The dropping of two identical balls without air resistance
In summary: Fixed it!In summary, the conversation discusses the behavior of two identical balls thrown horizontally at different speeds from a cliff, with air resistance being ignored. The main questions are whether the balls will land at the same time and with the same speed. It is concluded that since the only force acting on the balls is gravity, their acceleration will be constant and therefore the time of flight will be the same. However, since the balls have different initial speeds, their final speed upon landing will also be different.
M23
I was thinking about this and couldn't really figure it out.
You are standing on a cliff and you have two identical balls. In this case, air resistance is to be ignored. The only thing different is that you throw the ball horizontally at different speeds. Let's say you threw ball one at a speed of 5m/s and the other ball at 10m/s
Will the balls land at the same time? Will the balls have the same speed when they land?
My thinking:
Since air resistance is ignored, I know that the horizontal component will be constant throughout. However, I wasn't really sure how no air resistance will affect the behavior of the ball. Could someone please answer the two question above?
Thank you very much.
Some hints..
They have the same vertical velocity at the start.
They have the same vertical acceleration (g).
So will they have the same vertical velocity all the time?
[strike]Time = distance/velocity.[/strike]
Will they have the same vertical velocity?
Will they have the same horizontal velocity?
Do you know how to add vectors?
Hi M23 and welcome to PF.
1. No air resistance means that the only force acting on the balls is gravity. In other words, their acceleration is g. What does this imply about the time of flight? You are on the right track.
2. If the balls don't have the same initial speed, why should their final speed be the same?
Only in the horizontal direction, of course.
Yes sorry not sure why I put that in there when talking about the vertical velocity.
Related to The dropping of two identical balls without air resistance
What is the "dropping of two identical balls without air resistance" experiment?
The experiment involves dropping two identical balls from the same height without any air resistance present. The goal is to observe and compare the motion and behavior of the balls as they fall.
Why is air resistance not present in this experiment?
Air resistance is not present in this experiment because it can greatly affect the motion of falling objects and make it difficult to accurately compare their behavior. By eliminating air resistance, we can focus solely on the effects of gravity on the balls.
What factors can affect the results of this experiment?
The results of this experiment can be affected by the height from which the balls are dropped, the mass and size of the balls, and the surface on which they are dropped. Other factors such as temperature and humidity may also have an impact on the results.
What can we learn from this experiment?
This experiment can help us understand the principles of gravity and how it affects falling objects. We can also learn about the effects of air resistance and how it can impact the motion of objects. Additionally, we can gather data to analyze and make predictions about the behavior of falling objects.
How does this experiment relate to real-world scenarios?
Dropping two identical balls without air resistance can be seen as a simplified version of objects falling in a vacuum or in outer space. It can also be used to study the motion of objects in free fall, such as skydivers or objects dropped from a plane. This experiment can also provide insights into the behavior of objects in natural phenomena such as meteors entering Earth's atmosphere.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
