The Pressure Variation with depth in various Water Bodies
In summary: ACER Aspire One D270-4391 LaptopIn summary, the pressure experienced by a car door when it falls into water is not very significant. It is best to let the water inside the car equalize the pressure on both sides of the door.
sandeep singh
i want to know about the variation in pressure according to varo=ious depth in different water bodies like for river, lake, stream, and all with the possibility of having fresh water or salty water. (not talking about oceans) may be shore of a sea will also work.
pressure in water is rho * h * g
kindly help if you have any helpful data or solutions. Thanks in advance.
Well, what exactly do you want to know? The formula ΔP = ρ g h says it all.
There may be some variation in the density of the water in a particular body of water, but it typically ranges from 999 kg/m3 for fresh water to 1025 kg/m3 for sea water. Some extremely salty bodies of water, like the Dead Sea or the Great Salt Lake, have even higher densities.
Likes sandeep singh
i wanted to know how much pressure a car (specially door) experience when it fell off into the river or lake in an accident. As a person trapped inside is not able to push the door open due to this pressure. and i m even confused how to know it exactly as it varies with running water and steady water also...
There is a slight change in pressure when water is flowing, but for practical purposes, like trying to open a car door when the car is submerged, this makes little difference.
In such circumstances, it is better to let the interior of the car fill with water to equalize the pressure inside and outside the car. Then, the door may be opened with relative ease, assuming that no structural damage has occurred to the car which might jam the door closed.
thanks for your reply.. so do i still use the same equation (delta p) = (rho) * g * h ...for calculation of the exact pressure experienced by the car door for my project...??
Yes, this formula still works. But pressure is not the only thing you are looking for here.
When pressure acts over a surface, a force is created. It's this force which must be overcome in order to open the door.
Likes sandeep singh
For still water that will work fine.
But if equal pressures are on both sides of the door, the actual pressure doesn't matter.
In moving water, the car orientation will be a factor.
If the car is facing upstream or perpendicular to the water flow, the velocity of the water will act to hinder opening up the door.
For a car facing downstream, the flowing water will act to open up the door for you.
I am sure you have experienced the same troubles with opening a door in the air, where the wind can fling open the door and you have to hold on to it so it doesn't fly off, or you yourself using more force to push open the door if the wind is acting against it.
Likes sandeep singh
Related to The Pressure Variation with depth in various Water Bodies
What is the pressure variation with depth in various water bodies?
The pressure variation with depth in various water bodies is the change in pressure as you go deeper into a body of water. This change in pressure is caused by the weight of the water above pushing down on the water below.
What factors affect the pressure variation with depth in water bodies?
The pressure variation with depth in water bodies is affected by several factors, including the density of the water, the depth of the water, and the gravitational pull of the Earth. The deeper the water, the greater the pressure, and the denser the water, the greater the pressure. The gravitational pull also plays a role in the pressure variation, as it pulls the water downwards and increases the pressure.
How does the pressure variation with depth affect marine life?
The pressure variation with depth can have a significant impact on marine life. As animals and plants descend deeper into the water, the pressure increases, which can affect their bodies and behavior. Some species have adaptations to withstand high pressures, while others may not be able to survive at certain depths.
What tools are used to measure pressure variation with depth in water bodies?
Scientists use a variety of tools to measure pressure variation with depth in water bodies. These include pressure sensors, depth gauges, and underwater vehicles equipped with pressure sensors. Sonar technology is also commonly used to map the pressure changes in underwater environments.
How does the pressure variation with depth in water bodies impact underwater structures?
The pressure variation with depth in water bodies can have a significant impact on underwater structures, such as submarines, pipelines, and offshore platforms. These structures must be designed to withstand the high pressure at certain depths and may require specialized materials and construction techniques. Failure to properly account for pressure variation can result in structural damage or collapse.
10K
