What Constitutes something being coordinate free
  • Thread starter saminator910
  • Tags
    Coordinate
In summary: If you have a coordinate system, you can never be coordinate free. Coordinate free means that you don't specify a coordinate system.
saminator910
96
What Constitutes something being "coordinate free"
People say that exterior calculus ie. differentiating and integrating differential forms, can be done without a metric, in without specifying a certain coordinate system. I don't really get what qualifies something to be 'coordinate free', I mean in the differential forms I do, one still references components ie. x1,x2, etc., yet I never specified a metric, so is this classified as 'coordinate free'. Also, how does one do differential geometry without a coordinate system, in my mind once you don't specify a coordinate system or a metric, and things become vague, it sort of turns into differential topology, is there a 'middle ground' I am missing, keep in mind I have never taken a coarse in differential geometry. Also, in differential geometry, it has always been pertinent to give specific parametrization in order to find tangent vectors, metrics, etc.
If you use xi, that (implicitly) means that you have chosen a coordinate system, so it is not coordinate free.
To give a very simple example, consider a linear transformation (e.g. rotation) T on a vector x. You could write this in coordinate-free form as
x' = T x
This does not depend on which basis you choose for the space that x lives in - it just means: apply this transformation.
When you calculate the result on a vector, you usually pick a coordinate system by choosing a set of basis vectors (x, y, z-axis) and write the action of T as a matrix M.
You then calculate
[tex]\mathbf{x'}_i = \sum_{j = 1}^n M_{ij} x_j [/tex]
This is not coordinate-free, because both the components of x and x' as well as the entries of M depend on the coordinate system.
The advantage of the coordinate-free form is that it looks the same in any choice of basis. If you and I both chose a different coordinate system and wrote down M, we would get two different bunches of numbers but it would not be immediately clear that we're talking about the same "physical" operation.
Another example: Let X be the set of all quadratic polynomials from R to R and define T by T(f)= df/dx+ f. That is a "coordinate free" definition. If I had chosen [itex]\{1, x, x^2\}[/itex] as basis (essentially choosing a "coordinate system" by choosing a basis), say that T(1)= 1, T(x)= x+ 1, T(x2)= x2+ 2x, then say T is "extended by linearity", T(af+ bg)= aT(f)+ bT(g), that is not "coordinaate free" because I have used a coordinate system (a basis) to define it. Or course, those are exactly the same definition.
It would be interesting to sort out the distinction between "having a coordinate system" and "having a metric". The two definitions are not identical, but what common situations allow us to proceed from having one to having the other?
Aren't they two completely different things?
Sure, for a lot of "common" metric spaces the metric is defined in terms of coordinates. But for Rn, for example, that's mostly because people usually learn Pythagoras before inner products, so
[tex]\sum_i (y_i - x_i)^2[/tex]
is a little more intuitive than
[tex]\langle \vec y - \vec x, \vec y - \vec x\rangle[/tex]
Of course they are, that's why sorting out their relation is complicated. The idea of a metric on a set of things is standardized, but I'm not sure whether there is an standard definition for a set of things to "have a coordinate system".
The pythagorean idea won't necessarily work for a coordinate system where the same thing can have two different coordinates (as is the case in the polar coordinate system).
Okay so, your standard differential form, written with coordinates say for example a standard 1 form, [itex]\alpha = \sum^{n}_{i=1}f_{i}du_{i}[/itex], you are still referencing a it's local coordinates, but you don't necessarily need to know what the metric is ie. euclidean space vs. it being embedded in some other manifold, so the coordinates don't necessarily need any intrinsic value. then if you know the [itex]u_{i}[/itex] coordinates in terms of euclidean or other coordinates, you pullback/pushforward the form. Does this count as 'coordinate free' since you don't specify a basis: the coordinates in the form aren't in terms of anything.
Once we have a coordinate system, so that every point, x, can be identified with [itex](x_1, x_2, ..., x_n)[/itex], there is a "natural" metric, [itex]d(x,y)= \sqrt{(x_1-y_1)^2+ (x_2- y_2)^2+ ...+ (x_n- y_n)^2}[/itex].
Given a metric space, even finite dimensional [itex]R^n[/itex], we would need a choice of "origin", and n-1 "directions" for the coordinate axes (after choosing n-1 coordinate directions, the last is fixed) in order to have a coordinate system. So a "coordinate system" is much more restrictive, and stronger, than a "metric space".
But does the definition of a "coordinate system" ( if there is such a standard definition) include the idea that each element of "the space" can be identified with a unique finite vector of coordinates? And must the vector consist of a vector of real numbers?
okay, so now can someone give an example of using a differential form without a metric?
Related to What Constitutes something being coordinate free
What does it mean for something to be coordinate free?
Being coordinate free means that a mathematical or scientific concept or equation does not rely on a specific set of coordinates or reference frame to be defined or calculated.
Why is it important for something to be coordinate free?
Having a coordinate free concept or equation allows for more general and universal applicability, as it is not limited to a specific coordinate system. This makes it easier to apply to different scenarios and simplifies calculations.
How can I tell if something is coordinate free?
One way to determine if something is coordinate free is to see if it can be expressed using only mathematical objects or operations that are invariant under coordinate transformations. Another way is to see if it remains valid and applicable in different coordinate systems.
What are some examples of coordinate free concepts or equations?
Some common examples of coordinate free concepts include vector spaces, tensors, and differential forms. Specific equations that are coordinate free include Maxwell's equations in electromagnetism and Einstein's field equations in general relativity.
What are the benefits of using coordinate free concepts?
Using coordinate free concepts allows for a more elegant and concise formulation of mathematical and scientific ideas. It also makes it easier to generalize and extend these concepts to new situations without needing to change the underlying equations. Additionally, it can help identify and eliminate errors caused by coordinate system dependencies.
  • Topology and Analysis
  • Differential Geometry
