The 41 second clock failure syndrome
In summary, the cheap wall clock from 2017 failed in less than 1 hour, and the new clock with a new battery also failed in the same way at the 41 second position.
  • #71
So I used simple factoring to show that 42 days has 10! seconds
42 days in seconds is 42 . 24 . 36 . 100: ##2^8 . 3^4 . 5^2 . 7##
10! is 10 . 9 . 8 . 7 . 6 . 5 . 4 . 3 . 2 . 1 which is ##2^8 . 3^4 . 5^2 . 7##
How did you come to learn this arcane factoid?
  • #72
OK, I get this, but...
How do you get this? That doesn't seem to be a shortcut or anything: 256.81.25.7
Likes jedishrfu
  • #73
I can't remember when I first saw this, but it stuck in my mind as another candidate for the Ultimate Question, "What is the smallest integer number of days that is an exact factorial number of seconds?"
$$\begin{align*}
&\frac
{42 \times 24 \times 60 \times 60}
{10 \times 9 \times 8 \times 7 \times 6 \times 5 \times 4 \times 3 \times 2 \times 1} \\
&= \frac{60}{10} \times \frac{1}{9} \times \frac{24}{8} \times \frac{42}{7 \times 6} \times \frac{60}{5 \times 4} \times \frac{1}{3 \times 2} \\
&= 6 \times \left( \frac{1}{9} \times 3 \times 1 \times 3 \right) \times \frac{1}{6} \\
&= 1
\end{align*}$$
  • #74
I just prime factored the 10! Factors and counted up the 2s 3s 5s and 7s
2.5.3.3.2.2.2.7.2.3.5.2.2.3.2.1
You can think there are 5 even factors in 10! Hence five 2s But 8 gives you two more and 4 one more for a total of 8 2s or ##2^8## …
Likes DaveC426913
  • #75
I've not got an answer to your 41 second problem but it may be not dissimilar to the Thursday effect for grandfather clocks. This causes longcase clocks to stop on Thursdays* i.e. when the pendulum is the same length as the (hanging) weights causing a transfer of energy to the (swinging) weights if there is the slightest tendency for the clock to sway.
The standard cure is to put a match stick under the appropriate corner of the clock for which the clockmaker (or repairer) will charge five guineas.
*This, of course, is based on the normal rules of the household i.e. that the clock is wound up on a Sunday evening.
Likes Rive, Baluncore, anorlunda and 1 other person
  • #76
So there's your answer @anorlunda : tilt your clock:
Likes anorlunda
  • #77
That'll be five guineas please... :smile:
  • Haha
Likes dlgoff, Rive, anorlunda and 1 other person
