Temperature rise in Power Transformer
In summary, the transformer in question has a rating of 7.5 MVA and is connected to a load of up to 6 MW. It has a natural oil cooling system and is designed to operate at a normal atmospheric temperature of 25 C. However, it has been observed that on hot days, the transformer's temperature exceeds the permissible limits, with oil temperature reaching 50 C and winding temperature reaching 73 C. Despite the connected load being lower (4 MW) and the atmospheric temperature being higher (30 C), this should not cause the transformer to overheat. Upon observation, it was noted that the transformer's vent-pipe may be missing and it is a relatively new transformer installed in 2001. The expert's
atheistrical
The following transformer gets overheated and I was looking for most probable the causes associated with it.
1. Rating : 7.5 MVA, 0.85 power factor, Power Transformer (Manufacturer - Kirloskar)
2. Connected Load : Upto 6 MW
3. Oil Natural Cooling System
4. Normal Atmospheric Temperature : 25 C
5. Clauses : The transformer performs well most of the times and at peak load that occurs mostly at 0600 hrs and 1800-2100 hrs. However, on a hot day the temperature of the transformer exceeds the permissible limits. The reading are as follows: Oil Temperature : 50 C, Winding Temperature : 73 C. The connected load at this time was noted to be upto 4 MW and the atmospheric temperature was noted to be about 30 C. This should, practically, never cause the transformer to overheat.
6. Observation : The transformer's vent-pipe seemed to be missing, or perhaps this transformer never used one. Also, this is a pretty new transformer, installed in 2001.
7. My assessment : I thought that the dielectric strength of the oil has deteriorated and/or sludge formation within the tank has occurred. I am planning to filter the oil in the tank.
What are your recommendations/feedback?
This is too expensive of a problem to trust to a message board. Hire an engineer to evaluate the transformer. He'll want to physically examine the transformer and read the submittal information.
Based on the information provided, it seems that the most probable cause of the temperature rise in the power transformer is the lack of proper ventilation. The missing or non-functioning vent-pipe could be preventing the heat from escaping the transformer, leading to overheating. This is especially concerning since the transformer is operating at a high load during peak hours and in hot weather conditions.
I would recommend checking the dielectric strength of the oil and conducting a thorough inspection of the transformer to ensure there is no sludge formation or other issues. Additionally, installing a vent-pipe or ensuring that the existing one is functioning properly is crucial to prevent future overheating.
It is also important to regularly monitor and maintain the transformer to prevent any potential issues. This includes regular oil filtration and ensuring proper ventilation. I would also suggest consulting with the manufacturer, Kirloskar, for any specific recommendations or guidelines for maintaining their transformers.
Overall, it is important to address the issue of overheating as it can lead to further damage and potential power outages. Taking proactive measures such as regular maintenance and proper ventilation can help prevent such issues in the future.
Related to Temperature rise in Power Transformer
1. What is the cause of temperature rise in power transformers?
The main cause of temperature rise in power transformers is the dissipation of heat due to the flow of current through the transformer windings. This heat is generated by the resistance of the transformer windings and the core losses.
2. How does temperature rise affect the performance of a power transformer?
High temperature can cause the insulation materials in the transformer to degrade, leading to reduced efficiency and potential breakdown of the transformer. It can also affect the transformer's cooling system and increase the risk of overheating.
3. What factors can contribute to high temperature rise in power transformers?
The main factors that can contribute to high temperature rise in power transformers include overloading, poor ventilation, high ambient temperatures, and aging or faulty insulation.
4. How is temperature rise in power transformers measured and monitored?
Temperature rise in power transformers is typically measured using thermocouples or resistance temperature detectors (RTDs) placed on the transformer windings. These sensors feed data to a monitoring system, which alerts operators if the temperature exceeds safe levels.
5. What measures can be taken to control temperature rise in power transformers?
To control temperature rise in power transformers, operators should ensure the transformer is not overloaded and maintain proper ventilation. Regular maintenance and replacement of aging or faulty insulation can also help prevent excessive temperature rise. In some cases, additional cooling systems may be installed to keep the transformer within safe temperature limits.
  • Electrical Engineering
  • Thermodynamics
34K
  • Thermodynamics
  • Aerospace Engineering
