What is the exact definition of a function?
In summary, a function is a collection of pairs of numbers with the property that if two pairs have the same first element, then they must also have the same second element. This is different from the concept of a preimage, where multiple elements in the domain can map to the same element in the range. The formal definition of a function is a set of ordered pairs with unique first elements.
woundedtiger4
188
In text (Spivak) it says that a function is a collection of pairs of numbers with the following property: if (a,b) & (a,c) are both in the collection, then b=c; in other words, the collection must not contain two different pairs with the same first element. Now in an other text (Kolmogorov) I found that if b is a range of the function then it could have several preimages or no preimages at all (preimage means the domain) now these two definitions are opposite to each other & I don't really know that which one is true :|
P.S. Just figured out that both definitions are same, please ignore my post
I think you've just gotten mixed up with the second definition. In the first definition, the author is saying that for any given element that you input into a function, there is one unique element as output. (we can use the vertical line test to examine this property). That's why in the example it said, if (a,b) and (a,c) are part of the range then b = c, because there is only one unique mapping for a. Now, the second definition you mentioned, the author is saying that the reverse isn't necessarily true - a function *can* have an element in the range (output) that has more than one elements as its input (preimage). To use a similar "definition", the author could say (a,b) and (x,b) does NOT imply (a=x). (imagine the function f(x)=x^2, you can plug in 2 and -2 and each of these produce 4). Do you see the difference? In that first definition we are talking about the fact that each element of the domain gets mapped to a unique element in the range. in the second definition we are talking about the fact that multiple elements in the domain can map to the same element in the range.
Hope that helps! I think you just got a little thrown off because it sounds like the same thing is being talked about in bothEDIT: Just saw that you said ignore you post, but wanted to point out that both definitions are NOT the same, they are talking about different things. Just wanted to make sure you were clear on the definitions the author gave
Hello,
Here is the formal definition of a function:
A function f is defined as a set of ordered pairs (x, y) no two of which have the same first member.
Hope that helps.
basically if you evaluate the equation and find that it has two of the same x values, then it's not a function. just apply the vertical line test. if that line intersects the curve more than once, it's not a function. pretty much all there is to it.
That didn't make much sense, did it? "To evaluate the function and then find... it is not a function"?
The vertical line test may work for functions with graphs and only on a plane. There are plenty of functions which haven't such a representation.
Hivesaeed4 already gave the formal definition from set theory.
DonAntonio
Lol. I said if you evaluate the "equation" - whatever it may be. I did not say if you evaluate the function. I almost said that in my initial response, though. Ha ha.
I f you want to think about functions, not many people think of them this way. I.e. technically this is the definition of the "graph" of a function. I.e. if A and B are sets, then any subset of the cartesian product AxB is called a correspondence between A and B. If the subset passes the vertical line test, it is the graph of a function defined on that subset (called the domain) of A consisting of the elements that occur as first entry of a point on the graph.
The function itself is thought of as a mapping that picks up each element x of the domain from A and deposits it on top of the unique element y of B that occurs as the second entry of the unique pair having x as first entry.
Thus many people define a function f from A to B as a rule that assigns, to each element x of A, a unique corresponding element f(x) in B. Then the graph of f is the subset of AxB consisting of all pairs (x,f(x)).
Very problematic to define a function as a rule. If by "rule" you mean a finite string of symbols from a countable alphabet, there are only countably many rules. But there are uncountably many functions from one infinite set to another, or even from the natural numbers to the finite set {0,1}.
The OP already gave the mathematically correct definition. The "rule" definition is only suitable for the most casual of contexts, for example presenting functions to high school students for the first time.
Thanks everyone. Actually, I figured out my confusion after starting this thread therefore immediately I posted the 'P.S' :)
Actually, Spivak has done the analysis on range whereas Kolmogorov on domain (Please correct me if I am wrong)
hivesaeed4 said:
Hello,
Hope that helps.
I'm not a mathematician so forgive me for asking a dumb question; what if the function is given as:
(1,10)
(2,12)
(2,12)
(3,14)
Edit: I get it- no two that have *only* the same first member?
(1,10)
(2,12)
(2,12)
(3,14)
Technically, a function is a set of ordered pairs; as a set of ordered pairs, you count (2,12) only once.
Related to What is the exact definition of a function?
1. What is a function?
A function is a mathematical concept that describes a relationship between two variables, where each input has a unique output. In simpler terms, it is a rule that takes in a value and produces a corresponding result.
2. What is the difference between a function and a relation?
A relation is a set of ordered pairs that relate two sets of data, while a function is a special type of relation where each input has a unique output. In other words, while a relation can have multiple outputs for a given input, a function can only have one output for each input.
3. What is the domain and range of a function?
The domain of a function is the set of all possible input values for the function, while the range is the set of all possible output values. In other words, the domain is the independent variable, and the range is the dependent variable.
4. How do you determine if a graph represents a function?
To determine if a graph represents a function, you can use the vertical line test. If a vertical line can be drawn through any point on the graph and only intersect the graph at one point, then the graph represents a function. If the vertical line intersects the graph at more than one point, then it is not a function.
5. What is the difference between a one-to-one function and an onto function?
A one-to-one function, also known as an injective function, is a function where each output has a unique input. In other words, no two inputs can have the same output. On the other hand, an onto function, also known as a surjective function, is a function where every output has at least one corresponding input. In other words, the range of an onto function is equal to its codomain.
  • Topology and Analysis
  • Math Proof Training and Practice
  • Thermodynamics
