while the power is off (for a short period at least).
  • #33
This morning, after there was perhaps one reply to your original post, I started a post in which I was going to ask if you checked DigiKey, http://www.mouser.com/ , http://www.allelectronics.com/ or Fry's.
But Firefox crashed as it sometimes does on this PC, so I took the opportunity to upgrade packages. But I did something wrong and ended up with an incomplete upgrade which I've been fighting off and on all day. Finally, I got everything back to normal.
The other thing I'd say is what others almost mentioned. This sounds like an amplifier, which could be designed with almost any kind of transistor. Or you could us an opamp, which might be simpler.
  • #34
I don't want to appear to be pushing a product in my first post on this forum :nb) but given your interest, you may have already encountered this book - "Hacker's Delight" by Henry S Warren.
If you haven't, I would recommend it. There's a chapter on unusual bases that blew my rather closed mind when I first read it. There's a fun bit on base -1 +/- i, as well as a brief discussion on what base is "most efficient" from the point of view of cost. Standard binary is more costly than base e by a factor of 1.062 (According to the formula he used). This book might be useful for you, MeaningfromForm. :smile:
Likes jim hardy
  • #35
It is one of the less peasant truths of the modern world. There are so many smart people on this planet, it is very difficult to have an idea that someone else didn't think of first. We who yearn to be original get frustrated by that.
  • Electrical Engineering
10K
9K
  • Computing and Technology
  • Quantum Interpretations and Foundations
  • Astronomy and Astrophysics
