Understanding Completeness of Fourier Basis
In summary, my teacher gave a proof for the completeness of \phi_n(x) = \frac{1}{\sqrt{2\pi}}e^{inx} in L^2([-\pi,\pi]) . He defined Frejer's Kernel K_n(x) = \frac{1}{2\pi(n+1)} \sum_{k=-n}^{n}(n+1-|k|)e^{ikx} He claimed without showing that it could be written as K_n(x) = \frac{1}{2\pi(n+1)} \frac{sin^2((n+1)\frac
stephenkeiths
54
So the other day in class my teacher gave a proof for the completeness of [itex] \phi_n(x) = \frac{1}{\sqrt{2\pi}}e^{inx} [/itex] in [itex] L^2([-\pi,\pi]) [/itex]. And I'm trying to convince my self I understand it at least a little. He defined Frejer's Kernel
[itex]
[/itex]
[itex]
K_n(x) = \frac{1}{2\pi(n+1)} \frac{sin^2((n+1)\frac{x}{2})}{sin^2(x/2)}
[/itex]
He showed it was a summability kernel, and then claimed that any summability kernel approaches the identity. And used this to prove that the only vector orthogonal to all [itex] \phi_n [/itex] is the zero vector. I understand why the last step completes the proof, I'm just looking for some more insight into the rest of the proof.
What I'd like to be able to do, is understand where these definitions come from. What is this kernel and why is it so useful? For instance, if i was trying to prove completeness of the equivalent sines and cosines what would be different? Would the kernel look any different?
Also, in my class on Fourier series, we learned that [itex] sin(nx) [/itex] and [itex] cos(nx) [/itex] are complete on their own, in [itex] L^2([0,\pi]) [/itex]. How does this relate? How could I prove this? Would I have to use a new kernel?
Thanks in advance!
One of the major problems in the theory of Fourier series is that of pointswise convergence. That is, given a function ##f## and an ##x\in [-\pi,\pi]##, when can we guarantee that
[tex]f(x) = \sum_{n=-\infty}^{+\infty} c_n e^{inx}[/tex]
There have been inventend various conditions, such as differentiability, which make it work. It is however very curious that continuity is not sufficient.
However, there are other types of convergence which behave much better than pointswise convergence. One of these types is called Cesaro convergence. Define
[tex]s_N(x)= \sum_{n=-N}^{N} c_n e^{inx}[/tex]
Usual pointswise convergence cares about ##\lim_{N\rightarrow +\infty} s_N(x)##. Cesaro convergence only requires converges of the averages. That is, it demands that
[tex]\lim_{N\rightarrow +\infty} \frac{1}{N} \sum_{k=-N}^N s_k(x)[/tex]
For example, take ##s_N(x) = (-1)^N##, then this sequence does not converge, but it does Cesaro converge to ##0##. On the other hand, if you have usual pointswise convergence, then you always have Cesaro convergence. One of the major theorems in Fourier analysis is the Fejer theorem which states that any Fourier series Cesaro converges to the function provided it is continuous.
How does all this relate to the Fejer kernels? Let us introduce the concept of a convolution product. Given any two integrable functions ##f## and ##g##, we define
[tex](f*g)(x) = \frac{1}{2\pi}\int_{-\pi}^\pi f(x-t)g(t)dt[/tex]
One of the major advantages of the convolution product is that it relates to ordinary product in the sense that if ##c_n## and ##d_n## are the respective Fourier coefficients of ##f## and ##g##, then the coefficients of ##f*g## are ##c_nd_n##.
Here, the important property is that if you take the function ##e_k(x) = e^{ikx}##, then
[tex](e_k*f)(x) = c_k e_k[/tex]
So the partial Fourier series of ##f## can be written as
[tex]s_n = \sum_{k = -n}^n c_k e_k = \left(\sum_{k=-n}^n e_k\right)*f[/tex]
So the Fourier series can be seen as the convolution with one function. This function is called the Dirichlet kernel, ##D_n = \sum_{k=-n}^n e_k## and it controls pointswise convergence.
Cesaro convergence is
[tex]\frac{1}{N} \sum_{n=-N}^N s_n = \left(\frac{1}{N}\sum_{n=-N}^N \sum_{k = - n}^n e_k\right)*f[/tex]
The somewhat complicated function ##K_N = \frac{1}{N}\sum_{n=-N}^N \sum_{k = - n}^n e_k## is exactly the Fejer kernel and can be checked to have the form you describe above.
So this Fejer kernel controls Cesaro convergence. It has a few properties that make it very well behaved, these properties are:
  • ##K_n\geq 0##
  • ##\frac{1}{2\pi}\int_{-\pi}^\pi K_n(t)dt = 1##
  • For any ##\delta##, we have ##\int_{\delta\leq |t|\leq \pi} K_n(t)dt\rightarrow 0##
The Dirichlet kernel for pointswise convergence does not share these properties and this explains why pointswise convergence has worse properties.
The completeness of the sine and cosines can easily be proven from the completeness of the exponential functions, just use the relations
[tex]\sin(x) = \frac{ e^{ix} - e{-ix}}{2i},~\cos(x) = \frac{e^{ix} + e^{-ix}}{2},~e^{ix} = \cos(x) + i\sin(x)[/tex]
Likes 1 person
First of all, thank you for the very informative post; it was very enlightening.
Why do [itex] sin(nx) [/itex] form a complete basis in [itex] L^2([0,\pi]) [/itex]?
What is the essential difference? Does it have to do with odd and even functions?
Thanks again
Related to Understanding Completeness of Fourier Basis
What is the Fourier basis and why is it important?
The Fourier basis is a set of functions that are used to represent any periodic signal or function. It is important because it allows us to break down complex signals into simpler components, which makes it easier to analyze and understand them.
What does it mean for a Fourier basis to be complete?
A Fourier basis is considered complete if it can accurately represent any arbitrary function or signal. This means that by combining different components of the Fourier basis, we can approximate any function with a high level of accuracy.
How does the completeness of Fourier basis relate to the Fourier transform?
The Fourier transform is a mathematical operation that allows us to decompose a signal into its frequency components. The completeness of the Fourier basis is crucial for the Fourier transform to work, as it provides a basis for representing the signal in the frequency domain.
What is the difference between a discrete and continuous Fourier transform?
The discrete Fourier transform (DFT) is used for signals that are sampled at discrete intervals, while the continuous Fourier transform (CFT) is used for signals that are continuous. The DFT is a discrete version of the CFT and is often used in digital signal processing.
How is the completeness of Fourier basis used in practical applications?
The completeness of Fourier basis has many practical applications, such as in signal processing, image and audio compression, and data analysis. It allows us to analyze and manipulate signals in the frequency domain, which can provide valuable insights and help us solve real-world problems.
  • Topology and Analysis
