The building of a proton accelerator
In summary, a 7th grader wants to build a proton accelerator with a budget of less than $400, but this may not be feasible due to the high costs and technical challenges involved. The process of ionizing hydrogen and maintaining it in a proton beam would require ultra-high vacuum conditions, expensive equipment, and precautions to prevent radiation sickness. It is possible to build a cloud chamber for observing cosmic ray interactions within this budget, but constructing a proton accelerator may be beyond the capabilities and resources of a 7th grader.
Demodocus
Through random chance, I decided one day that I would build a proton accelerator. I understand the concepts of the physics that are involved well enough, but the actual construction is a bit of a mystery. There is a surprising number of rescources on the construction, but they mostly involve people with massive budgets, and even massiver amounts of free time. For example, I don't have the rescources to buy a few miles of copper wire, and then wrap it around my house. This problem is also escalated by the fact that I'm in 7th grade, and it's tough to accumalate enough money. I hope to spend less than $4oo american, if possible. One of my biggest challenges is to find a way to build (or buy) a cloud chamber, and enough reactant material. They don't exactly sell that stuff at target. I plan to keep a mini-blog here about the construction of it here, and I would really appreciate any helpful hints.
--Demodocus
I think you're setting your sights rather high. Whilst it's perfectly possible to create, within that budget, a cloud chamber to observe energetic particles from cosmic ray interactions, you wouldn't have a hope of building a proton accelerator for that, really.
Didn't some kid build an accelerator in his house and whenever he used it, it would mess up the power at his neighbors' houses? I remember reading about this a few years back.
What kind of energies are you thinking of?
There's four in this house - one TV and three CRT moniters :)
Those are "electron accelerators", not "proton accelerators".
I have a feeling this person doesn't quite know what he's getting himself into.
Zz.
how big are you wanting to go? i suggest checking out http://www.unitednuclear.com
It's possible that he could make a small Van de Graff and use inonized hydrogen as his proton source.
But probably not for $400.
Regards
ZapperZ, I'm well aware of that thanks. I was replying to the post that said 'some kid build an accelerator in his house', not the OP (which I've alread replied to).
Regards
No, not even with $1000. I still think he doesn't know what he's getting himself into. Here's why:
1. How does one ionize hydrogen? It's one thing to have H2 gas in a discharge tube to cause an excitation and view the transition lines. It's another to completely strip off the electron.
2. Not only that, you have to strip the electron with enough energy so that you have the chance to separate them out. So how do you maintain the ionized H's long enough to accelerate them?
3. Once you get that, you realize that to make any significant transport, you have to be in ultra-high vacuum (better than 10^-10 Torr). This is more crucial for protons than electrons since protons are way larger and has a large scattering cross-section than electrons. UHV pumps are NOT cheap.
4. Even when you accomplish that, this is a very HOT process. The protons will have very high momentum in all directions. Even if you put them in a uniform field, the transverse momentum will still be there and will, sooner or later, cause the protons to hit the walls.
5. You can minimize Point 4 using solenoids and steering coils, but hey, this now requires high current power supplies to work those solenoids and steering coils. This is not even a $10,000 project - it is way more.
6. If you have managed to overcome Problems 1,2,3, 4 and 5, then be prepared for radiation sickness sooner or later. Fast protons (not even high energy) hitting materials such as stainless steel, etc can cause the material to become "hot". The residual radiation from these can stay for a long time (people who work in proton colliders cannot go into the detector for hours and even days after shut down).
Like I said, I don't think this person knows what he's getting himself into...
Zz.
Zz.
When I was an undergrad, I worked with a 2Mev Van de Graff that had been donated to the University by the then Atomic Energy Commission. We could strip electrons with RF on both hydrogen and helium (4Mev in this case). We used a crude 1024 channel analyzer to gather data from photomultipler tubes detectors.
Maybe some day he'll be luck like I was and get to work with and see an accelerator.
Regards
Regards
Exactly. You just don't need something with 13.6 eV to strip off an electron off a Hydrogen if you want to obtain a bare proton. You need something orders of magnitude bigger! That's why I brought up Point 2.
I think your last point is what is missing in most people that either do not fully understand how science works, or do not understand what is involved in something like this. People should grab every opportunity they can when there's a chance to see an actual scientific facility and talk to people who do these things. I have highlighted this, but if anyone is in the NYC/Long Island area, you will miss a wonderful opportunity if you do not go to one of Brookhaven's Summer Sunday Tours. See what is involved in doing meticulous, careful science, and see how wide of an area that is studied in just that one laboratory.
http://www.bnl.gov/community/summer_sunday.asp
One might even get to see an accelerator or two there.
Zz.
CERN do summer schools... I wouldn't be surprised if SLAC didn't too.
Bnl
Zz.
I have a dozen pics I took at BNL in fall of 2003, I think it was
just after the first RHIC run. If anybody wants I can put on
a website.
Yep- that linear accelerator was indeed my first accelerator project. It involved extremely high voltages and vacuums, both of which can be dangerous. But most dangerous of all was the enormous amount of X-rays I was producing with my machine. Constructing a linear accelerator is quite difficult, and a good overview of the entire process is available in "The Amateur Scientist" by C. L. Strong, 1960. The book has an article from the Amateur Scientist column in Scientific American outlining the construction of a static-electricity driven electron accelerator. With the addition of a ion gun, a proton accelerator would be feasible, but extremely difficult. My first machine took over a year of my "free time" to complete. The other machines took even that much more time. It is important to examine both the scope of the project and your own dedication to the project before starting anything as difficult as a particle accelerator.
-Fred
a website.
I would love to see them!
Here are some BNL pictures from October 2003. Sadly even this isn't really 'made in the USA' - most of the metal came from Russia.
http://www.rant.st/snowboarder/BNL/BNL.html
Outstanding mmisk. Thanks for posting them.
Gosh, if I wanted to ionize hydrogen I think I could do it a lot cheaper than $400. Of course you're going to have to find a lot of parts at your local scientific salavage yard, and you will be risking your life in the process of building the thing.
It turns out that when I was in college I helped maintain equipment that created plasmas, which are combinations of ions and electrons. When you make a plasma out of hydrogen gas, what you end up with is first atomic hydrogen ions, and later, after you knock the extra hydrogen off, protons.
First, get a (very low pressure) more or less pure hydrogen atmosphere. Second, put a probe out in the middle of it with an extremely sharp point on it. Third, put a high positive voltage on your probe. The sharp point will create an extremely high electric field and this will ionize whatever gas is around.
The result of all this will be a steady flow of electrons into your probe and ions (protons) away from it. The protons that get created by the ionization will be attracted towards the negative plate and this will be the beginning of your beam.
To learn how to do this, in a practical manner, it would be best to first learn about vacuum tubes. Take a good look inside some, and when you've read enough to recognize what a "plate" and a "cathode" looks like, you're ready to start thinking of your own designs. Of course you'll probably be building in stainless steel rather than glass. That means learning how to run machine tools could be useful.
Once you get your source of hydrogen ions (as described above) you need to accelerate them and strip off the neutral hydrogen. The way this is done is with dangerous high voltages and various magnetic and electric fields.
The basic idea is to make everything you don't want go away by arranging for it to collide with some sort of "beam stop". For example, hydrogen ions weigh more than protons, but they have the same charge. So at the same energy (i.e. number of volts you've accelerated them by) they tend to travel straighter in a magnetic field. So you leave a free curved path for your protons to curve around, but your hydrogen ions go more straight, hit the walls and are turned back into neutral hydrogen.
To get all the diffusion pumps and stuff, you need to hang around at auctions and surplus yards. This stuff regularly gets thrown away for scrap prices. Check out your local large University, they may have a monthly auction or a salvage yard. Probably the perfect situation would be to work at a metal reclamation yard near a large scientific establishment. You'll get all kinds of incredible equipment for free.
Carl
In high school, Michio Kaku built his own particle accelerator around the football field over the Christmas break. According to him, it did usually blow every fuse in his house.
Zz.
It is possible to build a smaller scale project, why does it have to be so large and expensive. I was looking into doing this also and it was suggested to build a synchrocylotron they have been build as small as 30 cm in diameter. I don't know what the cost of parts is, but I'm sure its more in your range.
Adam,
This thread is four years old.
We're trying to tell you the same thing in the thread you started - this is not cheap. Ultra high vacuum systems run thousands of dollars, and without one, your beam won't get very far. You got on my case for "being negative" when I pointed this out, but it is nonetheless true.
10^-10 Torr requirement is an exagerration. 10^-6 should be sufficient for a desktop cyclotron.
Here's a diffusion vacuum pump for sale for $695, it should be sufficient for the task:
http://cgi.ebay.com/Unused-NEW-Varian-HSA-150-Diffusion-Vacuum-Pump_W0QQitemZ250340602272QQcmdZViewItemQQptZBI_Pumps?hash=item250340602272&_trksid=p3286.c0.m14&_trkparms=72%3A1240|66%3A4|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A200
While I agree 10^-10 is more than is needed, I don't think 10^-6 is good enough. That gives you a mean free path of around 100 meters, so if you go with 1/10 of a mean free path, that's 10m - around 10 turns of a frisbee sized machine. If you don't want an enormous voltage on the accelerator, that's not enough: I'd say you need a few x 10^-8 torr.
I'm not an expert on vacuum, but this seems to me to be pushing what a diffusion pump can do: I'd go with an ion pump or a turbopump.
A few points:
- "frisbee sized" is actually quite big for a cyclotron. The Rutgers system referenced in the other thread is about that size (r_max = 5 inches).
- Don't forget that radius increases with energy, you have to correct for that. Path ~ 2/3 * revolutions * circumference.
- 50 revolutions with 100 VAC between electrodes should get protons to 14 keV, which is IMHO quite respectable. In a 5-inch chamber, 50 revolutions would be equal to the total path of 27 m or 0.27 of a mean free path.
- If the vacuum is not good enough, you're going to lose output current. At a 0.27 of a mean free path, you'd lose 25% of protons. Depending on the initial current, and depending on what you do with protons once they are accelerated, you could still see output at 3x - 5x mean free path.
This is all theoretical, though.
But if I wanted a 14 keV proton, I wouldn't be inclined to use a cyclotron at all. I'd use a van de Graaf or a Cockroft-Walton. Much simpler; particularly the C-W, which has no moving parts.
Vanadium 50 said:
Adam,
Would you stop "trying" to tell me its too expensive, there are ways around things. I find it hard to believe that it MUST cost thousands of dollars to find a sufficient vaccum. And whos to say I'm not some loaded kid whose parents will spring for anything? Regardless I was trying to find out the smallest, most plausible way to do this, all you have done is tell me I cannot. When numerous other sources have given me encouragment. Stop responding to my posts please.
If you feel my posts are inappropriate, please take them up with the Mentors. Feel free to click the "report" button. Until then, I will feel as free to express my opinion as you are to express yours.
You might - just might - find it valuable to look at some of the numbers that I have posted. Nature, you see, doesn't care about your self-esteem or how much encouragement you're getting. Nature cares only about things like how good your vacuum is, how well aligned your beam optics is, and how good your field quality is.
Then maybe you should ask those "numerous other sources".
I work at a particle accelerator. In fact, the particle accelerator IS the research project in itself, rather than simply a particle source. Maybe you should go visit one and see what it takes IF you don't believe the stuff you read here. Argonne Nat'l Lab might have its open house again next year around August. I suggest you come visit the lab then and look at a particle accelerator and see for yourself what it takes.
Or would you rather we just lie to you and tell you it can be done easily?
Zz.
OK correct me if I'm wrong, but I believe that VdG can't output sustained beam for prolonged periods of time, and a 14 KV C-W could be quite deadly for an amateur.
And the road to higher energies in a cyclotron lies through stronger magnets and higher dee voltages, not through better vacuum.
  • #31
I don't see that continuous beam is a requirement here. In fact, there may be an advantage to pulsed beam, as it's easier to tell if it's getting out the other end if you see it blinking on and off at the machine's cycle time. As far as safety, I don't see that any design dispenses with HV: the advantage of a VdG or a C-W is that their HV is limited to relatively low currents. For that matter, I don't believe that it's possible to build any accelerator without risks, and one of the things that disturbs me about many of our visitors intending to do this is how cavalier they are about these risks.
The energy of a cyclotron is limited by the magnetic field. In principle, you could make this work with very low voltages and long paths. As a practical matter, vacuum sets a limit on your maximum path, which sets a limit on the minimum voltage. One has some ability to trade one against the other.
However, there is also a second-order effect. What happens to the beam that's lost due to collisions with the residual air? Usually, these form ions, and these ions then move in response to the applied electromagnetic fields, changing the net fields. So your field quality goes down.
  • #32
i am also building one, a cyclotron...with some o fmy friends. WE are all in 9th grade, and we understand the basics..so we have to read up on the subject. Here are three good books to read:
"The amateur Scientist"
"Accelerators:Machines of Nucelar Physics"
And "Particel Accelerators"
you should be able to find them at any Univeristy library.
You should also contact Fred Niell, google him. He built an accelerator for the 1994 ISEF and won...check his site out.
You can do it!
  • #33
... and you used PROTONS for such a thing?
Zz.
  • #34
"and you used PROTONS for such a thing?"
was that a reply to my post? no, we haven't built it, nor will we ever build it without the help of our local Physics department, at the local University. If we do actually build it, we will most likely try and use protons.
  • #35
ZapperZ, I don't understand why protons are so popular - especially when there are messages posted like "I want to build a proton accelerator, and I want it to be easy" - which precludes the advice "don't use protons!". I don't understand why cyclotrons are so popular when there are devices that are a lot more appropriate for the energies being considered. I really don't understand why there is all this focus on magnets and to a lesser extent Dees, when the real problems lie elsewhere - how do you get an ion source to work, so that you don't get recombination, and you get something which is more or less beam-like, so you have a chance of accelerating it before it splats against the wall of your device? How do you tell that you have managed to accelerate the beam? If the beam doesn't accelerate, how do you plan to figure out what's going wrong? These are the hard parts - it's like someone posting a message saying "I want to build an airplane from scratch, and I need your advice. What color should I paint it?"
  • Beyond the Standard Models
  • DIY Projects
