What exactly is a threshold frequency?
In summary: However, the calculations get increasingly complicated and less accurate the more particles are involved, so it's not always feasible to use these models for specific interactions.
MathewsMD
433
For example, when you have a photon interacting with a bound electron, there is a work function relating the minimum energy photon capable of interaction (given by hf). My question is, what exactly is going on in this situation if the work function is exactly equivalent or less than the energy of the incident photon? How exactly does the photon and electron interact?
Also, is there anything similar to this? For example, an electron hitting a proton must have a particular energy requirement for interaction (right?). What exactly determines the threshold frequency necessary for interaction with a proton (is it the nuclear forces)? How about for structures composed of more than one atomic entity (e.g. sugar molecule)? Can a photon interact with the molecule as a whole or must it interact with distinct components (e.g. electrons, protons)? Can essentially anything interact with something else if it has enough energy?
I guess my question boils down to: do all things exhibit a "threshold frequency"?
Please let me know if you need any further clarifications or if I'm grossly mistaken on any points.
Physics cannot answer "how" questions on a fundamental level. We just observe that interactions do happen, and find equations to describe the result of those interactions.
For inelastic interactions, where the particle contents change, yes.
Energy conservation. The energy of hadrons like the proton is mainly determined by the strong force (and quark masses). For molecules, you also have to consider the electromagnetic interaction and the electron mass.
Both can happen, the energy of the photon is important.
Yes.
Only if you want to create new particles, or reach excited states, or need the energy for something similar.
Likes MathewsMD
Sure. Are there any particular models for this particular type of interaction?
mfb said:
Both can happen, the energy of the photon is important. Yes.
Would you possibly know of an example besides electrons and photons (I might be missing something here)? Are there any models by chance for this?Thank you for all the help!
Molecules of many gases have rotational and vibrational energy states and they will interact with appropriate EM frequencies ( Infra red and Microwave photons). RF waves will interact with vast numbers of conduction electrons in a metal antenna to cause currents - which can be detected with a Radio Receiver. So it's best to refer to interaction with 'charge systems', rather than just with 'electrons', as in the Hydrogen atom.
Quantum electrodynamics.
An example of what? The question I replied to was specific to the interactions of photons with matter.
For non-photon-related interactions, you also get quantum chromodynamics (for the strong interaction) and the electroweak interaction (which unifies the electromagnetic interaction with the weak interaction). Both together form the so-called Standard Model of particle physics, which (at least in theory) allows to predict all interactions (as long as gravity is irrelevant).
Related to What exactly is a threshold frequency?
1. What is a threshold frequency?
A threshold frequency is the minimum frequency of light required to induce a photoelectric effect in a specific material.
2. How is threshold frequency related to the photoelectric effect?
The threshold frequency is directly related to the energy of the photons in a light beam. If the frequency of the light is below the threshold, no electrons will be emitted from the material, but if it is above the threshold, the photoelectric effect will occur.
3. How is threshold frequency measured?
The threshold frequency can be measured experimentally by gradually increasing the frequency of light shone on a material until electrons are emitted. The frequency at which this occurs is the threshold frequency.
4. What factors can affect the threshold frequency?
The threshold frequency can be affected by the material's composition, temperature, and surface conditions. It can also vary depending on the intensity of the light beam.
5. Why is the concept of threshold frequency important in understanding photoelectric effect?
The concept of threshold frequency is crucial in understanding the photoelectric effect because it explains why some materials only emit electrons when exposed to certain frequencies of light. It also helps to determine the energy of the photons involved in the process.
  • Electromagnetism
  • Electromagnetism
12K
  • Atomic and Condensed Matter
  • Quantum Physics
