Why is kinetic energy 1/2mv^2 instead of mv^2?
In summary, work is the energy added to or taken away from a system when it encounters a force over some distance. The definition of work is actually the integral, W=\intF\bulletdr.
Ghost803
The definition of joules, th unit of energy is the 1 J = 1 kg * m2/v2.
And that 1 joules is the amount of energy needed for the work done by one Newton traveling one meter.
From all this, I got the impression that to get energy, you would have to multiply force times distance. Is work, then just a measurement of energy.
Assuming my first assumption that energy = F x D, let's sat a 5kg object is accelerating towards Earth from 20 feet above at 9.8 m/s2 . To get the force, you would have to do 5 kg x 9m/s2 Then to get energy, that force times distance. So if it traveled 5 meters. The kinetic energy should be F(5kg x 9.8 m/s2) x D(5 meters.)
Which would end up being 5kg x 49m2/s2.
Sooo, can someone explain why ke is 1/2 mv2 instead of just mv2.
Work Energy Theorem
I hope you'll notice that nowhere did you determine its actual speed after falling the 5 meters. If you use your kinematic equations and solve for the time it took to reach the 5 meters and subsequently found the velocity at that 5meter point, you'd see that the energy is infact, mv^2/2
Right, work is the energy added to or taken away from a system when it encounters a force over some distance. The definition of work is actually the integral,
W=[tex]\int[/tex]F[tex]\bullet[/tex]dr
Where dr is the change in position, the D in your equation.
The equation for the kinetic energy of an object, K.E.=1/2mv^2 is derived by making a series of substitutions in the above equation and integrating.
[tex]W=\int_{x_1}^{x_2} F dx=\int_{t_1}^{t_2} m\ddot x \dot x dt=\int_{t_1}^{t_2}\frac{d}{dt}(\frac 1 2 m\dot x^2)dt=\frac 1 2 mv_2^2-\frac 1 2 mv_1^2[/tex]
Well, there would be no conceptual problems whatsoever to define a quantity mv^2, and use this instead of "kinetic energy".
This has already been done; mv^2 is called "vis viva".
But, the work-"vis viva" theorem is less aesthetic than the equivalent work-energy theorem, due to the explicit inclusion of the factor of 1/2 in the formula.
Thx for the replies, everyone. l'll check them all out.
Related to Why is kinetic energy 1/2mv^2 instead of mv^2?
1. Why is kinetic energy expressed as 1/2mv^2 instead of mv^2?
The equation for kinetic energy, 1/2mv^2, comes from the work-energy theorem, which states that the work done on an object is equal to the change in its kinetic energy. In other words, the kinetic energy of an object is equal to the work required to accelerate it from rest to its current velocity. This work is equal to 1/2mv^2, hence the expression for kinetic energy.
2. Is there a specific reason for the 1/2 in the equation for kinetic energy?
The 1/2 in the kinetic energy equation comes from the fact that when an object is accelerating, its velocity is constantly changing. In order to calculate the work done on the object, we need to find the average velocity, which is equal to half of the final velocity. This is why the kinetic energy equation includes the 1/2 factor.
3. How does the mass of an object affect its kinetic energy?
The mass of an object directly affects its kinetic energy. As the mass of an object increases, its kinetic energy also increases. This is because a heavier object requires more work to accelerate to a certain velocity than a lighter object.
4. Can the kinetic energy equation be used for all types of motion?
Yes, the equation for kinetic energy, 1/2mv^2, can be used for all types of motion, including linear, rotational, and vibrational motions. This is because the equation represents the energy an object possesses due to its motion, regardless of the type of motion.
5. Is the kinetic energy equation only applicable to objects in motion?
Yes, the kinetic energy equation is only applicable to objects in motion. It does not take into account the potential energy of an object, which is the energy an object possesses due to its position. The total energy of an object, which includes both kinetic and potential energy, is represented by the equation E=1/2mv^2 + mgh.
  • Mechanics
  • Mechanics
  • Classical Physics
