Very Basic Nuclear Reaction Q Value Problem
In summary, the conversation discusses the energy of a gamma particle in a reaction involving a neutron and another particle, assuming both particles are at rest. By using momentum balance and assuming m_Y*c^2 >> Q, it is found that the energy of the gamma approaches Q in the limit. This is because the increasing rest mass of Y requires less energy for the gamma, leaving more energy for binding energy in Y. The concept of Q is defined as the excess energy left after assembling Y from neutron and X.
steeeeevo
Hello,
I looked around before and could not find an answer to this question.
So given the reaction
neutron + X -> Y + gamma
and we assume that both initial particles are at rest.
Then using momentum balance we can find that the energy of the gamma is:
Egamma = -m_Y*c^2 + sqrt( (m_Y*c^2)^2 + 2Q*m_y*c^2).
Here is what I don't get. The question says to assume that m_Y*c^2 >> Q. Using the binomial theorem and rearranging the above you get that in the limit, E_gamma -> Q. Why does the energy of the gamma approach Q? I originally thought that the energy of the gamma would approach 0 since the increasing rest mass of Y would cause more energy to be needed as binding energy in Y, thus leaving less energy for the gamma.
Please help... ;)
Thanks.
How do you define Q? As an excess energy left after you're done assembling Y from neutron and X? This energy is divided into kinetic energy of Y and energy of the photon. If Y is very heavy compared with Q, it needs very little energy to balance the momentum of the massless photon.
Hello,
The reason why the energy of the gamma approaches Q in the limit is because Q represents the net energy released in the reaction. In other words, it is the difference between the initial and final energies of the particles involved. Since we are assuming that m_Y*c^2 >> Q, the energy released in the reaction is much smaller compared to the rest mass energy of Y. This means that the energy of the gamma will be very close to the energy released, which is Q.
As for your initial thought about the energy of the gamma approaching 0, it is important to remember that Q is a positive value and therefore, in the limit, the energy of the gamma cannot approach 0. It will always be equal to or greater than Q.
I hope this helps clarify your understanding. Let me know if you have any other questions.
Related to Very Basic Nuclear Reaction Q Value Problem
What is a nuclear reaction?
A nuclear reaction is a process in which the nucleus of an atom is altered, resulting in the production of different elements or isotopes and releasing a large amount of energy.
What is a Q value in a nuclear reaction?
The Q value, also known as the reaction energy, is the amount of energy released or absorbed during a nuclear reaction. It is calculated by subtracting the sum of the masses of the reactants from the sum of the masses of the products.
How is the Q value used in nuclear reactions?
The Q value is used to determine whether a nuclear reaction is exothermic (releasing energy) or endothermic (absorbing energy). It is also used to calculate the amount of energy released in a particular reaction.
What is the formula for calculating the Q value?
The formula for calculating the Q value is Q = (mp + mt - md - m4He)c2, where mp, mt, md, and m4He are the masses of the proton, target nucleus, deuteron, and helium-4 nucleus, respectively, and c is the speed of light.
How can we use the Q value to predict the stability of a nucleus?
The Q value can be used to determine the stability of a nucleus. If the Q value is positive, the reaction is exothermic and the nucleus is more stable. If the Q value is negative, the reaction is endothermic and the nucleus is less stable. A higher Q value indicates a more stable nucleus.
  • Science Fiction and Fantasy Media
