Time taken for two relativistic particles to meet
In summary, the two particles meet again at a time that is different depending on the frame of reference.
phosgene
146
A particle P undergoes the hyperbolic motion
[tex]x_{P}(t) = \frac{c}{a}(c^2 + a^2 t^2)^\frac{1}{2} [/tex]
along the x-axis of frame S, where c is the speed of light and a is a constant. A second particle, Q, undergoes the motion
[tex]x_{Q}(t) = \frac{1}{2}ct + \frac{c^2}{a}[/tex]
and so just passes P at time t=0. Show that according to a clock moving with P, the two particles meet again after a time [tex]\frac{a}{c}ln(3)[/tex], while according to a clock moving with Q, the elapsed time is [tex]\frac{2c}{\sqrt{3}a}[/tex]
The clock hypothesis is assumed, so the clocks are assumed to depend on instantaneous velocity, but not acceleration.
Lorentz transform for time between inertial frames with relative velocity V along the x-axis.
[tex]t'=\gamma (t-\frac{Vx}{c^2})[/tex]
Seems like a simple problem, solve for t when xP = xQ and then use the Lorentz transforms to get the time taken in the two frames corresponding to each particle being at rest, but my answers are not correct. Here's what I did:
[tex]x_{P}=x_{Q} [/tex]
[tex]\frac{c}{a}(c^2 + a^2 t^2)^\frac{1}{2} = \frac{1}{2}ct + \frac{c^2}{a}[/tex]
Square both sides and move all terms to one side to get:
[tex]\frac{3}{4}t^2 - \frac{c}{a}t=0[/tex]
[tex]t(\frac{3}{4}t - \frac{c}{a})=0[/tex]
[tex]t=0 \ or\ t=\frac{4c}{3a}[/tex]
t=0 corresponds to their initial meeting, so they must meet again at the latter. We plug that value into the equations for xQ or xP to get the spatial coordinate to use in the Lorentz time transformation.
[tex]x_{Q}(\frac{4c}{3a})=\frac{1}{2}c(\frac{4c}{3a}) + \frac{c^2}{a}=\frac{5c^2}{3a}[/tex]
To find the relative velocities between frames, we take time derivatives of xQ and xP:
[tex]\frac{d}{dt}x_{Q}(t)=v_{Q}(t)=\frac{1}{2}c[/tex]
[tex]\frac{d}{dt}x_{P}(t)=v_{P}(t)=\frac{act}{\sqrt{c^2+a^2 t^2}}[/tex]
[tex]v_{P}(\frac{4c}{3a})=\frac{4}{5}c[/tex]
Transforming to the frame S', which is the frame where xP is at rest when the particles meet in S, I get a time of zero:
[tex]t' =\gamma (t-\frac{Vx}{c^2}) = \frac{\frac{4c}{3a} - \frac{\frac{4c}{5} \frac{5c^2}{3a}}{c^2}}{\sqrt{1-\frac{16}{25}}} = \frac{ \frac{4c}{3a} - \frac{4c}{3a} } { \sqrt{\frac{9}{25} } }=0[/tex]
That's clearly not correct. What am I doing wrong?
Why are you Lorentz transforming? It is a question of integrating the proper time over the respective world lines.
Hi, thanks for the reply. The book doesn't cover the technique you mention and I don't know how to do it. The question references a previous one in which the particles aren't accelerating and the method is to use a Lorentz transform for velocity.
Where you've gone wrong is this:
You calculate the coordinate time in the reference frame when the particles meet. You calculate the velocity of each particle in that frame at this time. But, this is an instantaneous velocity. The Lorentz Transformation relates the elapsed time between two frames moving at a constant relativity velocity of ##V##.
This is not going to be valid to calculate an elapsed time over a period when the relative velocity between the two particles has been changing.
Likes phosgene
Thanks for that, I'll go back to the drawing board and see what I can come up with.
Do you know how to calculate the proper time of a particle with variable velocity?
Related to Time taken for two relativistic particles to meet
1. How does relativity affect the time it takes for two particles to meet?
The theory of relativity states that time is relative to the observer's frame of reference. This means that the time it takes for two particles to meet can vary depending on the observer's perspective.
2. Is the time it takes for two particles to meet affected by the speed at which they are traveling?
Yes, according to the theory of relativity, time dilation occurs as an object approaches the speed of light. This means that the faster the particles are traveling, the longer it will take for them to meet from an outside observer's perspective.
3. What is the formula for calculating the time it takes for two relativistic particles to meet?
The formula for calculating the time it takes for two particles to meet takes into account the distance between them, their relative velocities, and the speed of light. It is given by t = d/(v1+v2), where t is time, d is distance, and v1 and v2 are the velocities of the two particles.
4. Can two relativistic particles ever meet instantaneously?
No, according to the theory of relativity, the speed of light is the maximum speed at which anything can travel. This means that it is impossible for two particles to meet instantaneously, as it would require them to travel at an infinite speed.
5. Can the time it takes for two relativistic particles to meet be shortened or extended?
Yes, the time it takes for two particles to meet can be shortened or extended depending on the relative velocities of the particles and the observer's frame of reference. Time dilation and length contraction are both effects of relativity that can impact the perceived time it takes for the particles to meet.
