Why is Quantum Field Theory Local?
  • A
  • Thread starter LarryS
  • Tags
    Local Qft
In summary: I am using... think that entanglement means "nonlocal". Quantum Field Theory includes entanglement, because it includes non-relativistic QM as a special case and makes all of the same predictions for that case.
  • #176
Demystifier said:
So you rule out something that nobody believed in the first place.
That's the case for most theorems.
Likes vanhees71 and gentzen
  • #177
Demystifier said:
For Bohmian mechanics it's not important that the particles are exactly pointlike. If you like they can be balls of the Planck size, it doesn't change anything important.
Then they can even be football size, since they are unobservable, and only their center of mass appears in the equations.
But they are point particles in all publications on the matter.
Likes vanhees71
  • #178
So are the planets in Newtonian mechanics.
  • Haha
Likes vanhees71
  • #179
Yes, and Newtonian mechanics has the typical resulting defects: It can be formulated only as nonrelativistic theory, and has problems with collision trajectories (see the paper by Baez). Just like Bohmian mechanics.
For more than a century we are past this state of affairs.
Likes vanhees71
  • #180
bhobba said:
It shows such theories, as a class, allow for many features of QM, with QM perhaps the simplest
Reading this thread a while later, if you find it interesting quantum theory as a GPT (Generalized Probability Theory) can be characterized in two ways:
(a) As the most general one satisfying the Exclusion principle. Namely that if each of the pairs from a set of observables ##A,B,C## are compatible/co-measurable, then the whole set is co-measurable
(b) The most general one that permits Bayesian updating
"Most general" here means "has the broadest set of possible correlations". So in a CHSH test classical probability gives ##2## as the bound and QM gives ##2\sqrt{2}##, then any theory with correlations beyond ##2\sqrt{2}## breaks both (a) and (b).
Regarding (b), all GPTs allow updating but by "Bayesian" we mean there is a unique way to update in late of data. In GPTs going beyond the Tsirelson bound ##2\sqrt{2}## there is an element of arbitrary choice in how one updates in light of data. This is what leads to a recent phrase: it's the most general GPT where one can still learn.
Likes bhobba and vanhees71
  • #181
Could you give some references?
  • #183
To be more explicit there is also also a third condition proved to be equivalent in this paper, so the full list is that the theory is obeys the following which are all equivalent:
(a) The most general theory satisfying the Exclusion principle. Namely that if each of the pairs from a set of observables ##A,B,C## are compatible/co-measurable, then the whole set is co-measurable
(b) The most general one that permits Bayesian updating.
(c) The most general one which assigns probabilities to any repeatable ideal measurements.
(a) was originally a conjecture of Ernst Specker. Cabello proved (c) implies (a) and from there proves (a) in the paper I linked. After that he later proved (b) in (PDF free access):
https://journals.aps.org/prresearch/abstract/10.1103/PhysRevResearch.2.042001.
Likes bhobba and kith
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
