Velocity as a function of area in pipe flow
In summary, the equation for calculating the average velocity in a pipe over its cross-sectional area can be perplexing because the velocity is already a function of diameter. However, this is due to the difference between local axial velocity at a point and the average velocity across the cross section. While the average velocity can be calculated by dividing the volumetric flow rate by the total cross sectional area, using a different variable such as diameter instead of area may not accurately represent the velocity at each point.
mech-eng
828
There is an equation which perplexes me and it is about calculation of average velocity in a pipe but over area.
In the image, the velocity is already function of diameter, i.e, u=u(r) so how can we think velocity as a function of area?
Source: Fluid Mechanics, Fundamentals and Applications by Çengel/Cimbala
Thank you.
You've sort of answered your own question. It's the difference between the velocity at a point, which is a function of ##r##, and the average velocity across the cross section, which averages that ##r##-dependence away and depends on ##A##.
mech-eng said:
There is an equation which perplexes me and it is about calculation of average velocity in a pipe but over area.In the image, the velocity is already function of diameter, i.e, u=u(r) so how can we think velocity as a function of area?
Thank you.
u(r) is the local axial velocity at radial coordinate r. The axial velocity is maximum at the center of the tube u(0), and is zero at the wall, u(R) = 0. If you want to get the average axial velocity, you calculate the volumetric flow rate and divide by the total cross sectional area of the tube.
Can thinking of u(Area) instead of U(D) be the same? Because Area is function of diamter as well. This looks like a differential equation problem and while integrating over area it becomes integration over diameter because dA=2*pi*r*dr
Thank you.
In general, the velocity varies over the range of ##r##. Doing the integration so that it is ##u_{avg}(A)## loses all that information about the ##r## dependence. You could certainly cast it in terms of ##u_{avg}(D)## as long as you are just referring to ##D## as the inner diameter of the pipe and not some kind of surrogate for ##r##, but you couldn't get ##u(D)## just like you couldn't get ##u(A)##. It is less intuitive though, since using ##A## comes from conservation of mass.
Related to Velocity as a function of area in pipe flow
1. What is velocity as a function of area in pipe flow?
Velocity as a function of area in pipe flow refers to the relationship between the velocity of a fluid and the cross-sectional area of a pipe through which it is flowing. As the area of the pipe decreases, the velocity of the fluid increases, and vice versa.
2. How does the velocity change as the area of the pipe changes?
The velocity of the fluid increases as the area of the pipe decreases, and decreases as the area of the pipe increases. This is due to the principle of conservation of mass, which states that the total mass of a fluid remains constant throughout a pipe, and thus the velocity must change to compensate for changes in area.
3. What is the equation for velocity as a function of area in pipe flow?
The equation for velocity as a function of area in pipe flow is given by the continuity equation: A1V1 = A2V2, where A1 and V1 are the cross-sectional area and velocity at one point in the pipe, and A2 and V2 are the area and velocity at another point in the pipe. This equation shows the inverse relationship between velocity and area.
4. How does the shape of the pipe affect the velocity as a function of area?
The shape of the pipe does not affect the velocity as a function of area, as long as the cross-sectional area remains constant. This means that the velocity will change in the same way regardless of whether the pipe is circular, rectangular, or any other shape.
5. Can velocity as a function of area be used to calculate the flow rate of a fluid?
Yes, the velocity as a function of area can be used to calculate the flow rate of a fluid. By knowing the cross-sectional area and velocity at a certain point in the pipe, the flow rate can be calculated using the equation Q = A * V, where Q is the flow rate, A is the cross-sectional area, and V is the velocity. This equation is based on the continuity equation mentioned in question 3.
  • General Engineering
  • Classical Physics
